It is currently Fri Jan 19, 2018 1:05 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: My 2012 Tarmac SL3 SR-11
PostPosted: Sat Jun 01, 2013 3:22 am
Hey guys! I'm coming up on my 1 year anniversary with this bike, and I've started looking into upgrading some components here and there to save a little weight. And I've gotten some great ideas reading around on this forum that seem pretty easy to do: Uno stem, swapping to ti bolts on everything, getting a set of FarSport carbon clenchers.
I'd appreciate any suggestions you guys may have on potential upgrades or wheelsets, I'm a pretty light guy, so I may be able to take advantage of some flimsy wheels out there.
As you can see, I've tried to black out the decals on the frame. I got tired of seeing "SPECIALIZED" 9 times all over, so I cut some electrical tape to dull it down some. Not sure how many grams that adds... but it sets me at ease.
I know the steerer tube really needs to be cut, but I'm afraid to because I think I want to swap it out for another fork.
Build:
Frame- 2012 Specialized Tarmac SL3 Expert (10r) 54cm
Shifters- Campy SR-11
Crankset- Campy SR-11
Pedals- Look Keo Carbon Blade (CroMo)
Front derailleur- Campy SR-11
Rear derailleur- Campy SR-11
Brakes- Campy SR-11
Cassette- Campy SR11 12-25
Chain- SR11
Handlebars- 3T Ergonova LTD 42cm
Stem- 3T ARX alloy 90mm
Seatpost- Specialized 10r
Saddle- Selle Italia SLC Gel Flow
Wheelset- Mavic 2012 R-Sys (No issues with mine, I love them, they're not very aero though...)
Tires- Vittoria Open Corsa Evo CX
Bottle cages- BlackBurn 25g each
Computer Mount- K-Edge
Without the computer and computer mount it is exactly 15lbs (6.8kg)
Thanks!
PostPosted: Sat Jun 01, 2013 3:52 am
:thumbup:
you prolly will feel the most with replacing with lighter wheelset. :beerchug:
PostPosted: Sat Jun 01, 2013 4:51 am
Lose the seat post, it's a tank!
PostPosted: Sat Jun 01, 2013 2:50 pm
Get a Berk combo!
PostPosted: Sat Jun 01, 2013 5:50 pm
Kmc chain instead?
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Sat Jun 01, 2013 11:39 pm
Didn't know exactly how heavy it was. Am I correct in assuming it is the "Specialized Carbon 2003 240g OEM on Allez Comp Road" in the listings?
I've been looking at the KCNC Ti Lite post as a possibility. Prices don't seem too bad online.
Kayrehn wrote:
Kmc chain instead?
Debating if I should go for the Ti or chrome version. I like the Ti one, but I'm not sure if it will fit with the rest of the bike...
PostPosted: Sat Jun 01, 2013 11:49 pm
Location: Lima, Peru and occasionally in the Washington DC area.
Without commenting on your next upgrades, I find that to be a particularly sexy bike.
PostPosted: Sun Jun 02, 2013 1:20 am
@ace I had one wih a Phenom seat and between the two they weighed 560g. Not sure which was heavier, but I'd assume the post weighed 300g. Hopefully yours is lighter. Nice looking rig!
PostPosted: Sun Jun 02, 2013 2:08 am
Yikes! Well a new seatpost will do me good then.
Thanks Tony.
PostPosted: Mon Jul 01, 2013 4:21 am
Update:
So, obviously I've playing with my fit a little. Switched the stem from the 90mm 3T to a 70mm Uno Ultralight, and to a CarbonCycles zero setback post.
After doing a century earlier this month, I came to the conclusion that my shoulders were bothering me too much, and that the bars just felt a little too far for comfort. Figured spending the $20 to try out the Uno Alloy wouldn't kill me. Pleasantly, it made a significant difference in my ride quality. Riding and sprinting in the drops feels so much better now. It does make it slightly harder to hold a perfect line, but I'm starting to get use to it.
Switching to the zero setback post hasn't made much a difference. I already had the seat pretty far forward before, so it feels the same.
Probably would have helped me a little if I had gotten a 52cm frame :noidea: But I'm making it work for now.
I'm 5'7 1/2" Inseam of 32". This frame is a 54cm with 172.5 cranks.
I'd like to do a thorough fitting soon, either Retul or the Specialized Body Geometry, in hopes of getting everything set perfect.
Upgrades made:
Uno 70mm stem: 88g
Chinese Ti Skewers: 39g
Latex Tubes: 95g together
Ti Spindles for Look Blades, bringing total to: 183g
Carbon Cycles Post: 151g
New weight should be about 6500g
I'm planning on having a set of the new wide HongFu 40mm tubulars built up with some light hubs from BHS soon. Should save me another 150g, at least, and give me much better aerodynamics than the R-sys.
PostPosted: Mon Jul 01, 2013 4:25 am
You probably could have squeezed on a 50 with much better results. Good job in working it out and trying to get a good fit rather than beating yourself up in the name of looking cool though. I would definitely work out getting a new frame in the correct size soon though.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon Jul 01, 2013 8:24 am
Keep the wheels! Unless you go for 20mm or 24 mm tubes.
Most of those china 38mm clinchers weight about the same as the r-sys.
And I suppose (I have not ridden both) that the carbon spokes give a nice ride quality.
I would suggest to loose weight on the spacer tower, the saddle and the brakes...
PostPosted: Mon Jul 01, 2013 5:40 pm
I would agree with this. i'm not sure a 50 is the right size, but definitely one size smaller than what you have. the smallish stem makes the bike harder to handle.
PostPosted: Tue Jul 02, 2013 6:05 am
@btompkins0112 & FIJIGabe
Yeah, I'll probably try to swap frames at some point this year, now that I know for certain I'm in need of a smaller size. The frameset seems to still sell for around $1200 online, which sucks for me because I bought it new for about $1k more :cry: But thats the way it goes. Maybe the LBS I bought it from would be willing to give me credit towards another frame.
Shorter crank arms at some point would probably help my knees, too.
I plan on keeping the Rsys for use most days. I just need something more aero to swap in on fast days, plus I'd like to start racing this year.
PostPosted: Tue Jul 02, 2013 12:47 pm
The LBS should help you out......did they not fit you for the frame in the first place? They should be ashamed of themselves if they did!
Mosaic RS-1
There are no new unread posts for this topic. older 2012 Cervelo R3
b5000
Thu Jan 18, 2018 3:00 am
b5000 View the latest post
There are no new unread posts for this topic. 2012 Scott Foil HMX
mannequinforce
14
1632
Tue Apr 11, 2017 6:31 pm
gsindela View the latest post
There are no new unread posts for this topic. FS-2012 Specialized S-Works Venge
Bianchi10
Sat Dec 09, 2017 6:39 pm
Bianchi10 View the latest post
There are no new unread posts for this topic. My Tarmac Pro SL4
tarmacdz
Sun Jun 11, 2017 7:09 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Aero, 2012 Style. My Time RXR Ulteam
ab01ns
11
1685
Thu May 25, 2017 10:08 am
Look565w View the latest post
Users browsing this forum: stoney and 18 guests
