Interesting ti bike
elviento
by elviento
It's not mine, came across it at the media center of Giro Stage 5. Interesting "detachable" (but integrated) ISP. Anyone know anything about it?
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
waynedude
by waynedude
Not just the seatpost. Looks like the toptube and downtube also detatches
I may have Alzheimer's, but at least I dont have Alzheimers
astranoc
by astranoc
Enigma does that kind of detachable frames, build to order of course.
S&S coupling
fa63
by fa63
I think that is Velo News' Caley Fretz's (VNTech on this forum) bike; he has a custom titanium frame with couplers.
AttacknowAttackoften
by AttacknowAttackoften
That's nice. If I had one of those, I'd fly around the world with it.
I only train on days that end with "y".
Eli
elviento
by elviento
No wonder. It is quite an eye-catcher. Build quality is top notch, and the setup is unique w/ oversized tubing throughout, with 135 rear dropouts (from eyeballing) and disc compatible.
I guess VNTech rode up the hill where Degenkolb took the stage in Matera.
www.falcobike.com
Maximilian
by Maximilian
Caley Fretz's custom Mosaic Cycles. It has some sweet polished chevrons on the top of the TT, as well is his name, I think.
--Max.
dwaharvey
by dwaharvey
Not quite sure I see the point of an S&S coupler attached ISP vs a normal seatpost
prendrefeu
by prendrefeu
ISP won't slip. Not that seatposts always slip, but they are more likely to.
Having an S&S at the ISP does three great things:
-enables perfect seat height every time when the ISP is reconnected. Sure a piece of tape would work on a seatpost, but this method requires little or no attention be made.
-The ISP can be removed. Afterall, the bike needs to fit into a suitcase (see this: http://www.mosaiccycles.com/#!tt-1/c1ces" onclick="window.open(this.href);return false; )
-Repairability: if the ISP is damaged, just repair that bit. Just like a seatpost in modularity, without the penalties of an ISP.
Heavier? Yes.
For a travel bike, a great idea.
The downside of an S&S Coupler is having someone steal half your bike. It's possible: the tool for the S&S Coupler is a universal one.
TrekUk
by TrekUk
those aeolus wheels are out of this world, ive ridden a set.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
dwaharvey
by dwaharvey
@Prendrefeu... I understand what you're getting at, that using the S&S gives advantages over a straight ISP, but it seems like re-inventing the wheel in terms of comparison to a regular seatpost. To each his own though.
thatdkid
by thatdkid
Very cool use of us of the S&S coupler. It takes the custom travel bike to a new level...
elviento
by elviento
Just got around to getting the other pics loaded. Nice to see something different than Specialized/Trek/C'dale, etc.
www.falcobike.com
GonaSovereign
by GonaSovereign
Nice bike, but a seat post would make so much more sense. If slipping seat posts were an actual problem we'd all attach our saddles with a pipe and S&S couplers.
Stolichnaya
by Stolichnaya
This design has less to do with slippage and a whole lot to do with traveling. Frames that travel have the posts removed and inserted more often and this S&S design is a brilliant idea - less stress on the frame over time, perfect alignment both height wise and saddle nose left-right position. Plus, it's fast. Travel bikes that take less time to set up are worth that S&S weight penalty in my mind.
