It is currently Tue Jan 23, 2018 11:10 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Apr 03, 2013 12:06 pm
I'm normally not a fan of colored tires but those really work with this build. Great job!
PostPosted: Wed Apr 03, 2013 12:53 pm
Unusual colour way but it looks great, good job! :thumbup:
PostPosted: Thu Apr 04, 2013 1:59 pm
Certainly not colors I would have chosen for my own bike, but my wife wanted purple so she got purple.
PostPosted: Thu Apr 04, 2013 9:22 pm
looking forward to pictures with a slim saddle and everything all set up just so.
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Thu Apr 04, 2013 11:02 pm
This will be going on once it arrives...
PostPosted: Fri Apr 05, 2013 12:05 am
No KMC Chain?
PostPosted: Fri Apr 05, 2013 10:40 pm
If it came in VIOLET!
PostPosted: Sat Apr 13, 2013 6:24 pm
Looks great. About to build one up myself, a few questions:
Where did you buy your Ring-Go-Star and for how much?
Any tips on the internal cable routing? What method did you use? Any unexpected hiccups?
Did you have any problems with keeping the seatpost in place, did it tend to move?
Any more pics of the cable routing near the crank? The hole where the Di2 battery cable goes in--it only serves a purpose if you're using Di2, correct?
PostPosted: Sun Apr 14, 2013 7:59 am
Unfortunately I am away from home for two weeks so cannot provide any additional photos.
I had the ring-o-star in my parts box. It's not bad, but I plan to look for a more traditional expander plug when I get back.
For the internal routing, it wasn't too difficult. The rear brake was the hardest. I routed the inner wire from the front of the bike, through the frame, and out the back. Then I pushed the housing through from the rear using the inner wire to guide it. The holes for the brake cable were a little rough resulting in some gouges in the housing. Not a big deal with black housing. It took time and patience, but wasn't a nightmare.
The holes for the internal wiring were much better. And the holes machined into the bottom bracket junction were huge. You are correct that the battery wire hole is superfluous if not using an external battery... as is the battery mounting hardware. There is a separate routing hole for the front derailleur if you are using mechanical, so you wind up with two unused holes if you're going that route. However, plugs are available, or you can just cover with a small piece of black tape.
The first seatpost I tried (Ritchey alloy, 27.2) slipped no matter how much I tightened the clamp. The second post I tried (BBB Carbon, 27.2) did not slip at all. Obviously there is some variance between manufacturers of seatposts. Regardless, I recommend some carbon fixing paste.
PostPosted: Fri Jun 07, 2013 12:04 pm
Here are a few more photos of the bike (and rider). Fit and finish are pretty much final now. My wife doesn't like the Ultegra pedals so we will likely switch back to her old Crankbrothers.
I'm no pro photographer, but I took this shots at the request of Giro. My wife won a contest for their Women's Series Gear Makeover and received a new helmet, shoes, gloves, and socks. This is her "take the kids to school, get some exercise, and bring home the groceries" getup. She was really pleased to have been selected by Giro for this prize and loves the ladies gear they provided her. I think she was equally pleased that they had a colorway to match the bike.
PostPosted: Mon Jun 10, 2013 7:44 pm
Thinking of the same build or 11 spd electric. What do you think about it now and how is the comfort? Lastly, sounds like a few screwy things to deal with in the build. Would you still recommend it?
PostPosted: Fri Oct 04, 2013 7:58 am
hi Ted, i'm so glad i found your post. i just bought the same frame for my wife and the frame will be here next wednesday. quick question on the shifter cable used.. did you use jagwire XL version or? nashbar told me i need a longer cable, but didn't specify which one. will be building it up with DA7800 group that i got from my riding buddy. will be transfering the parts from his 2007 allez pro to this bike for my wife.
how does your wife like it so far? is the frame stiff and good for climbs? thanks..
PostPosted: Fri Oct 04, 2013 10:19 am
I built the bike with di2 so didn't need traditional derailleur cables. The rear brake required full length housing run through the frame.
My wife loves the bike. It's the first real "high-end" bike she's ever had. She came from a Klein Aura V softail. So this is much lighter and stiffer. But she says it feels faster. We're currently in the Netherlands so no real climbin experience with the bike. But I suspect it would be good on climbs as well.
PostPosted: Fri Oct 04, 2013 4:04 pm
Thanks Ted for the feedback. Did she.experienced and cable slap while riding from the brake line that was internally routed?
PostPosted: Wed Oct 09, 2013 12:28 pm
No note of the cable housing rattling or slapping in the frame.
There are no new unread posts for this topic. Tubeless & carbon clinchers safety
in Everything wheels
twostroke
9
1376
Mon Mar 27, 2017 8:28 am
Marin View the latest post
There are no new unread posts for this topic. ENVE 3.4 SES Carbon Clinchers...new price
merlin3008
Sat Jan 20, 2018 4:22 pm
merlin3008 View the latest post
There are no new unread posts for this topic. Who is running latex tubes on carbon clinchers?
RJKflyer
41
3926
Mon Mar 27, 2017 5:57 pm
Multebear View the latest post
There are no new unread posts for this topic. Sub 1000€, 100% German made 1370g Carbon Clinchers
[ Go to page: 1 2 3 4 5 6 ]
leej88
89
19758
Sat Jan 20, 2018 6:31 pm
photek View the latest post
There are no new unread posts for this topic. Boyd Cycling 28mm carbon clinchers experiences?
btothec
Sat Jun 24, 2017 1:32 pm
btothec View the latest post
Users browsing this forum: bfno, bremerradkurier, dcorn, Gearjunkie, Google Adsense [Bot], grouk and 11 guests
