Canyon Ultimate CF SLX 2013
micropox
by micropox
Just want to share my canyon. very loyal to campagnolo record 10 speed. Thanks so much FL :D
From this:
to this:
olebole
by olebole
Great build and great photos!
I really like the 10 speed touch :)
trychle
by trychle
These frames are just superb!
Could you tell me what stem that is? Canyon's have a 1 ¼ inch steerer right?
micropox
by micropox
trychle wrote:These frames are just superb!
S-works CLP Stem. Wanted a 10 or 12 deg stem. 17 deg is too much. And this is the only option available in the market.
Remove the angled 1 1/8" shim and had a machinist fabricate a 1 1/4" shim to fit canyon steerer.
bencolem
by bencolem
Nice
LouisN
by LouisN
Loooove it :thumbup: !!! Except, esthetically, the huge space between the levers and the bars at the bottom
Louis :)
Nelus
by Nelus
First of all nice bike. Looked at your stem. But isn't there something of the hook??? It looks like your top spacer isn't in contact with your stem as I think it should be. Or am I seeing it wrong ? Normally I couldn't mount a stem like that. I could be wrong
Everything is all right in the end, so if everything is not allright it's not the end
micropox
by micropox
Nelus wrote:First of all nice bike. Looked at your stem. But isn't there something of the hook??? It looks like your top spacer isn't in contact with your stem as I think it should be. Or am I seeing it wrong ? Normally I couldn't mount a stem like that. I could be wrong
Hi Nelus,
The silver color in between the spacer and the stem is not the steerer tube. It's part of the shim that i use to fit s-works stem. So no problem with the stem mounting....
mpower
by mpower
Size XS?
CaptainP
by CaptainP
Looks really damn great!
drainyoo
by drainyoo
Perfect. Really really nice build.
paradawt
by paradawt
You do a great job.
Congrats.
Cannondale Supersix '10
Spessartpantani
by Spessartpantani
The Bike looks perfect. :up:
Can you tell us some things about framesize and your measurement (Inseam and Saddelheight center bottombracket to top of Saddle would be nice). your position looks perfect too....
thanks a lot
micropox
by micropox
Thanks guys for the compliments :D
@mpower yes, it's XS
@Spessartpantani Thanks... Frame is size XS. Seattube length 47cm, Eff toptube 52.9cm, headtube length 13cm.
Don't know my inseam but my saddle height is 72cm.
aftereffector
by aftereffector
I think that's the first Campy-equipped Canyon I've seen. It looks very good! Does Campy make a black anodized chainring for Record 10-speed?
