FL's NEILPRYDE BURA SL/ AX/ DI2/ 5.32kg
farm_lim
by farm_lim
sold the previous ride here on WW and now building up this one.
initially eyed this one but my size had a tall seattube c-t for my liking so looked at other brands. got confirmation that the actual c-t measurement was lower than in the geometry. thanks mdeth1313 for verifying!
this will be a weight concious build but still sturdy enough to ride anywhere.
hope youll like it.
NEILPRYDE BURA SL size S, DI2 frameset
modernist graphics
[img width=800 height=531]http://i614.photobucket.com/albums/tt225/farm_lim_bucket/DSC_0025_zps5e368f93.jpg[/img]
toptube braces
if there ever is something to nitpick, would have preferred if the rear brake routing was fully internal. this is a novel way to do, bbq the headtube and exit outside but it was not a dealbreaker for me.
stays
box chainstays
full carbon cups, fd hanger, pf30 bb shellImage
and not bad weight.
frame at 790g with rd hanger.
uncut fork at 333g
you cant buy fitness, but you can buy advantage.
farm_lim
by farm_lim
will recycle some leftover parts from the previous build, resurrect some stashed parts and will get new ones to match the build.
frm blackhole saddle, semi-gloss 3k
recon 11sp cnc cassette, black nickel coating
kmc x11 sl 11sp chain, silver
farm_lim
by farm_lim
had this ergosum ltd handlebar since my kuota kom build in 2008.
already battrlescarred, lots of scratches and tape residue.
worked on it toremove the thick top coat layer and recoated after.
exhausts on, and fire away!
just painted the exposed part
added another coat so i can keep it on center.
not bad at 165g.
Monkeyboy3333
by Monkeyboy3333
this is gonna be sawweeet
farm_lim
by farm_lim
thanks!
as with some of the stems on my previous builds, debadged an uno 6 sl stem to match the clean look of the bars. left a bit of red and white for accents.
MarkGiardini
by MarkGiardini
Interested in following this build...really diggin these NPs
KWalker wrote:chill out perv dogs, homegirl is still only 17.
mnmasotto
by mnmasotto
I was going to replace my Parlee Z5SL small/tall with this frame because i was under the impression it weighted less. My 2012 Z5SL small/tall frame weights exactly 770 grams and the fork 300 grams even. None the less, its a very pretty frame. I like the paint scheme.
dereksmalls
by dereksmalls
You could dremel some off that stem still onthe bar clamps by the looks of things! How much does it weigh?
farm_lim
by farm_lim
dereksmalls wrote:You could dremel some off that stem still onthe bar clamps by the looks of things! How much does it weigh?
106g with the stock steel bolts. havent weighed with ti bolts yet which i intend to. pics on the web show it at 88-92g with ti bolts.
that should be fine with me. id prefer the the security, even if just psycholigical, and the 2-3g of material staying on the clamp than worrying about coloring the exposed part after.
prendrefeu
by prendrefeu
Ti bolts will bring it to ~100. There's no way that changing six small bolts from Steel to Ti will result in a loss of more than 10g.
farm_lim
by farm_lim
changing bolts should be around 10g.
viewtopic.php?f=1&t=110326
the pic i meant the uno website. sould be a 90 stem.
http://kalloyuno.com/products/grade3.0-2-3.html
anyway, will weigh when i have the bolts.
prendrefeu
by prendrefeu
Yeah, I know. I too have a 90mm stem (see my build).
Like I stated: There's no way that changing six small bolts from Steel to Ti will result in a loss of more than 10g.
If you're at 106 with steel, at most you're looking at 96g. Not the "88-92g" you're stating. If you did, it would be shocking.
SWijland
by SWijland
Might I ask what you used to debagde the stem? I know Acetone does the trick, but your stuff seems to stick much better.
farm_lim
by farm_lim
@pren, was replying to "Ti bolts will bring it to ~100".
@SWijland, paint remover.
nickl
by nickl
farm_lim wrote:sold the previous ride here on WW and now building up this one.
hope youll like it.
I really like this frame, but I'm a bit confused by the geometry too. Can I ask how tall you are?
I'm 171 cm tall, previously on a small DeRosa Merak Evo with 53.5 cm TT (until it was destroyed by a car).
The Neil Pryde fit tool keeps putting me on the M frame. I've ridden a 54.5 cm TT before and wasn't too comfortable. I might make it work, but... (Yes, I know about stack & reach).
