It is currently Mon Jan 22, 2018 5:25 am
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: Where to start?
PostPosted: Mon Jun 03, 2013 8:27 pm
I've got this...
Tiagra everything
Got some nice wheels for it and a KCNC seatpost. Will be getting a Fizik carbon saddle
What next to help shed weight / upgrade?
 Post subject: Re: Where to start?
PostPosted: Mon Jun 03, 2013 10:42 pm
My order of what to reduce weight in:
Wheels, Tires, Tubes.
Cranks, Handlebar, Stem, Seatpost.
Calipers, Pedals, Saddle.
Group (When upgrading) Shifters, Derailleurs, Chain, Cassette.
Wheels first as rotational weight is most important and you can save 100g with a proper tube selection alone.
Cranks (Rotational weight)
Handlebar/Stem (Front end handling becomes lighter)
Seatpost/Calipers (Dead weight)
Pedals (rotational)
Saddle (dead weight)
Group (As a whole will be lighter as you upgrade).
carbonLORD.com
PostPosted: Tue Jun 04, 2013 4:06 am
As above plus some smaller bits and pieces, some specific to Cannondale:
1. If your ride came with the nice aluminum "Cannondale" bar end plugs ditch them for plastic -> ~20g
2. Swap out the heavy FSA fork expander for the new "Evo" one -> ~35g
3. Swap out the heavy cone spacer for a ControlTech -> ~30g
4. Swap the stock seatpost collar for something lighter - lots of choices here -> ~15g
All told roughly 100g with those four simple changes.
2012 SuperSix - 6.30kg
PostPosted: Tue Jun 04, 2013 6:56 am
That's really helpful, thanks guys
Can't wait to start now :D
PostPosted: Tue Jun 04, 2013 1:38 pm
All very good points but minimal savings in the grand scheme of things. For me I'd be looking at tyres, stem, bars and group for the largest savings, providing your new wheels are decent weight.
EDIT: Thinking about it, the stem and bars on the Caad 9 aren't too heavy as far as alu parts go. But tyres and group (particularly cranks, as mentioned previously) will definitely give you big savings.
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Tue Jun 04, 2013 2:52 pm
Lightweight tubes are the cheapest part swap to save weight, by far. Find some thin butyl tubes like specialized turbos, etc. Those tires probably have wire beads. don't go for the lightest replacement, I'm personally a fan of gp4000s as an excellent all-rounder in the 200ish gram category. Saddle: lightest version of what best works for you. Maybe a Thomson Masterpiece post. Then you get some dwindling returns...
Sent from my EVO using Tapatalk 4 Beta
PostPosted: Tue Jun 04, 2013 6:15 pm
Do not need to quote the post above
Already on Continental GP folding tyres with 140g KCNC seatpost and 13g seatpost clamp
Regarding the cranks...
I was looking at Ultegra compact, but its only a 30g saving :shock:
was expecting more tbh
PostPosted: Wed Jun 05, 2013 5:09 pm
Ordered some supersonic inner tubes. That's a 100g saving! epic :)
PostPosted: Thu Jun 06, 2013 12:13 am
What bottom bracket standard does this bike has? If BSA, I guess there many cranksets out there that would safe more than 30g ;) Other than that, light wheels and tubes/tires are a good start...
PostPosted: Thu Jun 06, 2013 6:36 am
Its a BB30 frame but has an adapter to fit HT2
PostPosted: Thu Jun 06, 2013 10:12 am
so with BB30 a Connondale crank would be perfect! ;)
PostPosted: Tue Jun 11, 2013 12:18 am
Absolutely. Call my list Phase 2...
And I agree with the stock stem / bars. That C2 stem is pretty decent.
@alexh - how are those quick releases working out?
There are no new unread posts for this topic. Canondale Bad Boy - Where do I start?
pletharoe
Sun Dec 10, 2017 12:58 pm
pletharoe View the latest post
There are no new unread posts for this topic. Going to start biking again, Tarmac?
WiryMike
28
2686
Fri Feb 17, 2017 6:17 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. How much base ? When to start structured training?
in Training
AJS914
Fri Jun 30, 2017 8:02 am
AJS914 View the latest post
Users browsing this forum: wheelbuilder and 15 guests
