Guru Venio CX
SilentG
by SilentG
i've been lurking here for a while but decided to finally sign up.
i ride a little bit of everything and while i was doing some off season cleaning on my cross bike i took some photos. it's the only bike i have pictures of at the moment, but i'll share the others in time. and if the dirt on the tires bothers you, may i remind you that it's a cross bike. you're lucky i cleaned any of it :D
Profile by greshkov, on Flickr
Stem by greshkov, on Flickr
RearB&W by greshkov, on Flickr
KingFrontHub by greshkov, on Flickr
Front by greshkov, on Flickr
Cockpit by greshkov, on Flickr
Chainrings by greshkov, on Flickr
3Qbike by greshkov, on Flickr
build list:
Guru Venio CX Custom (derailleur hanger)-1,565g
Alpine CX Fork-708g
FSA Headset-53g
Headset Spacers-29g (4g, 9g, 15g)
Brake Hanger-18g
FSA Top Cap-8g
Top Cap Bolt-8g
Guru Seatpost Clamp w/ Brake Hook-30g
Cable Guide-4g
AL Bottle Cage Bolts-5g
SRAM Force 110BCD 175mm Crank-538g
SRAM Force 46/36T CX Chainrings-126g
Aerozine Red Crank Bolts-8g
SRAM Team Bottom Bracket-131g
SRAM Rival Shifters-329g (163g F, 166g R)
SRAM Rival Rear Derailleur-185g
SRAM Rival Band Clamp Front Derailleur-103g
SRAM PG-1070 11-28T Cassette-239g
SRAM PG-1091 Chain (broke)-256g
TRP EuroX 3k Carbon Weave Brakes-234g (117g ea.)
Shimano PDM540 Pedals-356g
FSA Wing Pro Compact 44cm Handlebar-300g
Ritchey Pro Stem 100mm-147g
Ritchey Pro Carbon Seatpost-246g
Specialized Romin Comp Cr-Mo 143mm Saddle-229g
Specialized Rib-Cage Water Bottle Cages-68g (34g ea.)
Specialized S Wrap Roubaix Bar Tape/Ends-62g, 7g (-7g)
HED Belgium C2 32H Rims-N/A
Chris King Classic Cross Hubs-N/A
DT Comp Spokes x 64-N/A
Alloy Nipples x 64-N/A
Specialized 700x34 Tubes-248g (124g ea.)
Specialized Captain CX 700x34 Tires-804g (393g, 411g)
Shimano Skewers-123g (59g F, 64g R)
this fall i'll be adding a 3T team cockpit to replace the Ritchey/FSA one I have on there now. I have the bar and stem but am waiting for QBP to have the new Ionic 0 post in stock in the diameter i need.
gravity
by gravity
wow that is one classy build!
SilentG
by SilentG
gravity wrote:wow that is one classy build!
thank you for the kind words.
