It is currently Fri Jan 19, 2018 9:15 am
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: New Condor Terra-X
PostPosted: Fri Sep 20, 2013 11:22 pm
Well she's finally finished. 8.5kg with Record 11 & Hope V-twin hydraulic brakes. Wheels are Stans ZTR Iron Cross on DT 240S. Michelins have tubes at present but will be tubeless very soon.
Mud of Epping awaits!
Sent from my iPad using Tapatalk - now Free
 Post subject: Re: New Condor Terra-X
PostPosted: Sat Sep 21, 2013 7:29 am
Looks great - enjoy tearing up Epping!
PostPosted: Sun Sep 22, 2013 3:52 am
What size is that frame?
PostPosted: Sun Sep 22, 2013 6:49 am
52cm. 120 stem in the pic has been swapped out for a 110 and hoses are now trimmed. Rear hose is internally routed now too.
Sent from my iPhone using Tapatalk - now Free
PostPosted: Mon Sep 23, 2013 4:52 pm
Thanks.
How is the hydraulic conversion setup working for you?
Is there a taller head tube on the 54? Would that have not helped reduce the amount of stack on the steerer?
PostPosted: Thu Sep 26, 2013 12:57 pm
prendrefeu wrote:
Thanks.
Hydros need bedding in. They're starting to get there bit by bit. I need it get off road really. Stack is temporary. As the fork was precut, I simply fitted it. Once I've tweaked the fit it'll be cut. 55cm has a longer headtube, but the toptube is longer too. Don't want a 90 stem.
There are no new unread posts for this topic. Orro Terra/Scott Speedster Gravel 20 on C2W
Strikermk2
Fri Jun 23, 2017 12:38 am
PocketGroove View the latest post
There are no new unread posts for this topic. Orbea Terra 2017 Gravel/CX Bike
ToffieBoi
29
6298
Sat Aug 12, 2017 6:11 pm
Users browsing this forum: No registered users and 12 guests
