It is currently Mon Jan 22, 2018 9:49 am
Post new topic  Reply to topic  [ 121 posts ]  Go to page Previous 1 2 3 4 59 Next
 Post subject: Re: CAAD10 - Force 22
PostPosted: Wed Oct 23, 2013 9:27 pm
^is that weight with the original wheels?
PostPosted: Thu Oct 24, 2013 2:05 am
It was 18lbs with the original wheels and brakes.
Lost 2lbs (about 900 grams) swapping to Force 22 and my XR19w wheels. I was going to use the PX brakes, but I am going to try out the Force brakes to see if I like them.
I also just ordered a C1 stem and seatpost which should net me roughly 60 grams for about $80......my goal for this build is 6.8kg so going to look for creative ways to achieve this without using exotic components. By my reckoning I should be half way there or more after the crank and stem/post swap. If I am a bit short I will go for a saddle upgrade.....I think I may like this shape so may go for the upgraded version of the same saddle.
Sent from my iPad using Tapatalk HD
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Fri Oct 25, 2013 2:23 pm
First ride last night and I am very please with the bike. Many compliments from the group on the aesthetics of the frame/group and overall color coordination (which we all know is of the utmost importance :wink:). The ride brought back memories of my last CAAD 10, but it almost seemed to ride smoother....not sure what changes that Cdale made to the frame from 2011 to 2013, but it felt like the vibration damping was improved. A little bit of weight loss (on me and the bike!) would be welcome; however, I PR'd a segment even with the extra weight (probably new bike exuberance). Hopefully the Force 22 cranks and the new stem/post will come in this weekend and will get some updated pics of the "final build". :beerchug:
Mosaic RS-1
PostPosted: Fri Oct 25, 2013 3:08 pm
Happy to hear everything seems to be working and you are happy with it so far. Try to keep this ride for a little while this time. :)
Any thoughts on Force22 vs DA9000? Or not enough time on Force22?
PostPosted: Fri Oct 25, 2013 3:17 pm
We will see :wink:
As far as the Force/DA.....there is no doubt that 9k is much smoother in operation. The lever throw is much less for the front mech; however the front shifting on the Force 22 is pretty darn good tbh. I will give myself the credit in setup that the rear runs quiet and shifts well.
Mosaic RS-1
PostPosted: Fri Oct 25, 2013 6:52 pm
Beautiful build! How does the new Force 22 compare to Red? New force 22 is suppose to be the old red but at a better price.
PostPosted: Fri Oct 25, 2013 8:21 pm
Except that Force now has 1 more speed than old Red/2012, so it's different.
 Post subject: CAAD10 - Force 22
PostPosted: Sat Oct 26, 2013 3:12 am
Force 22 and Red 22 are functionally the same.
PostPosted: Sat Oct 26, 2013 3:21 am
Got the crank on.....the NDS looks funky, but the crank is centered, chainline is perfect and there is no perceivable play so I guess it is correct since I followed the directions to a T. I had to use the thick spacer on the drive side since the crank is BB30 + PF30. Have a 50 mile group ride in the morning so I hope it holds up!
Mosaic RS-1
PostPosted: Mon Oct 28, 2013 4:41 am
So what's up with the fire sale, dude?
PostPosted: Mon Oct 28, 2013 12:46 pm
Just selling the group that came with the bike and two cranks that I was considering using for the build. I bit the bullet and purchased a Hollowgram crank that should be coming in soon, so trying to recoup some funds. :wink:
Mosaic RS-1
PostPosted: Mon Oct 28, 2013 5:34 pm
As I had read half the text i was like "No, no, no, don't keep the FSA cranks!" But then... Hollowgrams :thumbup: .
Tumblr
Instagram
Kaptajn Webstore
PostPosted: Mon Oct 28, 2013 5:38 pm
:wink: :thumbup:
Mosaic RS-1
PostPosted: Tue Oct 29, 2013 1:38 am
Got the upgraded C1 stem/seatpost
Lost a good bit of weight there. It is the 250mm post, but to get the right saddle height I needed to ignore the minimum insertion line by ~5mm or so.....should be ok, right? :noidea: It appears that the post still extends below the TT junction.
Had to go to a 110mm stem over the 100mm that came on the bike, weight stayed the same so I call that a win!
Mosaic RS-1
PostPosted: Tue Oct 29, 2013 1:49 am
Which Hollogram version did you end up going with.
There are no new unread posts for this topic. New to me CAAD10 ..aka Super 10
gtinut
Tue Feb 28, 2017 2:53 pm
FLtrooper View the latest post
There are no new unread posts for this topic. Caad10 sub 7kg with Vector 2 Project
sgergole
Tue Feb 14, 2017 4:30 am
nemeseri View the latest post
There are no new unread posts for this topic. Attachment(s) Wanted to buy-Cannondale fork (CAAD10/12, SS evo)
in Wanted
juanacity
Mon Nov 27, 2017 2:21 am
juanacity View the latest post
There are no new unread posts for this topic. Help me get below 17lbs for stock CAAD10 105... on the cheap
[ Go to page: 1 2 3 4 ]
Morghulis
56
5971
Thu Jun 29, 2017 12:40 pm
JDEves View the latest post
There are no new unread posts for this topic. Cannondale CAAD10 - Stem Torque for Carbon Steer
steelandbananas
9
1126
Sat Feb 11, 2017 6:11 pm
Hamfist View the latest post
Users browsing this forum: caballero, crux, kantcantcamp, KCookie, Squashednuts and 14 guests
