It is currently Tue Jan 16, 2018 8:40 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Mon Aug 05, 2013 9:02 am
Here is my Canyon Ultimate CF SLX SL. It is basically stock, except:
Wheels : Enve 25 tubular (1000g the pair)
Tyres : Vittoria Corsa Evo (240g each)
Bars : Zipp SL2 (202g)
Seatpost : Engage Revit (cut to 300mm) (128g)
Saddle : My old trusty Selle Italia Carbonio Flow (132g)
Chain : KMC X10SL
Rings : Praxis Works Standard 53/39 (128g pair)
Bar tape : Pinarello (30g)
Skewers : Carbonsports Lightweight (34g pair)
Pedals : Speedplay X1 (155g)
Cages : Tune (38g pair)
All in weight is around 5.6kg. Ordered in October last year. Delivered in April (which I understand was pretty swift compared to most people's experience!). I apologise in advance for the small pictures, so don't beat me up about it. I'm sure there must be a better way of getting a 160kb picture to look a decent size on WW, but I don't know how. I know some people just put a link to a Flickr page, but I can't access Flickr from my work PC.
Cheers,
 Post subject: Re: Canyon SLX
PostPosted: Mon Aug 05, 2013 11:57 am
did you have a chance to weigh frame / fork ?
what frame size is this ?
txs
PostPosted: Mon Aug 05, 2013 2:00 pm
I've weighed the fork because I took it off to cut the steerer down a bit. Pre-cutting it was 325 grams, a bit heavier than I was expecting. I've not weighed the frame, but based on the kit it has on it and the final overall weight, I'd be surprised if it was more than 800g.
It is a small, which I think is a 53. I am just over 5'9. I did consider medium, but I'm glad I didn't go for that, as it would have been too big for me.
PostPosted: Mon Aug 05, 2013 7:45 pm
txs
PostPosted: Mon Aug 05, 2013 8:23 pm
What are the ride impressions? How does it compare to other bikes you've had?
London2Paris24 2014 Fundraising for Scope UK
Facebook Page for more information and updates!
PostPosted: Tue Aug 06, 2013 10:30 am
This is only my third road bike, so I can compare it to a Boardman Pro Carbon and a Storck Fascenario 0.7
Ride : The Canyon rides more smoothly than either the Storck or the Boardman (much more so than the latter). Although I changed the stock Canyon post for the Engage, I couldn't tell any difference, they both do a good job of ironing out poor road surface at the rear. The front isn't quite as smooth as the rear, but it certainly isn't harsh. It is on a par with the Storck I'd say. The Enve wheels contribute to the ride as well, as they are noticeably smoother than the stock Mavic R-Sys or my Zipp 303s.
Handling : I was initially a bit underwhelmed by the handling, which I first tried out on some really big descents in Southern Spain. It felt quite twitchy and I struggled to get my lines right. It gave me a lot less confidence than the Storck, which I instantly felt at one with. Having put a significant amount of miles in since, I have adapted and think that the 'twitchiness' is largely down to the 100mm stem on the Canyon (the Storck is a 110). This is something I've just got used to, and I'm now really enjoying the way it handles. It is super stable (you don't have any fear taking your hands off the bars, even at high speed), and really sticks to the road. I'd still say the Storck is marginally better (it manages to be both more exciting, and more confidence inspiring), but there's not much in it, and the Canyon is much better than the Boardman.
Power Transfer : The Canyon is a stiff bike, particularly at the front end. BB power transfer is very good, although perhaps a touch less immediate than the Storck. Up front, it is stiffer than the Storck. Acceleration is immediate, and sprinting is very good, even with the Enve wheels. The front end is stiffened further by the Zipp SL2 bars, which are quite a bit stiffer than the stock Ritchey Evo Curve. The Boardman is noticeably more flexy than either German bike.
Climbing : Any 5.6kg bike should climb like a goat, and the Canyon certainly does. The Enve wheels are a big help here. I have some Zipp 303 rims on Tune hubs (1120g the pair), and the Enve's are noticeably better once the road goes over 6%. The stiff front end makes a difference as well, as out of the saddle hauling on the bars produces no movement at all. The Storck is a slightly lighter bike, but I don't think I could tell them apart from a climbing perspective.
Finish : The finish on the Canyon is ok. I'm not a massive fan of the raw carbon look (although I know it saves weight), and you can certainly see quite a few blemishes / joins in the finish without looking too hard. The Storck is much more appealingly finished IMO, and has more 'Wow' factor. My custom painted Boardman has a better looking finish (probably only IMO) than either German bike, but the custom paint job did add 120g to the frame and fork weight!
Kit : The new SRAM Red stuff is very good, but I have only ridden SRAM on road bikes so I have no comparison. The chainset is better (better looking and stiffer) than 2011 Red. I've changed the stock rings for Praxis, which gives a very slight drop in stiffness, but no noticeable drop in shift quality.
Wheels : My Enve 25s on Tune hubs (built by Strada Wheels) are fantastic. Brilliant climbers, lovely ride, great rolling, great braking (no pulsing at all), lovely finish and they are still true after 3000 miles of riding on UK roads. My Zipp 303s are marginally faster (unless the ride is really hilly), but I'd happily trade that for the other benefits.
Overall : The Canyon is a great bike. It is difficult to see what would come close to it at this price point. To put it in perspective, it is probably around £1,000 more than the Boardman, but is in a completely different league (and I really like my Boardman). The Storck is marginally better (it just has more 'Wow' factor) but there is very little in it, and the Canyon is at least £5,000 less expensive. The other think with the Canyon compared to the Storck is that I just don't worry about it like I did the Storck. The Storck had so much 'boutique' stuff on it, that any creak or cracking noise had me fretting. It is probably just perception, but the Canyon just feels more 'robust', despite only being around 200g heavier.
