It is currently Mon Feb 27, 2017 8:14 am
 Post subject: New Shoes for my Moots
PostPosted: Sun Oct 06, 2013 8:52 am
A few rides in with the new wheels and time for an update. I have tried this bike with a set of Hyperons, a set of Lightweights, a set of Boras and a set of 404 Firecrests, but I have to say, the hype about the ENVE 3.4s on King hubs is absolutely justified.
They are a couple of a hundred grammes heavier than the Lightweights, but on a par or slightly lighter than the others. More versatile than the Hyperons, more aero than the Lightweights, less prone to the strong sidewinds that we get on Hong Kong island than the Boras and 404s. The best of all worlds, and the King hubs are just wonderful and should stay that way for a while. And (if this makes sense), they ride lighter than any of them. Not the best braking, but I think that will improve as I put down a layer of the ENVE brake pad compound on the braking surface. Right now, I wouldn't trust them on the steep descents of Hong Kong in the rain!
I have almost finished building my new Moots Psyclo X RSL with Super Record EPS and disc brakes which should be just the ticket for those hilly braking issues! Just waiting for the new internal battery to hit the shops. I know that discs are a big discussion topic right now, but I hope to be able to make a considered and informed contribution to that debate before too long. The Psyclo X will be predominantly a cyclocross bike built with ENVE XC rims on King R45s, but I am also having a set of Mavic Open Pro CD (to mask the brake surface) built onto King R45s with Vittoria OPen Corsa 25s to use only on the road for bad weather training. More new on that one as it breaks. Come on Campagnolo - get that new battery shipping!
Contrary to the ENVE recommendation, I am running 25mm tubs. ENVE recommend 23mm for optimum aerodynamics, but some of the roads over here are concrete with wheel-eating expansion gaps in between and the 25s are just that bit more comfortable.
A typical Autumn day in Hong Kong. 32 degrees, sunny and a gentle breeze. I do miss the road scene in Europe, but as Winter approaches, Hong Kong has its distinct advantages!
Really well built by Strada in the UK. Highly recommended.
Frame - Moots Vamoots RSL
Fork - ENVE 2.0 tapered
Aheadset - Chris King Inset 7
Chainset - Campagnolo Super Record Ti Compact
Bottom Bracket - Campagnolo PF30 cups
Pedals - Look Keo Carbon Titanium
Front Deraileur - Campagnolo Super Record EPS
Rear Deraileur - Campagnolo Super Record EPS
Shifters - Campagnolo Super Record EPS
Brakes - Campagnolo Super Record
Chain - KMC SL
Cassette - Campagnolo Super Record 12/25
Wheels - ENVE 3.4/Chris King R45
Tyres - Continental Competition 25mm
Stem - Moots RSL
Bars - Zipp SL Carbon
Seatpost - Moots Cinch
Saddle - Fizik Arione
Grips - Deda Cork
PostPosted: Sun Oct 06, 2013 12:34 pm
Administrator
judging by the picture your moots deserves these shoes!. Great looking ride.
Quote:
PostPosted: Sun Oct 06, 2013 2:59 pm
Location: somewere floating between here and the other side
very nice set up ! (-:
PostPosted: Tue Oct 08, 2013 12:00 am
Looks great...btw, something I found out, you can direct from Moots get a seatpost finish to match frame/stem. They don't recommend it because it scuffs easily but if you have your height nailed it looks so much better imo.
Thing 1 & Thing 2 & Thing 3
PostPosted: Tue Oct 08, 2013 2:55 am
What's the weight??
PostPosted: Tue Oct 08, 2013 2:41 pm
i am wondering, is yours a custom frame where the external lower headset was considered (which has a higher stack height than an internal)
PostPosted: Tue Oct 08, 2013 4:26 pm
Yes, it was a custom geometry to have a longer head tube, and slightly longer top tube and to incorporate the external lower bearings.
I will weigh it at the weekend. Think it is just below 16lbs. Not bad for a 58cm frame.
PostPosted: Wed Oct 09, 2013 1:21 am
I wouldn't kick that out of bed.
Speedvagen Road
Stoemper SSCX disc
Ira Ryan XCR DI2
Parlee TT
Moots Mooto-X RSL SS
Richard Sachs Cyclocross
Scott Spark 29er
There are no new unread posts for this topic. My Moots Vamoots CR
Jcgill
Thu Jul 21, 2016 6:12 am
beeatnik View the latest post
There are no new unread posts for this topic. Tapered carbon forks: Columbus, Enve or Moots?
fudgefudgefudge
Tue Jun 14, 2016 2:29 pm
Marin View the latest post
There are no new unread posts for this topic. New Lake CX 301 WW Shoes
Ozrider
12
1406
Fri Oct 21, 2016 8:24 am
Ozrider View the latest post
There are no new unread posts for this topic. D2 vs Rocket7 shoes
Master-Ti
14
895
Sun Feb 12, 2017 4:46 am
Master-Ti View the latest post
There are no new unread posts for this topic. Down to CX shoes: The best choices are ....?
LouisN
29
3244
Tue Nov 15, 2016 10:03 pm
PARTIZAN View the latest post
Users browsing this forum: Delorre, KarlC, motorapido and 7 guests
