Post new topic Reply to topic  [ 18 posts ]
Go to page 1, 2  Next
PostPosted: Thu Feb 07, 2013 6:25 am
update So all things did not go as planned so the bike will be built up as a raw frame, then painted after the show. The frame came in waaaaaay under what I was expecting for a MTN frame. Can not say enough for Jeremy's work and patience with me and all my "eccentric" ways. But the simply details and overall look of the frame is exactly what I envisioned/wanted when starting the project in June.
I will try to get some detail shots soon. The Brake Hose will route internal thru the downtube and external on the chainstay. "When" I run it geared, the cable will run full internal, DT & chainstay.
Steel 29er hardtail SS with carbon top tube and seatstays (142x12, PF30, 44MM HT)
Ritchey superlogic bar, stem, saddle
New Ultimate Evo post...waiting
Fox Talas 120 15mm w/Tune skewer skewer out of stock still :cry:
Yet to be released E13 TRS-r cranks...TRS+ cranks shown for color matching
Custom Formula R1 brakes
Kettle Cycles 55g "carbon" 160mm rotors these weigh nothing :D
KMC chain...waiting
Custom E13 wheelset w/cx-ray
Schwalbe 2.25 Rocket Ron F/R
King 18t cog...waiting
Chris King Gold Tapered Headset
Parts of passion UD top cap...waiting
KCNC post collar...waiting
Ashima Black Alloy rotor bolts...waiting
Adding all things together and estimating parts I'm waiting for, it looking close to 8850g or 19.5lbs.
Build list never complete w/o pics :D
And for those wanting to see how the rotors looked. Waiting for Ashima alloy bolts
PostPosted: Thu Feb 07, 2013 5:06 pm
Sounds tasty! Looking forward to seeing the finished product. Keep us updated! :thumbup:
http://www.maggieroses.com
Parlee TT: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=77371
Speedvagen: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=87080
PostPosted: Thu Feb 07, 2013 9:11 pm
Yes .. keep it coming!
PostPosted: Mon Feb 11, 2013 1:24 pm
Location: somewere floating between here and the other side
That is intresting,
I worked in an frame shop in nortern italia for a bitt nd these fella's always welded the seattube to the bb shell first, this pretty much became the base of the whole frame.
Do you put your headtube and bb shell in the jig, then mitter the bottom tube to fit and then weld the tube onto bb shell in a separete jig?
Sorry bring nosey (; love ya work !(;
PostPosted: Tue Feb 12, 2013 3:22 am
What you see here came right off the jig. The signature wishbone seatstays and chainstays will be mocked up on the same jig. The seatube is not tacked because the TT will need to be cut out leaving about an inch "sleeve" on either side that the carbon tube will slide over. This way, the top half of the frame can be removed off the jib to install the carbon then put back together to weld the ST/BB junction.
The only unfortunate thing was receiving the carbon seatstay tube and it being the wrong OD. A new one is being made, but this means it won't be going to paint. Getting the tube on Friday and having to ship the bike to CO on Monday just doesn't leave enough time for paint. :cry:
Wishbone stay for reference
PostPosted: Tue Feb 12, 2013 4:23 pm
Thank you for this inside,
So i suppose if you were to weld the seat tube to bb and fully weld the top tube after fitting the carbon-tube in it the carbon might get t hot or?
Cant wait to see the full build, love the sycips !
PostPosted: Tue Feb 19, 2013 5:43 am
All welding had to be done in steps so the carbon and bonding would not get too hot. All brazing, reaming, frame clean up finished up today, but ran out of time to put anything on.
Will try to post tomorrow as things go on and hopefully all other parts will come in.
PostPosted: Wed Feb 27, 2013 4:08 am
I start off by saying if the photos posted are not within the rules, feel free to edit or take them down.
NAHBS was a great experience. Very talented people. Next bike will 100% be a custom bike. Probably a Alchemy or Crumpton. Nick was one of the most welcoming and informative guys to talk to. He even took the time to check out the bike, how we did the carbon/steel bonding, later gave a few suggestions for next time, then gave the thumbs up.
The frame came in way under what I was expecting of around 6lbs. 4.4lbs for a a 29er frame was not what I was expecting. I don't have a final weight but on the bathroom scale was 20.5lbs, no pedals. I have no time on the rotors, but will post my thoughts on them in the coming weeks in the MTB thread. The fact that the bike was finished about 11pm Tuesday night, it never got off to paint, but so much feedback and compliments has given me the idea to just put a gloss clear coat over it and be done.
First ride is at least a week away though :cry:
PostPosted: Wed Feb 27, 2013 8:25 am
do you have special brake pads for that rotors?
PostPosted: Fri Mar 01, 2013 2:20 am
I love the rear brake cable details, very nice how classic cable stops are used for modern hydraulic lines !enjoy !
PostPosted: Fri Mar 01, 2013 5:27 am
Any OEM pads will work with the rotors.
PostPosted: Sun Mar 03, 2013 8:57 pm
Can I buy such a frame? I always wanted a steel frame, lightened with carbon tubes, and this looks amazing!
Sadly (altough I am very happy with it) just bought myself a Scott Scale 29er frame,, but my next frame would be something like this!
PostPosted: Fri Mar 08, 2013 11:23 am
Very cool indeed!
PostPosted: Sat Mar 09, 2013 3:36 am
At the moment it is not available to buy. It originally started out as a "lets-try-it-see-if-it-will-work-why-not-a-NAHBS-bike" :D There was a substantially amount of feedback from the show and with Nick Crumpton giving it a :thumbup: the conversation about offering it has come up. It will be ridden for awhile to access the durability and any shortcomings, then decided if it will be an option to the current Unleaded 29er or a "new" frame.
Thanks for the inquire though.
PostPosted: Sat Mar 09, 2013 11:53 am
Online
Administrator
I really like it too. :thumbup: A belt drive option would be the icing on the cake.
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Users browsing this forum: lbrasi, OrPe, oskar, renoracing, vladoo and 36 guests
There are no new unread posts for this topic. 2012 Cannondale Flash Carbon 29er 1 or Scalpel 29er 2?
in MTB
2002SaecoReplica
7
3209
Fri May 25, 2012 8:09 pm
steve07982 View the latest post
There are no new unread posts for this topic. Sycip with Hyperons
go4custom
14
1607
Fri Sep 28, 2012 4:52 am
go4custom View the latest post
There are no new unread posts for this topic. Steel, Titanium or Carbon frame?
[ Go to page: 1, 2, 3, 4 ]
in MTB
stephen@fibre-lyte
47
3664
Fri Jan 04, 2013 7:12 am
andekeon View the latest post
There are no new unread posts for this topic. Replacing Carbon Frame with Custom Steel
photocycler
40
2351
Sun Mar 10, 2013 10:46 pm
Ride-Fly View the latest post
There are no new unread posts for this topic. Gunsha 29er carbon wheels
in MTB
n2b
Tue Jan 29, 2013 11:47 am
n2b View the latest post
It is currently Tue May 21, 2013 7:41 pm