PostPosted: Tue Aug 06, 2013 11:56 am
Love it mate.
Nice job. Congratulations!
Cannondale Supersix '10
PostPosted: Tue Aug 06, 2013 5:03 pm
Hi mate
Nice ride! Can I ask how you got the oval saddle rails to work on the Engage Revit post?
Cheers
Scott CR1SL 6.25Kg | CAAD10 6.56Kg
PostPosted: Tue Aug 06, 2013 8:09 pm
Wow, thanks for the report! Sounds awesome - wanna try it just to compare with the Ultimate CF but sounds similar in terms of characteristics. Germania, here I maybe come at some point! :D
PostPosted: Wed Aug 07, 2013 9:06 am
ross wrote:
Hi mate
Cheers
Hi. I didn't have any issues, I've run the post with 4 different saddles, all with oval rails (a Phoenix, a Romin, a Toupe and the Carbonio Flow) and they all seemed to work fine. Am I missing something here - are they not supposed to be compatible?
PostPosted: Wed Aug 07, 2013 10:18 am
Yeah I have the same post on my new Scott , the rails on my SLR Kit Carbinio wouldn't fit the lower cradle or upper yolks without modification
This pic shows a Thomson Masterpiece lower cradle, but shows the problem with the upper yolks. With the Engage cradle it wouldn't fit straight at all
In the end I bought an SLR TT with round rails. I emailed Engage about getting replacement upper yolks but they never replied.
PostPosted: Wed Aug 07, 2013 2:21 pm
Hmm, you have me worried now! It all looks ok to me, there are no gaps and it appears straight. It certainly fits in the lower yolk without issue. I've attached a (sorry, bit rubbish) photo - please shout up if it looks like there's a problem!
PostPosted: Wed Aug 07, 2013 3:50 pm
That looks (blurrily) ok to me
PostPosted: Wed Aug 07, 2013 4:50 pm
Cheers!
PostPosted: Tue Jun 23, 2015 9:32 pm
Updated with new stuff...
Groupset : SRAM Red 22 Compact (finally capitulated after a sorry week running out of gears in the Sierra Nevada mountains)
Wheelset : Lightweight Meilenstein Obermayer with Ceramicspeed bearings (945g)
Tyres : Fr, Veloflex Sprinter; rear, Veloflex Criterium (227g fr, 254g rear)
Saddle : Selle San Marco Aspide Superleggera (105g)
Stem : Ritchey Superlogic Carbon C260 (with a shock result, lower than advertised at 108g)
Bars : Schmolke Full Over (144g, and awesomely stiff - fantastic purchase)
Cables : Yokozuna Reaction (utterly butterly)
Skewers : Tune AC14
Can't see much else I will change now. The Lightweights (purchased with insurance money following nasty commuting accident) are every bit as impressive as the reviews. Light, stiff, comfortable and er, a bit aerodynamic (can't have everything I guess!). Super smooth with the Ceramicspeed bearing option (a horrendously priced upgrade, but as it was insurance money, it didn't feel quite like it was mine!)
The Superlogic stem is maybe a tiny bit oversized for what is a relatively delicate looking frame, however it is functionally the best stem I've tried. The cockpit with the Schmolke bars just doesn't move, even when down in the drops, but remains decently comfortable. Strangely enough the stem looks more at home when my Garmin 1000 is mounted, as that unit tends to dwarf slimmer stems.
The Schmolke bar is a lovely thing, and Schmolke are super helpful. With the good £ to euro exchange rate, it wasn't even that expensive (compared to other flagship bars). 144g, and it is much stiffer in the drops than the Zipp bars I ran previously (which are marketed as 'sprinter' bars). The greater diameter (it only tapers to 27mm from the clamping zone, rather than 24mm) feels really good to hold. The photo (hmm, sorry about this, David Bailey I'm not) doesn't really do them justice as it does make them look a lot bulkier than they actually are. The other weight weenie benefit is that they need special shifter clamps because of the increased diameter - these are supplied and they are quite a bit lighter than the standard clamps you get with your groupset.
The veloflex tyres are nice and supple. Not noticeably better than the Vittoria Corsa SCs I had on previously (albeit a bit lighter), but the colour on the sidewall is nicer (the SCs are a bit 'yellow', rather than 'tan').
The skewers are a bit heavier than the Obeymayer skewers that come with the wheels, but having had wheel slip issues with Lightweight skewers in the past, I feel happy to give up a few grams for the greater clamping force.
I do have a Schmolke TLO setback post on order which will save 35g on the Engage Revit post, but this may fit geometry wise better with my Schmolke Namur as it only provides 10mm of setback.
There are no new unread posts for this topic. Internal routing on Canyon Gran Canyon?
in MTB
Zak
Sat May 13, 2017 7:32 pm
Zak View the latest post
There are no new unread posts for this topic. Attachment(s) Road Stuff on my MTB
in MTB
northy185
Wed Jan 25, 2017 10:21 am
ooo View the latest post
There are no new unread posts for this topic. Canyon Grand Canyon AL SLX
wjs
Mon Dec 25, 2017 2:30 pm
wjs View the latest post
There are no new unread posts for this topic. trek madone 9 updated
markyboy
12
2111
Thu Aug 31, 2017 5:03 am
markyboy View the latest post
There are no new unread posts for this topic. Focus Izalco Max -- When will it be updated?
octave
Thu Jan 11, 2018 11:34 pm
octave View the latest post
Users browsing this forum: AZR3, blantonator, emorydptt, reebzor and 12 guests
cron
