It is currently Wed Jan 24, 2018 6:57 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Stevens Ventoux Di2
PostPosted: Wed May 01, 2013 3:36 pm
Hi all,
Just wanted to share some pics of my Stevens Ventoux Di2. I just glued up some Corsa CS's on the 9000 C35's and took her for a spin. Coming form C50 clinchers, these wheels are much livelier and responsive. Weight is now down to 6.72kg, which is nice I suppose :-)
 Post subject: Re: Stevens Ventoux Di2
PostPosted: Wed May 01, 2013 5:37 pm
:thumbup:
PostPosted: Wed May 01, 2013 8:43 pm
Nice.
Really like the lines especially with 35 mm wheels, and the setapost completes it perfectly IMO.
:beerchug:
Louis :)
PostPosted: Thu May 02, 2013 12:54 pm
Yeah I love that seatpost.
I only train on days that end with "y".
Eli
PostPosted: Thu May 02, 2013 4:33 pm
Thanks for the nice words! Seatpost is nice indeed. Quite comfortable and light. Funny thing is, I was disapppointed with the front end comfort until I switched from the carbon Pro Vibe stem to the aluminum PLT stem. This really is one comfortable stem, and plenty stiff too. Weigt of the 130mm PLT is exacly the same as the 120mm Vibe when I switched over the ti stem bolts.
PostPosted: Thu May 02, 2013 8:52 pm
Verry verry beautiful bike , but those valve extenders.... I have the C35 also but with the 60mm extenders, must safe you about 1/2 kg ;)
Scott Foil Team edition / Holdsworth Competition / Gluing tubular and add water.
PostPosted: Thu May 02, 2013 9:26 pm
great to see something different on WW, tell us more, how does it ride?
PostPosted: Fri May 03, 2013 8:26 am
@ Rene: Haha, yeah, I'm surprised it took 4 posts for someone to complain about the valve extenders ;) Truth is, I have previously used the short ones you are using on your Scott (beautiful build by the way), but it's a hassle to inflate the tires with my pump which has a brass head without a clamping device; It relies on friction between the valve stem and the rubber seal ring inside the pump head to stay put under pressure. It barely seals the valve if I use the short one and keeps popping off. These longer extenders are hassle free, but I agree it looks kind of bad.
About the ride: Very powerful, with amazing bb and front end stiffness. Frame weight (size 58) is 981g, fork weighs 316g cut to size. The geometry makes for an agile bike: wheel base is short-ish: 995mm, with 73,5 degree angles. Effective top tube length is average for the size: 570mm. The 130mm stem makes the overall handling close to neutral.
The thin seat stays make for a very comfy rear end. I used to get numb hands with the all carbon cockpit, but since I changed stems the front end transformed into being quite comfortable as well. It truly is a very nice ride indeed.
PostPosted: Wed Sep 04, 2013 4:03 pm
thats a nice looking bike :)
It looks kinda "normal" but with a little twist. Only thing i do not like are the crakns as the are looking a bit to "big" for this bike.
:arrow: my 36XXg Stevens
:arrow: my Litespeed
PostPosted: Wed May 28, 2014 6:33 am
@tigradekat
Nice Bike!
Can you tell me your Height and inseam?
Im also interested in this Bike but im in between 56 and 58 with a height of 182cm and 90cm inseam.
Thanks!
PostPosted: Mon Jun 09, 2014 8:55 pm
nice.
except the tan side wall, i would prefer black on this bike.
sorry vor mai bed englisch!
There are no new unread posts for this topic. Lightweight Ventoux III
[ Go to page: 1 2 3 4 5 ]
in Everything wheels
KCookie
70
4422
Sun Oct 08, 2017 12:08 pm
KCookie View the latest post
There are no new unread posts for this topic. Lightweight Ventoux front
in Wanted
glepore
Sat Dec 02, 2017 12:03 am
glepore View the latest post
Users browsing this forum: godzuki26, markyboy and 9 guests
