It is currently Tue Jan 23, 2018 9:22 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sun Mar 17, 2013 6:49 pm
Longtime lurker, first time posting. I hopefully will be a new owner of a Cervelo in the next week. Skip down to OPTIONS to skip the whole background story, I only am sharing in case someone with a similar issue can chime in.
Let me start by saying I ride/race an SL4 and have no plans to sell that bike. The fit is not perfect...I wish for just a smidgen more steerer tube length, the prior owner of the frame cut it quite aggressively, so I would rate it 8.5/10 on fit. Performance wise, 10/10.
I recently unloaded a CAAD10 which I loved but could never get a good fit. It was a 56cm, also slammed pretty low, and running a setback post and 130mm -10* stem I still needed to be more "out" and slightly more up.
So with experience on 4/5 bikes over the past several years I have figured out my problems with fit are much due to my extremely long monkey arms. I am just 6 feet tall (legs/torso pretty much equal), but in most 58 frames (that are EFFECTIVE 58 or slightly longer) I have to run at least a 120mm stem. I am really more comfortable with the reach on a 59/60 frame, but not so comfortable with other aspects of a frame that size.
What brought me to look at Cervelo is the very long height of the headtube vs top tube, in the geometry of the R3 and S5. This seems to allow tons of options for fit, from running anything for a 6 to 17 degree stem, and particularly for me and my crazy long arms.
My LBS has some great pricing, I think, on 2012 R3's and S5's. I decided on the S5 as I already have an SL4 and feel the S5 would complement it better (perhaps for use in road races while preferring the SL4 for criteriums). I do not do tri's or TT's, but this would also be versatile for those if that changes in the future. I don't find the S5 to be as ugly as many do, my only real concerns are the limitations on tire width (I prefer to race on 25mm) and on saddle options.
OPTIONS - NEED HELP DECIDING GROUP FOR S5 TEAM FRAMESET
Ultegra 6700 ($3,500): This is currently on the frame and what I test rode. I switched to SRAM several years ago but would be open to running Shimano again. I enjoy the quiet drive train and front derailleur performance (vs pre-2012 SRAM Red). I don't prefer the hood shapes and long shift throws (the hoods on di2 and DA 9000 are great however). After some saddle time, I get used to the hoods and shift just as quickly as I can with SRAM. Also in my past experiences, Shimano just seems to be very reliable, low maintenance. I don't get the positive feedback and tactile feel shifting as with SRAM, but it made me smile on the test ride to experience the quiet drivetrain and flawless FD performance I have missed for several years with SRAM.
Force/Red mix with upgrade to ROTOR chainset and cranks ($3,700): This is a slight favorite and really high value for the price; full SRAM force except new RED front derailleur and new RED shifters. I stay with SRAM but get much better front derailleur performance from what other have told me.
Campy Super Record 11 ($4,200): This is the oddballl option. I've always been intriqued by Campy and this is an awesome price, although the are much greater costs to consider particularly that all my wheelsets are SRAM/Shimano. There are only a few dealers that stock parts and much fewer options on wheelsets other than special order...but definately not getting any closeout deals from LBS options.
So what do you guys think?
PostPosted: Mon Mar 18, 2013 2:26 am
I've got an S5 with ultegra di2 and its a great bike. Love it so much I just recently built up an R5 with the new Duraace Di2. You won't be able to put 25's on an S5. Also keep in mind on Shimano you can adjust the shifter throw to meet your liking. I don't know if you can do that on a SRAM setup. Good luck with your search for your Cervélo!
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon Mar 18, 2013 2:33 am
I would say Sram.
But, are those prices the cost of the frame + groupset?
PostPosted: Mon Mar 18, 2013 6:55 am
Super record for $500 over force? a very good deal.
if you've ridden shimano & sram... try campy. i have switched and never looked back.
it is quite, effortless, and has that campy "thing" no other has.
surely you should test drive.
all assuming you can afford the $$$ differences.
OP
PostPosted: Mon Mar 18, 2013 10:12 am
the frame is quite heavy, you need a light groupset
PostPosted: Mon Mar 18, 2013 12:20 pm
Sram is not very great IMHO, SuperRecord for a touch more is motto worth it. If you want to dabble in some ITT's then Ultregra DI2 would possibly be an easy conversion w/ some auxillary shifters?
PostPosted: Mon Mar 18, 2013 1:03 pm
S5 with Ui2.
PostPosted: Tue Mar 19, 2013 12:49 pm
4200 s5 with super is an awesome deal ...
2017 De Rosa King Xs
2017 Colnago C60
2017 Colnago Concept
PostPosted: Tue Mar 19, 2013 4:55 pm
I'd go with Campy, because it rocks, but the only concern is that with you having other bikes, wheel swaps would be pretty difficult.
PostPosted: Tue Mar 19, 2013 8:50 pm
that's a pretty important point, the compatibility between your bikes,
btw. ui2 is far too heavy on a s5, it will be difficult to built up under 7500 g then
PostPosted: Tue Mar 19, 2013 9:26 pm
+1 ... that feeling of disadvantage on the climbs with that combo!
I'd avoid, but then I'm a WW! :beerchug:
PostPosted: Wed Mar 20, 2013 6:58 pm
to give you an idea .. this is my s5 with record 11
2017 Colnago C60
There are no new unread posts for this topic. Help a doofus with bar/stem decision
peted76
Wed Mar 01, 2017 1:03 am
peted76 View the latest post
There are no new unread posts for this topic. Disc brake wheelset decision: Enve SES 3.4 4.5AR 5.6
in Everything wheels
jlok
11
2501
Thu Mar 30, 2017 7:38 am
jlok View the latest post
There are no new unread posts for this topic. We took a tough decision, locked gallery threads.
[ Go to page: 14 5 6 7 8 ]
Frankie - B
108
13261
Tue Jul 25, 2017 11:01 am
slowK View the latest post
There are no new unread posts for this topic. Attachment(s) New groupset Campagnolo?
[ Go to page: 19 10 11 12 13 ]
Daniel1975
191
22074
Thu May 18, 2017 1:36 pm
claus View the latest post
There are no new unread posts for this topic. campagnolo or shimano groupset....
[ Go to page: 1 2 3 4 ]
Boshk
48
5659
Wed Oct 04, 2017 10:25 am
Daniel1975 View the latest post
Users browsing this forum: alexgodmar, alistaird, Delorre, dudemanppl, Google Adsense [Bot], sivan, Stockie and 15 guests
