Big Giant TCR
aserota
by aserota
Hi all,
I'm just getting back into cycling after 5 months off the bike following a knee injury. Picked up an XL 2011 Giant TCR recently which I'm in the process of setting up and finishing off. The bike should see regular use of around 50 miles a day, 6 days a week through winter; so is more of a 'solid' build then a lightweight. Ignore pedals, steerer, stem and QR's as these are all being replaced this week, along with compact crank, bar tape and saddle (to something less garish).
Spec:
Giant TCR Advanced 1 (2011) XL Frameset
DT Swiss Tricon Wheelset
Full Ultegra 6700 Groupset
ITM Vista Carbon 130mm Stem
Shimano SPD-SL Pedals (not pictured as shoes in repair)
Powerful Pete
Location: Lima, Peru and occasionally in the Washington DC area.
by Powerful Pete
1. Interesting build.
2. How much does it weigh.
3. That is a big frame. How tall are you?
Renatita81
by Renatita81
Nice , I also have a big tcr , I had knee surgery last year , try the q rings it helps with your pedal stroke !
Valbrona
by Valbrona
I don't envy big riders and getting frames that fit, but if that is your final set-up position, or thereabouts, your Giant looks a good fit.
aserota
by aserota
Valbrona wrote:I don't envy big riders and getting frames that fit, but if that is your final set-up position, or thereabouts, your Giant looks a good fit.
It's roughly setup, i will probably throw on a 140mm stem and pull the saddle back 10mm or so. I'm not a fan of the look of the bike, but the frame in XL does'nt look ridiculous (i.e. stupidly long HT) as many others. Compared to my old 61cm Allez it's a better fit for me:
Powerful Pete wrote:2. How much does it weigh.
Not sure about weight, I would guestimate around 7.2kg with SPD-SL pedals
I'm only 6ft 2" but I have a very long torso hence long reach and lowish stack
http://s1236.photobucket.com/user/asero ... ort=3&o=10
(although I had to remove the conical spacer to get the stem low enough, not pictured)
