Planet X build - WIP
deanh
by deanh
This is my Planet X sl pro carbon build with easton ec90 slx forks.
Both brakes on and set up.
Theres a FSA team issue carbon crankset in the post.
t0ph0id
by t0ph0id
Not too keen on the blue and red together.
andy12
by andy12
t0ph0id
You complain about blue and red and you have white pedals ?
deanh
by deanh
To be honest the blue and red wasn't intentional and won't last very long (when funds allow) they will be changed for black or red bits.
t0ph0id
by t0ph0id
andy12 wrote:t0ph0id
Not complaining, just pointing out that I personally wasn't keen on it.
The white pedals on mine match with the white in the paint, the saddle and the bar tape.
Deanh - No offence meant, just not to my taste.
deanh
by deanh
None taken. 2nd cage ordered & wrapping the bars tonight.
No idea on expected weight, hopefully be sub 8kg.
astranoc
by astranoc
Yeah I am not that keen on the red fork either. If the blue wasn't there you could work with the red color to spice up the bike. Best of luck with the build, I have this frame too and I ve done 14k knack without any issues.
deanh
by deanh
She is finally finished. Bottom bracket turned up today so got it fitted and got the drivetrain finished off.
I dont have a finished weight for it yet but it is considerably lighter than the cube. Feels it on the quick ride around the block too.
TrekUk
by TrekUk
take the blue easton decals off the rims.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
deanh
by deanh
They will be coming off. I want to get rid of the bmc branding on the forks but I don't know what to do other than repainting them. Borrowing some scales tomorrow so ill get her weighed.
deanh
by deanh
I decided to sand the forks down to get rid of the bmc branding.
How they started out
One leg done
Ran out of 200 grit paper so threw the forks back on until tomorrow.
Looks so much better already. Just need to finish the other leg, wet sand and lacquer.
btompkins0112
by btompkins0112
Yes, that'll be nice with a bit of clear on....I like the progression!
Sent from my iPhone using Tapatalk 2
deanh
by deanh
Lacquered, ive left some red near the top on the inside as my fingers feel like they're about ready to fall off & you can't see it with the wheel on.
totoboa
by totoboa
Nice !!!
First triple I have seen on here.
Weighed yet ???
:beerchug:
DRAGON60
by DRAGON60
Could you give me a rundown on the gearing numbers-----crank and cassete-----a triple setup might make sense where I live.
Thanks
