Cannondale Supersix Evo
KB
by KB
I already have an old S6 that I keep in Nigeria and like the ride on that, so I pulled the trigger on a S6 Evo.
D Ace 9000; Dale Hollowgram SISL cranks that I had polished with TA Squale rings; Far & Near Brakes; Deda Superleggera bars and Extralite stem; Mavic wheels with Veloflex tubs; Enve post and Spec saddle. I'm not fussed on spacers, but the size56 headtube's a bit short for me, so I got Stephen at Fibre-Lyte to knock up a spacer that's the same width as the headtube (I don't like conical spacers), and I'm pleased with the result.
Came in at 6.10 kg. No proper ride report yet as I only rode it home from my LBS with a heavy backpack.
Ebruner
by Ebruner
Nice!! If you don't mind me asking, was polishing the crankset just a personal esthetic choice, or does it serve a purpose?
Either way it looks nice.
-Eddie
majklnajt
by majklnajt
KB, I always liked your bikes. Also this one! :thumbup:
I think the spacer might look better if it had the same finish (polished black) as the frame.
KB
by KB
majklnajt - You're right. I intend having the spacer painted so that it better matches the black headtube.
Ebrunner - Having the polished cranks was just for the aesthetics.
Danza
by Danza
Are you not running a headset cover under the spacers?
rheosibal
by rheosibal
Danza wrote:Are you not running a headset cover under the spacers?
+1 Looks like your headset cover is above the spacers
KB
by KB
There's a small rubber 'spacer' on top of the headtube, then the carbon spacer, then a cover over that; see the last pic.
jbaillie
by jbaillie
Wait, what? What is the point of the big carbon spacer? It's the width of the head tube rather than the width of the steerer. The only reason to have a spacer that big is if you explicitly wanted the headset bearing cover/dust cap to sit on top of it, which doesn't make a whole lot of sense. Doesn't it move around while you're riding?
KB
by KB
jbaillie wrote:Wait, what? What is the point of the big carbon spacer? It's the width of the head tube rather than the width of the steerer. The only reason to have a spacer that big is if you explicitly wanted the headset bearing cover/dust cap to sit on top of it, which doesn't make a whole lot of sense. Doesn't it move around while you're riding?
because I don't like conical spacers. and no, it doesn't move around
53x12
by 53x12
KB wrote:because I don't like conical spacers.
Isn't that what it basically is. Just rather than being diameter of steam clamp, it is diameter of head tube? Not sure what the point is since it is still a spacer right?
KB
by KB
yes, it's a spacer (that's clear), but it doesn't reduce in diameter. What I don't like is a 'reducing' diameter spacer at the top
prendrefeu
by prendrefeu
This one will go nicely with that Winter!
BeeBee30
by BeeBee30
Very nice machine Kevin, jealous!
Ti or dye!
KB
by KB
prendrefeu wrote:This one will go nicely with that Winter!
The Winter has gone to Ed at my LBS. The replacement's an Enigma steel frame in Columbus Spirit that's fillet brazed, but it looks very similar to the Winter. It should be ready for when I'm next back in Blighty at the end of October. Looking forward to the build much more than the Dale.
