FL's NEILPRYDE BURA SL/ AX/ DI2/ 5.32kg
farm_lim
by farm_lim
nickl wrote:Can I ask how tall you are?
170cm, 74cm inseam
you cant buy fitness, but you can buy advantage.
liketoride
by liketoride
what is the size of the handlebar? 165 is a good wt. how much wt was taken off in the sanding?
farm_lim
by farm_lim
@liketoride, size 42. 4g off. actually weight loss wasnt the primary reason, just wanted to clean out the tape residue and scratches. any g sanded off was a bonus.
pic from june 2010 when i got the bars.
farm_lim
by farm_lim
wired the frame already.
how i mounted the internal battery.
seatpost inserted, with a bit of bartape. only 3g of material added.
liketoride
by liketoride
wow i did not know that bar was that light. i just looked on the listings page and i must have missed that when i was looking for my bar.
mdeth1313
by mdeth1313
mnmasotto wrote:I was going to replace my Parlee Z5SL small/tall with this frame because i was under the impression it weighted less. My 2012 Z5SL small/tall frame weights exactly 770 grams and the fork 300 grams even. None the less, its a very pretty frame. I like the paint scheme.
FL's is the electronic model. My frame is the mechanical and it comes in at 768 frame and 300 fork (cut)
Speedplay is the devil!
farm_lim
by farm_lim
crankset for this build.
with extralite rings and pf30 bb + spacers.
installing the bb with my cheap press. works the same.
PSM
by PSM
Nice build!
TrekUk
by TrekUk
This is going to look great! im glad you took all the 3T logos off they look cheap with logos on, great job with them!
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
farm_lim
by farm_lim
here's the completed build.
im sure many will prefer more shallow wheels. i actually have an unbranded 50mm lying around and an unbranded 20mm project. will post when finished. but as with all my previous builds, i have always prefered at least a 50mm as main wheels.
buildlist
frame: neilpryde bura sl, electronic-ready, size S
fork: neilpryde bura sl tapered 1 1/8- 1 1/4
handlebar: *3T ergosum LTD , debadged
stem: uno 6 ul 100mm, debadged
saddle: frm blackhole
seatpost: *6kcycles ul 27.2
seatclamp: neilpryde stock 31.8 clamp
shift kit: shimano 9070 upgrade kit, internal battery
crankset: fsa k-force light bb30 110bcd w/ fsa pf30 bb
chainrings: extralite octaramp rc2 50/34
cassette: recon aluminum nickel-black 11-28
pedals: *speedplay zero SS with ti spindles
brakes: *trp 960 calipers/ ice-stop carbon pads
brake cables: *ota cnc housing/liners with x-cross teflon-coated inner cables
qr skewers: *unbranded ti skewers w/ alu/carbon levers
wheelset: zipp 404 11sp tubular
tires: schwalbe ultremo HT
*parts from previous builds
actual weight with this setup:5.58kg
farm_lim
by farm_lim
more pics:
driveside
front
cable and tapework
drivetrain
stoppers
non-drive side
thanks for viewing!
MarkGiardini
by MarkGiardini
I love it.
KWalker wrote:chill out perv dogs, homegirl is still only 17.
prendrefeu
by prendrefeu
That looks gorgeous!! Beautiful build there!
btompkins0112
by btompkins0112
That's really nice! Looks great! The brakes throw it off a bit for me since anodized red doesn't really tie-in that well, but that is being ULTRA nitpicky. Fantastic!!
Monkeyboy3333
by Monkeyboy3333
nicely balanced, very well done and great weight
