My Venge with Red 11-Speed
kakanpolen2
by kakanpolen2
My Venge Pro with Zipp 404, Vuka Sprint and Sram Red 11-speed.
Better pictures are coming as soon as the Red Cranks are mounted.
Imaking20
by Imaking20
You are a giant.
Current:
T2
Retired:
kakanpolen2
by kakanpolen2
Imaking20 wrote:You are a giant.
No only 188cm tall :)
DRAGON60
by DRAGON60
If it is a XL frame----it looks very good---it seems bike manufacturers are achieving good visual balance with larger frames now. A few years ago with smaller tubes a 60 would look all out of proportion----now because of larger tubes etc. the sweet spot is around 58 or more rather than 56cm,
kakanpolen2
by kakanpolen2
DRAGON60 wrote:If it is a XL frame----it looks very good---it seems bike manufacturers are achieving good visual balance with larger frames now. A few years ago with smaller tubes a 60 would look all out of proportion----now because of larger tubes etc. the sweet spot is around 58 or more rather than 56cm,
Yes its a XL/58 frame... but I think 54-56 still is the best looking size!
boots2000
by boots2000
Ridden it yet? Feel any different than the 10 speed Red?
Does front der really cover all 11 gears?
What crank/ring setup is that? Does not look like sram?
kakanpolen2
by kakanpolen2
Yes ive ridden it. And its super... Shifting is Seven faster than 10speed. Yes u van use Alla gears... Its great! In the pic tis a fsa crankset. Now theres a red 53/39.
