It is currently Thu Jun 29, 2017 3:25 am
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Jul 27, 2013 11:46 pm
My essential thought is that the frame is at least one size too big for you. What height are you?
Not everything that counts can be counted. Not everything that can be counted counts.
PostPosted: Sun Jul 28, 2013 4:31 am
A S5 probably is more aero than that setup, more useful, too
PostPosted: Sun Jul 28, 2013 9:52 am
I am 5'9. That is a size M bike.
I can understand why you say it, but I my fitter and I went back on forth, both could have been made to work, but in the end decided (correctly, I still think), that a size S would have too much seat to bar drop for my relatively inflexible back.
PostPosted: Sun Jul 28, 2013 9:54 am
Really really doubt that
PostPosted: Sun Jul 28, 2013 3:27 pm
mattjevans wrote:
A few people have said that (about handling) and not sure why people are making that assumption?
Time trial bikes generally have a slacker head tube angle (among other things) since they're intended to be ridden fast in a straight line with more weight over the front wheel. That being said, if you like it then that's all that matters.
PostPosted: Sun Jul 28, 2013 5:15 pm
its not assumptions, its bloody common knowledge TT bikes are for striaght lines, not the twist undulating roads we ride with road bikes, you bike is not fit for purpose.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Sun Jul 28, 2013 5:46 pm
Well the seat tube angle, head tube angle, fork rake and wheel base are the most important. Then it will be stiff as hell probably.
Speacialized Project Blue
Trek Tri-bike
PostPosted: Sun Jul 28, 2013 6:25 pm
1 Maybe your "common knowledge" should do a geometry comparison between a SC 9 Medium and a Madone 7 H1 54cm. Then "common knowledge" might actually find that a 10mm shorter stem (i.e. 100mm vs 110mm, what a radical notion) and a 10mm spacer under said stem are the primary fit difference.
2 You might ride twistY undulating roads but I don't. So what you're really saying is my bike isn't fit for your purpose. So lucky it isnt your bike...
You seem to be misunderstanding that what I WANTED was a drop bar bike for time trial style riding. i.e.. By myself, on flatish straight roads at relatively high speeds. I physically can't ride aero bars any more or I would have left well enough alone.
PostPosted: Sun Jul 28, 2013 6:36 pm
ST angle 74. Same as Madone 54
Head tube angle 72.5 Half a degree slacker than a Madone 54
Wheelbase 985 Same as Madone 54
Fork offset 45mm Same as Madone 54
Stiff as hell. HELL YES!!
PostPosted: Sun Jul 28, 2013 6:38 pm
No matter what you say you will get ripped by every one on here, if your needs were so specific then you need an in depth bike fit, not just modify what you think is good for you, clearly not all bike shops give good advise, which is very clear in this case. its not just a matter of stem length, and you would be absolutely crackers to compare a TT bike to a 7s, or any road bike for that matter!!
not only will you get a chuckle from every reader on here, but im sure if you listen carefully you will hear a little chuckle from every rider that passes you on the road.
bike not fit for purpose, end of, you dont just chuck road bars on a TT bike and treat it like a road bike.
EDIT - surley if you have a fit issue or a medical issue preventing you from a proper road bike, then a bike "STIFF AS HELL" is the worst possible bike for you?
PostPosted: Sun Jul 28, 2013 6:42 pm
Of course the primary fit difference is the seat tube angle. Just don’t get to defensive, getting critique is part of going out there. Maybe you’ll prove them all wrong and it turns out that this was the best idea since handlebar located shifters;).
Trek Tri-bike
PostPosted: Sun Jul 28, 2013 6:44 pm
Im also very confused as to who is supplying your geometry figures as I feel your very confused by what your posting about and what your planning on riding.
from trek themselves, figures in all departments arent even close to each other.....
SC - http://www.trekbikes.com/ca/en/bikes/road/triathlon/speed_concept_9_series/speed_concept_9_9/#/ca/en/model/fit_sizing?url=ca/en/bikes/road/triathlon/speed_concept_9_series/speed_concept_9_9"%20onclick="window.open(this.href);return%20false;
Madone - http://www.trekbikes.com/ca/en/bikes/road/race_performance/madone_5_series/madone_5_2_h2_compact/#/ca/en/model/fit_sizing?url=ca/en/bikes/road/race_performance/madone_5_series/madone_5_2_h2_compact"%20onclick="window.open(this.href);return%20false;
PostPosted: Sun Jul 28, 2013 6:59 pm
I don't mind criticism, I do mind "your bike isn't fit for purpose" from someone (not you obviously) who doesn't actually know what the purpose is, or apparently much about bike fitting
By the way, the bike has the UCI seatpost which is why seat tube angle isn't the 78 degree SC standard, it is 74 degrees
PostPosted: Sun Jul 28, 2013 7:05 pm
TrekUk wrote:
Yes I can see reading comprehension wasn't your strong suit at school. Those aren't the bikes I was referencing. You've linked to the 2013 SC and to a Madone 5 H2 not a 7 H1. I am comparing a Madone 7 H1 with the 2011 SC 9 (with steerer stub, which changes the quoted stack)
 Post subject: My Trek Speed Concept
PostPosted: Sun Jul 28, 2013 7:12 pm
Boys, boys.....lets be civil. Now we know that many of us (myself included) are very opinionated, and sometimes get caught up in trying to convince others that our opinions are correct. However, we can freely state our opinions without being arses about it.
That being said, the OP should have expected the reaction received when he posted that bike on this forum specifically.....we are on WW after all, and this forum could also be called Aesthetic Weenies as it seems the look is as important as the weight.
Lets just take the high road and agree, that this is an interesting project, and although it may not be what any of us would do, the OP has a right to do what he would like with his time, money and bicycle.
Sent from my iPhone using Tapatalk 2
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
There are no new unread posts for this topic. Attachment(s) Adjusting aero bars on trek speed concept
Mattparlane
Mon Mar 20, 2017 4:42 pm
jekyll man View the latest post
There are no new unread posts for this topic. Trek Concept Bike 2026....
mile2424
Sun Aug 28, 2016 4:25 pm
KarlC View the latest post
There are no new unread posts for this topic. Colnago c60 or concept?
markyboy
28
2725
Tue Apr 25, 2017 8:16 pm
alistaird View the latest post
There are no new unread posts for this topic. Colnago concept
markyboy
Fri Apr 07, 2017 4:30 am
markyboy View the latest post
There are no new unread posts for this topic. Colnago Concept CHDB
nismosr
14
2272
Tue Jun 20, 2017 2:01 pm
nismosr View the latest post
Users browsing this forum: Google Adsense [Bot] and 16 guests
