Leaving BMC, welcoming Trek…
Some common components, still waiting for front D to arrive, cranks and chainrings too.
Campy SR11 rear derailleur, tuned with fiberlyte carbon cage and KCNC pulley wheel bolts, shaving 6g off.
Campy SR11 shifters
Shimano 9000 11 speed Cassette, 11-23t. I’ve also used a Shimano DA cassette previously with my Campy record 10 as I felt it is quieter than my Campy record cassette that I had on another pair of wheels, and Shimano wheels are always easier to sell if I ever want to do that.
Campy SR11 shifters
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
Looking forward to hearing about how nicely the DA9000 cassette plays with Campy 11.
More weights of some random items that I can take off my bike and weigh...
Zipp SL145 stem - much heavier than my previous Extralite stem at about 100g, but I love solid-looking pieces. Probably can't get to weight the Zipp Vuka Sprint as the levers are still on and the mechanics will find me a pain in the a** if I make him weigh it for me midway while transferring it from one frame to another, but a fellow WW has it in picture at 249g.
Look Keo Blade with White Industries titanium spindles.
Madfiber front wheel with Vittoria Evo SC tires - rear wheel still has the cassette on so no point weighing it yet
KCNC skewers.
Removed the duotrap from the frame and had it weighed.
On a side note, I managed to find out the weight of the Bontrager stock brakes watching this video http://www.youtube.com/watch?v=6kJXvhpwkwA" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;[/url], and it's an impressive 304g for the pair with pads!
KCNC skewers.
Campy SR11 Front D
KMC 11 speed chain
Tacx Tao Aluminium bottle cage – I ordered in the Bontrager RXL bottle cages too but decided these are much nicer looking, even if two of the Bontrager ones weigh the same as one of these!
Extralite Ultrastar expander, awesome stuff for weightweenies
Deda bar tape, hopefully it will match the bike, and it’ll definitely look much cleaner than white! Will probably use like 35g of it.
Got a 5mm setback seatmast instead as I already have my saddle quite far back with my current setup. Unbelievably, it is actually 2g heavier than the 20mm setback mast!
KMC 11 speed chain
Got these cranks to fit Osymetric rings on, and am going to sand it now for a gloss black finish. Before and after
First time I sprayed clearcoat lacquer on I overdid it and it drips, producing an uneven finish. I sanded it again and try a second time, spraying from a further distance - this time the clearcoat mist produced a grainy finish. Any help from anyone on how I can do this right?
I can't get the bike assembled - the non-arrival of the Enduro XD-15 bearings that I ordered 5 weeks ago has been causing me a lot of grief. Disappointed with the service (or the lack of it - 3 emails in 2 weeks with no replies at all!), and I never had to wait so long for anything in my decade of shopping online. I got everything else I needed and these are the last few parts that came in.
Osymetric rings - upgraded to 54t from the previous 52 that I was using. Time to push myself harder...
Got Swissstop Black Prince pads for the Madfiber - anything is better than cork, can't get used to it since I last used the solid Reynolds Blue.
Meanwhile, I got my cranks clearcoated a week ago. It took me 5-6 tries as I'm afflicted with OCD and wanted it to look nothing less than perfect. So many things could mar the coating, uneveness of the spray, dripping of the coating, dust, bubbles etc, and there were many lessons to learn about it. I applied Raceshield protective film over it, as well as on some parts of the bike which can potentially get scratched, while making sure they aren't obvious at all.
Left this thread dead for months because I waited 9 weeks for Enduro Ceramic bearings to come; in the end I was just glad that it actually made it here at all. Still, it turns out that the mechanic says I need SRAM BB washers to get it on and right now I'm still waiting for it to arrive. Nonetheless, I got it fixed up, rode it for a week, and went back to get the steerer cut. So here it is –
Glitter paint on the logo
Much happier with this colour scheme than the new team colours.
Tacx Tao alloy cages are heavier than carbon ones but they look much nicer.
Massive headtube that’s larger than the palm!
Unique front brake limit screws for installation on different systems, and a cable release for rear brakes.
Gold cables don’t look too bad to me on it, though I was contemplating getting the industrial metal look of the Yokozuna cable housing.
The lack of a bridge for rear brakes might be the secret to its comfort.
The Duotrap sensor doesn’t really go very well with my madfibers as I can’t install its magnet and I had to glue a stack of neodymium magnet on one spoke so that it is tall enough to give a magnetic signal to the sensor.
Rode it once on wet roads and the rear brakes doesn’t get any dirtier compared to conventional brakes.
Upgraded to a 54t Osymetric ring from the previous 52t. The front D hanger didn’t allow the front D to go high enough and I had to modify the provided 10mm spacer with some advice from Tillquist – Thanks!! Also had to pry this plastic tab on the upper end on the inside of the front D to avoid chain rub in some gear ratios.
The seat tube bottle cage was too high and I had to pull the bottle out towards the front instead, leaving marks all around the bottle. Got the Di2 bottle cage adaptor and shifted it down all the way, problem solved.
Much more comfortable than the BMC, but I’m not sure if that means it is less stiff (not the sprinter type anyway). The big plus of this frame is that I can slam my stem lower and get more drop by raising the seat mast to the minimum insert level. Not doing this just for fashion’s sake; I have good flexibility and stay in the drop more often than most other people that I ride with.
Thats one mad looking 7s!!!
Bontrager RXL carbon cages are half the weight of those, also black side wall tubs would look better IMO, and if it were mine bontrager carbon RXL bars and XXX stem would be my choice.
But its not my bike is it!
Great effort and great bike. and my fave team colours.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
The BMC looked much better with all the different parts. Sorry!
I think the bontrager Aeolus D3 wheels would suit this bike a million times better with black bar tape and RXL carbon cages, It would sort it out hell of alot.
It doesnt look as much as it costs as there is so much going on.
Obviously I imported many of the parts over from the BMC, except for the SR11 parts; I thought they'll work better on this bike actually since its just white grey and gold instead of having a large swath of red as well. I actually got the RXL cage but abandoned them for this as I don't take to the graffiti-laced looks. Wouldn't consider changing the wheels because I love these for their weight - I might even get them changed to the new Version 2.
Weight is 5.96kg without cages and garmin mount. as reported by the mechanic. Another shop said it was 6kg exactly when the steerer tube was still long so I believe both are accurate measures.
- Similar Topics
- Replies
- Views
- Last post
- 78 Replies
- 14752 Views
Last post by dim
Thu Mar 08, 2018 10:53 pm
- 21 Replies
- 2242 Views
Last post by jfranci3
Thu Mar 15, 2018 6:44 pm
- 18 Replies
- 2268 Views
Last post by FIJIGabe
Wed Sep 27, 2017 5:18 pm
The Trek Madone 9
by Bely » Sun Oct 15, 2017 12:33 am » in Introduce Yourself / Gallery - Please use metric weights. - 19 Replies
- 4450 Views
Last post by stax
Sun Oct 22, 2017 8:28 pm
- 0 Replies
- 357 Views
Last post by PSM
Mon Feb 19, 2018 10:54 pm
