new weenie on board
spec is as from factory at present,current weight is 23lb,frame is a large,pictures will post up when i can sus out how todo it.
plans are to at least get it down to 21lbs,if possible??..new pieces lined up so far are.
fsa k force nano flat bars 110g
tioga spyder saddle. 142g.
will change seatpost to a kcnc
stem to a kcnc.
wheels not sure yet. and will go to a single ring up front.
any ideas on wheels people.
stem to a kcnc.
TrekUk wrote:I reckon you could hit under 20lb if your a proper weenie![]()
stans podium?
http://www.flickr.com/photos/99995515@N08/9523683033/" onclick="window.open(this.href);return false;
http://www.flickr.com/photos/99995515@N08/9523686087/
http://www.flickr.com/photos/99995515@N08/9526475564/
suprisingly nice looking bike! my list to strip weight would be carbon bar and stem, seatpost, lightweight seat, foam grips. stans tubeless wheelset with tubeless conversion. 1x10 conversion with lightweight cables.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
- Juanmoretime
- Administrator
RESIDENT GRUMPY OLD MAN.
so far i have removed very close to 2lbs, Have removed inner and outer chainrings front derailleur cable and shifter changed grips to kcnc's
changed the heavy bars to fsa nano flats.
also tuning the saddle as was so solid before,now has a bit of spring to it,but will proberly change to a tioga spyder or a Your air camel saddle soon.
- Similar Topics
- Replies
- Views
- Last post
- 5 Replies
- 808 Views
Last post by kidrob
Thu Nov 23, 2017 11:02 am
My weight weenie storck .....!!!
by Neckkoss » Sat Feb 03, 2018 10:27 pm » in Introduce Yourself / Gallery - Please use metric weights. - 35 Replies
- 1979 Views
Last post by TurboTommy
Mon Feb 05, 2018 7:09 pm
- 21 Replies
- 2067 Views
Last post by TobinHatesYou
Sun Nov 12, 2017 9:36 am
- 28 Replies
- 3695 Views
Last post by punk
Fri Jun 16, 2017 11:18 am
- 66 Replies
- 10083 Views
Last post by 964Cup
Tue Feb 06, 2018 10:29 pm
