It is currently Wed Oct 18, 2017 3:40 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Wed Sep 18, 2013 9:45 pm
New pictures at last.
With the Next SL crank (about 450g with ring), new tires (about 490g each), and removing the chain guide (-56g) the bike weighs in at 10.4kg or 23lbs ready to ride.
very happy with the build, lots of fun to ride and very capable in races.
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Fri Feb 21, 2014 6:25 pm
Well Quinn- Seems we both have the same kind of thinking. I want to go 1 x on my Voodoo that I just had painted.
I was running Sram XO last year, 3x taken down to 2x but I had issues with the setup.
Xo rear and gripshift with an XT front and RaceFace x Wickwerks crankset. Just couldn't get the damn thing dialed in so out of frustration I swapped everything back to a single setup.
I like your setup and was looking at the RF chainrings earlier this week in the shop. Does it hold the chain well? I dropped way too much last year, I want to just get rid of the front mech. if it will erase that issue.
The XO rear mech is a long cage, I know I'll have to run a short or mid but I'm wondering if I should even bother trying to run it 1x9 with a wide/narrow up front and the 11-34 XO cassette.. or just get xx1 or xo1? I don't really want to drop a grand on a new group because the Ridley isn't even complete yet but then again, I want to do it right.
Thanks in advance man.
Nice rig you have there too.
PostPosted: Sat Feb 22, 2014 6:18 am
Thanks, its been a work in progress for a while now and I absolutely love it. I like my bikes to be a little unique.
anyway, haven't had a single dropped chain since taking off my guide when i got my new crank and ring. I run this 1x9 with a PC991 and a PG990. I've raced it hard, crashed it hard (in those races), hopped and dropped it off all kinds of things, and shifted under load repeatedly. Yet to have a hiccup. I dunno what length cage ive got on there... bought my shifters and derailleurs about 6 years ago... but its just a basic XT shadow, no clutch or anything. Im sold on narrow-wide and I've got the legs/terrain to run a 32 tooth ring on an 11-32, so I've been very happy. so a similar set up to your plans but using a shimano mech over a sram one...
Sur La Plaque!
PostPosted: Sat Feb 22, 2014 2:15 pm
Quinn,
Nice bike! I was interested in knowing more about your lower headset race setup? looks a little strange, is that a bearing sitting below the lower race or some sort of shim/offset washer etc..
PostPosted: Sat Feb 22, 2014 5:09 pm
Hey tom, thanks!
In answer to your question, that's a 5mm King race/spacer. It replaces the original race to give around 5mm (a little less in actuality) of extra lift between the frame and the fork crown. The reason for it is that Fox crowns/knobs and Dekerf frames (the SST and Elysium in particular) dont play nice and the fork will hit the downtube without the tall race. The part comes directly from King and is the solution that around 10 of our customers (and my fellow employees) bikes have employed for these frame/fork combinations. Dunno about other suspension manufacturers forks as, for our area at least, if you buy a Dekerf you buy a Fox. However, older model floats (2009-10ish, dont have the same issue... the FIT's and CTD's seem to be the things that cause the issue)
Hope that clears things up for ya!
Sur La Plaque!
PostPosted: Fri Feb 13, 2015 10:23 pm
Update!
Changes over the past year or so have been minor... but they include:
Thomson Elite---------> Thomson Masterpiece
SDG Bel Air Ti---------> Selle Italia XC Flow
Finned Pads-----------> Alu backed, unfinned
Old tube--------------> Lizard Skin
Oury Lock-ons--------> SRAM foam lock-ons
Conti Schrader tubes--> Maxxis Ultra lite presta
PC 991 hollowpin------> PC 991 solidpin
Steel bolts------------> Alu bolt (cages, CS/SS)
Weight is now 10.2kg or 22.5lbs
Will post some better pictures when we have less snow.
Sur La Plaque!
There are no new unread posts for this topic. Attachment(s) 2012 Focus Izalco Team Repllica
518jbe
Tue Jan 17, 2017 9:04 am
reedplayer View the latest post
There are no new unread posts for this topic. Attachment(s) 2012 Cervelo R5 VWD, 51cm
indywagon
Wed Aug 23, 2017 4:04 am
indywagon View the latest post
There are no new unread posts for this topic. 2012 Scott Foil HMX
mannequinforce
14
1355
Tue Apr 11, 2017 6:31 pm
gsindela View the latest post
There are no new unread posts for this topic. Upgrade Or Keep: 2012 Cannondale Evo HiMod
SBRYYC
14
2370
Fri Aug 11, 2017 12:30 pm
tarmackev View the latest post
There are no new unread posts for this topic. 2012 Cannondale Supersix SRAM RED
mcbbcn
Wed Jan 18, 2017 8:01 pm
mcbbcn View the latest post
Users browsing this forum: glam2deaf and 10 guests
