Enigma Esprit - Titanium - Finished!
iamalex
by iamalex
Thanks Quinn.
Must admit, whilst they feel rock solid they don't feel quite as quick as the previous wheelset. Going to play with the tyre pressure and perhaps some latex inners see if that makes a difference.
Intheshed - I got the tape measure out...
Saddle to floor: 1020mm
Saddle to bar drop: 90mm
(I spend most of my time cycling in the drops, Ergonova Team bars, so not a massive drop on those).
Much more comfortable since loosing the spacers and flipping the stem. I guess sitting on a jig for a fit and actually riding are quite different.
If you can, try and head over to Enigma and have a test ride. They were fantastically helpful when I went. Some of the other models might be a bit stiffer if that was something you needed. I get some brake rub if stomping on the pedals.
intheshed
by intheshed
Thanks for the info on fit and flex. On quite a nice Cannondale carbon frame at the mo' so the flex might bug me. Probably worth testing as you say.
Cheers
iamalex
by iamalex
Just wanted to revise my initial thoughts on the wheelset; they're actually really very nice!
Running them with 24mm Open Pave tyres they're smooth, fast and fun. I think I was the week link to begin with, getting over an injury I was more run down than I first thought.
michel2
Location: somewere floating between here and the other side
by michel2
Do u have a bitt hip ?
I had a bitt (well shattered) hip after a bus accident. Waited for about nine years to decided to have it resurfaced with a birmingham hip and now i got a fake but good hip !(;
Should have done that much earlier !(;
iamalex
by iamalex
Michel2, that sounds awful! Glad to hear you got it sorted.
Mine is nowhere near that. It comes and goes but my hip doesn't always seem to seat properly, it pops about the joint when I move it. Got knocked off in the summer which has aggravated it and running the other week really did something to it. Only 31 so shouldn't be knackered just yet, perhaps time for the doctors though.
vektor
by vektor
Nice build!
one question though: how did you remove the decals from the handlebar? aceton, sandpaper?
iamalex
by iamalex
Hello Vektor, I used a product called Carbolift. Took a few goes but did the job. There are posts by other forum users with alternative methods; razors blades, sanding etc etc
vektor
by vektor
iamalex wrote:Hello Vektor, I used a product called Carbolift. Took a few goes but did the job. There are posts by other forum users with alternative methods; razors blades, sanding etc etc
THX for the info... will do some deeper research on this!
iamalex
by iamalex
Hello Vektor, sorry for the short answer earlier, was out riding. I bought 500ml directly from Carbolift's website and postage to the UK was pretty reasonable. There was more than enough for two pairs of bars and a set of forks. I accidentally spilt the rest moving house.
As I mentioned it took a few applications over a few days. I used a plastic scraper to help remove the gunk and agitate the stubborn bits. Used some fine grit paper at the end to remove the last of the stubborn lacquer. After this I resprayed with an automotive varnish with a satin finish. Just from an aerosol. This added back the UV protection.
A word of warning - the raw carbon did not have a perfectly uniform finish, there were some marks and blemishes. Luckily they were all covered by the tape.
In some of the other threads people have used razor blades to scratch off as much of the varnish/lacquer as possible and then gradually finer grit papers. Stop sanding when the dust goes black, that's the carbon. I'm not a composites expert so I'll leave you to do your own research on what might be the best way of UV protecting.
bjj22
by bjj22
As a fellow esprit owner, I have to say this is a fantastic build.
iamalex
by iamalex
Thanks bjj22!
Word of warning to a fellow Esprit owner: If you have an aluminium seatpost be sure to regularly remove, clean and reassemble with copper slip. I used Park Tool Anti Seize and that post is now stuck - only took a couple of months.
bjj22
by bjj22
Thanks for the heads up, I have a ti post but most of my components get changed around far more often than necessary so not beyond the realms of possibility that I'll have an aluminium one in at some stage.
ryan0380
by ryan0380
I have a steel enigma but this bike makes me want to have a ti one too, great build
iamalex
by iamalex
ryan0380 - I'm your steel Enigma is plenty good enough!
bjj22 - Start a thread and post some pictures, be good to see your build.
CXTony
by CXTony
Nice build and love the new wheels too. Personally I would switch the white logos to black to match the components, but that may just be me :)
