It is currently Sat Dec 16, 2017 4:18 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Oct 19, 2013 4:59 pm
Well after getting the bike in and putting it on the scale it was not what i was hoping for. I lost only 30g over my Felt f1 frameset but there are lots of upgrades i can do with the RCA to increase that number. I was also sad to see that the jump from 56cm-58cm was a 59gm weight increase where all the size increases from the smaller sizes were only 10gm increases. All that sadness was tossed out of the window once i rode the bike. It is a very fast machine and i killed some KOM that i had been trying for months on, which made it a little better for me. But i need your help with this one, right now i pulled over the stuff from my Felt but i want to upgrade this bike till it cannot be upgraded anymore. The only restriction we have is i have lost a lot of my MM but am not light. I currently weight 210 pounds and i cannot go down any further. Thanks and hope we can build something in the high 9's low 10's. This will be my everyday bike and lets get it done. Thanks guys.
PostPosted: Sat Oct 19, 2013 5:13 pm
There's another thread with a guy whose rca came in at under 11 pounds. My 56 cm rca is at 14 even with zipp 404 tubbies, di2 9070 and a Quarq for reference. But I would comment that your best bet for improved climbing performance is to lose more body weight.
My frame including the rubber cable grommets and brake cable stops, RD hanger, seat post collar, water bottle bolts was 659 gm. Uncut fork was 313 gms.
My RCA
PostPosted: Sat Oct 19, 2013 10:00 pm
i was not so lucky, after reading your thread i was thinking that mine would come in lighter than what it did but i looked at the white papers and it is only a little heavy than the ave in the 58cm. I cannot lose anymore weight myself as i am getting complaints from my wife and my parents that i am too skinny now. So i am just going to try and take it off the bike. Right now the bike comes in at 11.3 but i have DA 7900 cranks running while i wait for my THM CLA cranks to come in. I have a couple of ideas on the build but am looking for other ideas to get this down low and still work as an everyday bike.
PostPosted: Sat Oct 19, 2013 11:12 pm
Do you have a thread for your F1? Love the FC & F1's.
FF Ti Road
EM Alu Cross
PostPosted: Sat Oct 19, 2013 11:25 pm
yeah it is my 56cm felt f1
PostPosted: Sun Oct 20, 2013 12:23 am
Please post your current component/planned build list so we can provide feedback accordingly. High 9s is probably possible but I think reliability will be compromised at that weight point given frame size and the fact that this will be a daily driver. Also consider that most of the ultra lightweight components have rider weight limits.
PostPosted: Sun Oct 20, 2013 4:56 am
this is what i was thinking the build list was going to look like
frame- 58cm 682gm
BB 108gm get a custom one at 65gm
mec hrdward- 42grms
seatpost collar- 6gm
seat,post combo- 288gm work on geting a berk combo 125gm
rd- 126gm
fd- 84grm but thinking of putting the 9000 on to cut more weight 68gm
complete crank,pedals- 733gms have THM coming that will be 494gms
chain- 219gm getting YBN 210gm chain
stem- 104gm want to get ax lightness 110mm 69gm
fork,ultrastar 2- 310gm
brakes w zipp pads- 148gm
shift brake hdls- 205gm
shift clamps- 11gms
shift hoods - 22gms
computer- 54gms
cable housing- 62gms
cables- 10gms
bar 42cm zipp- 176gm was thinking a schmolke tlo 42cm 148gm
bar tape-50 gm
headset- 44gms
spacers- 4 grms
prewrap- 2grm
front wheel 454gm was thinking the extralite hyperclimbs as the lightweight wheelset 830gms
rear wheel 628 gm
f tire- 152gm
b tire- 158gm
cassette wlock- 94gm
120psi of air x2- 16 grm
kcnc qr- 42gm have tune skyline coming 21gms
lube- 6grm
glue- 6 grams
tire seal- 18grm
total 5064gm could be 4258gm
That is what i was thinking
PostPosted: Mon Oct 21, 2013 11:34 am
Which pedals are thinking about, you can save weight on the fork and about 10 grams using deda bartape. Bottle cages, you can go lighter here as well
PostPosted: Mon Oct 21, 2013 11:52 am
So you are not going to use the stock fork???....its sub 300 after cutting.
My RCA
PostPosted: Mon Oct 21, 2013 3:33 pm
i use the aerolite pedals that are 74gms and i am currently using the fork that came with the frameset but i would love to change that but could not find a fork that was 1-3/8" that was less than this one. Which one were you thinking about?
PostPosted: Mon Oct 21, 2013 3:40 pm
which deda bar tape is 40grams? That will help the number i am trying to hit. thanks
PostPosted: Mon Oct 21, 2013 3:52 pm
That's pretty light for a 210 lb rider. Do you have experience with the sub 1100 g wheelset at your current weight that makes you confident with looking at a sub 900g wheelset?
PostPosted: Mon Oct 21, 2013 4:01 pm
I have been riding the enve 1.45 for a little over 8 months and they come in at 1081 or so and i like them, this would be the first set under 1000 grams.
PostPosted: Mon Oct 21, 2013 5:35 pm
If you roll it on tight it should be around 40, from the looks schmolke bars require a bit less tape maybe others can confirm
PostPosted: Mon Oct 21, 2013 5:57 pm
That is great news i will get some on order. This is what i was hoping for. Any other places that i can lose extra grams? Thanks for all your help.
There are no new unread posts for this topic. 2017 Cube Attain GTC SL Disc 58cm
89daytona
Mon Nov 13, 2017 6:21 pm
89daytona View the latest post
Users browsing this forum: Google Adsense [Bot] and 14 guests
