It is currently Fri Dec 15, 2017 4:06 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page 1 2 3 Next
 Post subject: 2013 Cervelo R5
PostPosted: Tue Aug 06, 2013 5:32 am
Had to retire my 2011 R5 (see here: viewtopic.php?f=10&t=80217&p=702751#p702751 ) and replaced it with a 2013 R5 (warranty replacement for my FOURTH cracked R-series frame). Again, outstanding customer service from Cervelo.
Here is the obligatory Weight Weenies build list:
- Cervelo 2013 R5 54cm, Cervelo SL fork
- Campagnolo Super Record gruppo (175mm crank, 53-39 chainrings, 12-27 SR cass)
- Ritchey WCS Carbon 2-bolt seatpost
- Ritchey WCS 4-axis carbon 110mm
- Easton EC90 SLX3 46cm
- Prologo Scratch
- CaneCreek headset
- Reynolds Forty Six wheels
- Vittoria Open Corsa CX 25c w/Michelin latex tubes
- Arundel Mandible cages
- Time RXS Ulteam Titan
Full build weight 6.5Kg…..the frame weight is 760 grams (65 grams lighter then 2011 R5), and the uncut fork weight is 315 grams (15 grams lighter then 2011 R5).
The matte paint is actually a dark gray, not black, coupled with matte silver and red highlights.
Enjoy!
EM3
______________
 Post subject: Re: 2013 Cervelo R5
PostPosted: Tue Aug 06, 2013 6:20 am
That just looks 'right'.
I personally prefer the all black Campagnolo Super Record to the current red accents.
I often hear about brands having 'good customer service' when they replace a broken frame. To me, good customer service would be putting a product out there that doesn't break so often in the first place, and in this respect, Cervelo do seem to have to offer 'good customer service' too often for my liking!
It is light for sure, but I do wonder if they have pushed the boundaries just a bit too far.
PostPosted: Tue Aug 06, 2013 7:16 am
3T LTD or Team and it would be perfect. :)
PostPosted: Tue Aug 06, 2013 7:29 am
Nice bike
PostPosted: Tue Aug 06, 2013 8:28 am
I wonder if you could detail the failure modes of your past frames? I think all of us with R3/SL/5 would be interested in looking out for early signs.
Thanks,
 Post subject:
PostPosted: Tue Aug 06, 2013 8:58 am
I was going to say something about your bar and seat tilt.......
Nice ride!
Sent from my SGH-I747M using Tapatalk 4
My RCA
PostPosted: Tue Aug 06, 2013 9:19 am
Thanks,
This. I scanned your last thread but couldn't see any mention of the failure(s) in there either?
My R5
PostPosted: Tue Aug 06, 2013 9:37 am
Tinker, Taylor, Tart
So that's FOUR cracked Cervélos you've had?? Ouch...
PostPosted: Tue Aug 06, 2013 2:28 pm
That frame is spectacular! Very nice and sensible build.
Solarider.....Good customer service, is good SERVICE to the CUSTOMER.....manufacturing and quality control is in no way, shape or form related to customer service. Cervelo indeed has fantastic customer service from what I have heard; however, their quality control may be a bit lacking.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Tue Aug 06, 2013 2:38 pm
Look very nice. I like it. Just would have expected the build to be a little lighter with an R5 build.
PostPosted: Tue Aug 06, 2013 3:21 pm
beautiful bike.
PostPosted: Tue Aug 06, 2013 3:24 pm
great build !
2017 De Rosa King Xs
2017 Colnago C60
2017 Colnago Concept
PostPosted: Tue Aug 06, 2013 3:29 pm
Thanks,
..first three frame failures were the dreaded and all too familiar BB shell crack, all on pre-2011 R-Series frames (pre-BBRight). This defect has been well documented on the Cervelo forum and Cervelo has been very proactive about replacing frames with said defect. The 2011 and newer R-series frames with BBRight have addressed the BB cracking issues...I have not read or heard of any BB failures since the adoption of BBRight.
My last failure (fourth frame) was a hairline crack that formed at the topside tip of the seatstay and extended to the upper edge of the driveside dropout. There is no known pattern of this defect. I have seen a couple of reports on broken dropouts, but those are clearly due to overclamping skewers as the failures have been on the lower part and face of the dropout, not on the upper edge.
As I indicated, Cervelo customer service has been amazing and always quickly supplied me with a replacement frame. I really don't mind as the frame failures have given me an excuse to tear down and rebuild my bike at least once a year (I have averaged one replacement frame per year for the last four years).
EM3
______________
PostPosted: Wed Aug 07, 2013 9:54 am
I don't mean to detract from what is a lovely bike (and it is a lovely bike), but 4 frame failures? And you call that good customer service?
What if one of those frame failures happened at speed hairing down a descent? I just can't accept that good customer service is to produce frames with that failure rate. And the fact that they replace them so readily speaks volumes about how often it happens.
It is admirable that they stand by their product and help their customers when it ll goes wrong, but after 4 failures I personally would have lost confidence in the brand by now.
PostPosted: Wed Aug 07, 2013 2:55 pm
You are right, you are indeed detracting from what is simply a post on the "Introduce Yourself Gallery" picture thread, but if you insist, I'll play. Actually, I would point you to
btompkins0112 response above:
You are correct that four failures for my N=1 might be excessive, and I do agree that Cervelo might have a quality control issue on their hands. But at the same time, I have not seen proof that carbon frames from other manufacturers are breaking at a lesser rate (as a proportion of the # of frames they produce). My point is that all frames from all manufacturers are prone to failing, but we simply do not know at what rate across manufactures. In my over 30 years of cycling (10 as a pro shop wrench) I have seen and experienced my fair share of failures, across MANY manufacturers, which probably explains why I am not phased by the Cervelo failures I have experienced.
EM3
______________
There are no new unread posts for this topic. cd super six evo himod 2013 size 52
reedplayer
16
3608
Sun Jul 23, 2017 10:13 pm
dolophonic View the latest post
There are no new unread posts for this topic. Fork for 2013 supersix evo 1.125->1.25 tapered
vejnemojnen
Fri Jul 07, 2017 1:13 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. 2015 Ridley Helium SL new build & 2013 winter Helium SL
Monkeychunki
15
2955
Sun Feb 05, 2017 9:32 pm
Monkeychunki View the latest post
There are no new unread posts for this topic. Cervelo S2 DA Di2
Beancouter
20
3995
Wed Jul 26, 2017 4:31 pm
mr.wulf View the latest post
Users browsing this forum: pikles and 8 guests
