Post new topic Reply to topic  [ 101 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Wed Feb 27, 2013 3:38 am
The tech that cut my fork left some room so it had play in it. Their fix was to put the FSA expander on it instead of cutting it again. That saved six grams, which got me thinking. So I looked at the expanders on FWB and figured I could save even more weight. Since I don't know the inner diameter on the fork I bought a Park Tools DS-1 that should do the trick. More than likely I will go with the Extralite Ultrastar 2. It looks to be well built, is that the consensus?
Thoughts?
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112078
PostPosted: Wed Feb 27, 2013 4:32 am
Yes they have a reputation of being a very solid choice
PostPosted: Wed Feb 27, 2013 8:23 am
I have recently installed the Extralite Ultstar 2 .It is well built and keeps well in place torqued with 14nm.
I have a AFC super light top cap and a Carbon-Ti cap bolt.
But used a strong cap and a steel bolt to take out the play and tightening the stem before I replaced them with the above.
BTW hope the rear KCNC skewer placed as is only for the photo shooting. And switched showing to the front when riding.
PostPosted: Wed Feb 27, 2013 3:35 pm
Im waiting on the same bar ends. I think the black would look better with the white tape. When you say "left some room", do you mean that it was measured and cut incorrectly?
PostPosted: Wed Feb 27, 2013 4:12 pm
Nope, is there any reason why it shouldn't be? I have always done it because I thought it was more aero. Am I wrong?
PostPosted: Wed Feb 27, 2013 4:14 pm
The thinking is that the potential danger of that skewer lever catching onto another bike far, FAR outweighs any aero benefit.
Nice weight!
PostPosted: Wed Feb 27, 2013 4:24 pm
The "cufflinks" are pretty hot!
Correct, they measured and cut incorrectly....
PostPosted: Wed Feb 27, 2013 4:41 pm
Bummer about that. I had a shop do that once. Luckily the gm corrected the whole mess and replaced my fork.
Post up over there once the build is complete. Not too many bmc's ive seen over yonder
PostPosted: Wed Feb 27, 2013 5:23 pm
Thanks! Will do...
PostPosted: Wed Feb 27, 2013 6:18 pm
Like Imaking20 already said.
Want more aero? Get some bolt on ones.
PostPosted: Fri Mar 01, 2013 1:23 am
Point 1 Racing 5mm spacer came in....
PostPosted: Fri Mar 01, 2013 2:20 am
5 point something grams savings....
New weight!
PostPosted: Wed Mar 06, 2013 7:00 pm
Don't want to hijack your thread but a quick q.
can i ask if either of your bmc's came with a conical spacer/top cap originally? my TM02 has come with this:
and i want to drop the 15mm of stack height. problem is the 3mm narrow bit that is fiared by a rubber shield. Never seen this before and with another lower stack height top cap I couldn't get the headset to preload properly. I don't think using 3mm of micro spacers below the topcap is a solution but might be what I have to go with.
Anyone have any ideas or seen anything like this before.
nice bike by the way
____________________________________________________________________________
Firefly FF050
Felt B2Pro
Trek Fuel EX9
PostPosted: Wed Mar 06, 2013 10:33 pm
Mine didn't
Storck Fenomalist 6.3kg.
BMC Teammachine SLR01
PostPosted: Thu Mar 07, 2013 12:17 am
CAMSHAFT wrote:
New weight!
Sorry to put it this way. You've havent managed to post a single full side pic of your awesome bike. The weight is nice and all, but we need to see a proper pic of this devil. (Not in the hometrainer, not in a workstand but outside against a big wall or something) :wink:
N/A CYCLES
Trek Madone SL 2007 Clearcoat
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Users browsing this forum: scotty and 37 guests
There are no new unread posts for this topic. Attachment(s) Z5, Yet again - Updated Jan 2013
tod
11
2444
Sun Jan 27, 2013 6:51 am
tod View the latest post
There are no new unread posts for this topic. BH ULTRALIGHT 2013 Updated Pics Page2
jasonsv
23
4232
Fri Mar 01, 2013 12:09 pm
sugarkane View the latest post
There are no new unread posts for this topic. 2013 Specialized Allez Race E5 OSBB (updated photos)
HaroldC
20
5611
Tue May 21, 2013 11:23 am
kets View the latest post
There are no new unread posts for this topic. BMC SLR01
[ Go to page: 1, 2, 3, 4 ]
nismosr
45
7176
Tue Jan 08, 2013 9:12 am
manne View the latest post
RihardsR
Fri Apr 19, 2013 8:52 am
RihardsR View the latest post
It is currently Thu May 23, 2013 5:41 pm
