It is currently Sat Jan 21, 2017 1:45 am
Post new topic  Reply to topic  [ 131 posts ]  Go to page Previous 14 5 6 7 8 9 Next
PostPosted: Fri Mar 28, 2014 7:52 pm
Looks great with the "raw" frame :-)
My blog
PostPosted: Mon Mar 31, 2014 11:29 pm
Internal cable routing conversion getting done.
PostPosted: Mon Mar 31, 2014 11:40 pm
absolutely love the minimal pain job, superb
PostPosted: Tue Apr 01, 2014 1:03 am
Thanks...ended up pretty good! now I'm only waiting on a small 5mm adapter to fit the s-work crank on this BB92 and I'll be good to put everything back together.
PostPosted: Fri Apr 04, 2014 9:06 am
New tool!
Fitting an S-works crank onto BB92! Before you lecture me.....it worked! Pictures coming soon.
PostPosted: Fri Apr 04, 2014 6:08 pm
Finished! 18.9lbs with 2.25/2.40 tires and heavy cassette.
to sand down BB to fit swork crank
Carbon stem cap doing its trick
Running shifting and brake cable internally...much cleaner look
PostPosted: Fri Apr 04, 2014 6:11 pm
Very cool bike!
Custom Rychtarski steel bike
Ridley X-ride 10
Custom Wittson Ti
PostPosted: Fri Apr 04, 2014 8:48 pm
sweet! need some good pictures of the new setup
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Sun Apr 06, 2014 9:36 pm
Bike did great as a first ride after modifications.
PostPosted: Mon Apr 07, 2014 9:02 am
Great build and one of a kind, congrats.
PostPosted: Mon Apr 07, 2014 12:36 pm
Shifter on the left side andreszucs ?
Enjoy your time under the sun.. and when its cold and dark don't worry too much, the world will keep spinning and your time in the sun will come again.
PostPosted: Mon Apr 07, 2014 2:53 pm
I'm missing 3 fingers on right hand (brake with little finger)...so to make things easier I moved to the left, the advantage of gripshift style.
PostPosted: Tue Apr 08, 2014 4:52 am
Wait what?!
Decided to try this because I still like the lever feature on seatclamps..
Original washer used on spark frames to secure cable and work with bottle cage... since it's no longer needed now is pairing with a front wheel quick release lever left over (because a have the lefty). Perfect combo since the washer has a concave face, fully working and holding seatpost well and strong.
21g is actually lighter then a 38mm X-Clamp QR EVO 38...and I'm still using a M5 stainless steel rod, with a Ti rod would go under 20g for sure!
PostPosted: Tue Apr 08, 2014 7:49 am
It is crazy thinking like this which is why I'm sure many of us are watching this thread :) Good stuff!
Mt Zoom 6g clamp is the way to go for pure WW ;)
PostPosted: Tue Apr 08, 2014 2:44 pm
I call it 'Eureka moments'...I have that all the time!
If you look closely to the picture with the clamp on the scale, I have a Mt zoom 38 on the background. Too bad I damaged the clamp on another 'eureka moment'...but it was not on a bike, was on a prosthetic foot. Sure would be the lightest 38mm clamp with lever in the world! Lol
There are no new unread posts for this topic. Scott Spark 700 RC 2015
freepk
Sat Apr 23, 2016 9:45 pm
freepk View the latest post
There are no new unread posts for this topic. 2016 Scott Spark 940... What to upgrade?
in MTB
shinkansen
Sat Sep 03, 2016 4:11 am
DeeHubbs View the latest post
There are no new unread posts for this topic. 2017 Scott Scale and Spark RC crank q-factors?
in MTB
hjb1000
Mon Dec 19, 2016 9:53 am
hjb1000 View the latest post
There are no new unread posts for this topic. Clavicula dp 1X10 setup.
in MTB
Erhar
15
923
Mon Mar 14, 2016 8:31 pm
CGT View the latest post
There are no new unread posts for this topic. Litespeed Ghisallo 1x10 build (3.76kg or 8.29 lbs but not finished!!!!!!)
[ Go to page: 114 15 16 17 18 ]
godzuki26
256
34243
Fri Oct 28, 2016 8:35 pm
godzuki26 View the latest post
Users browsing this forum: asiantrick, beeatnik, jrmynthn, poynt and 5 guests
