Post new topic Reply to topic  [ 9 posts ]
 Post subject: 2013 Madone 7.9
PostPosted: Tue Jan 22, 2013 9:13 pm
Just weighed in at 14.3 with speedplay peddles and carbon bottle cages. U5 Vapor Paint, Full Sram Red, and Stan's No Tubes Alpha wheel with Hutchinson Atom tires.
 Post subject: Re: 2013 Madone 7.9
PostPosted: Tue Jan 22, 2013 11:22 pm
W/o pics., it didn't happen.
PostPosted: Tue Jan 22, 2013 11:31 pm
Pics please :)
PostPosted: Tue Jan 22, 2013 11:52 pm
Sounds legit - my 60cm 7.9 with SRAM, standard paint, speed plays, cages, computer and durace ace C24s with grand prix 4000s weighs in at just under 15.
I would post pictures but i don't have a high enough post count :(
On a side note how have the brakes been for you? I seem to get a lot of flex within the brake itself which ruins brake feel in my opinion. Does anyone know if i can use the dura ace brakes with sram levers? I guess they would be different ratios? :( Or can i adjust them?
PostPosted: Wed Jan 23, 2013 4:06 am
You can definitely shed some weight by swapping out those tires. I think mine were about 60g heavier than the VeloFlex I swapped them for. None the less, out of the box that is pretty sweet!
09 Pinella w/ Record 10spd
http://1spd.blogspot.com/
PostPosted: Wed Jan 23, 2013 10:30 am
I agree about right, ive a 5 series with pedals, lights and garmin edge 200 all fitted and this was just under 16lb with everything
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Wed Jan 23, 2013 8:30 pm
Here's a pic. Had it weighed at the LBS so I don't have a picture of the scale.
PostPosted: Wed Jan 23, 2013 10:44 pm
Very nice!
PostPosted: Wed Jan 23, 2013 10:53 pm
I have a 7.9 (6.04kg / 13.3lbs 62cm H2 details will follow) I just swapped my Bontrager brakes for Dura-ace. I hated the bontrager brakes for many reasons, but not for feel funny enough. The Dura-ace brakes work great.
[*] DA were a bit of a pain to install (don't remove the plastic bits before trying to install.)
[*] DA weigh a little less. Front 139g vs 146g. Rear 118g vs 146g
[*] DA front is more powerful than Bontrager (from feel only)
[*] DA rear flexes so I am not sure how much power you could really put in there - but it is a rear brake so I am sure it would lock up before bending too much. Might flex more than Bontrager on the rear
[*] DA is better made with a more quality feel about it and the bolts should not rust (like the bontrager ones were beginning to)
[*] DA pads will be much much easier to swap (important for be with carbon and al. wheels)
[*] DA do not look as stealth as bontrager.
[*] Trek has 3 holes at the front and rear to mount brakes. both brakes use 2 holes. DA and Bont share 1 hole and the other one you pull out a plug from the frame and shift it to the redundant hole.
I hated the bontrager brakes so much for many reasons (mainly build quality, adustability hassles and brake pad swapping hassles. If I had my time again i guess I would buy a full DA setup and not Red/Bontrager for a Trek as the bontrager brakes are a killer for me and I don't like having such a mismatch of red/DA parts.
Users browsing this forum: -Robin- and 15 guests
There are no new unread posts for this topic. 2013 Madone
wilson78
15
3354
Sat Dec 01, 2012 10:58 pm
sawyer View the latest post
There are no new unread posts for this topic. My 2013 Trek Madone
allezkmiec
Thu Apr 11, 2013 12:42 am
allezkmiec View the latest post
There are no new unread posts for this topic. 2013 Trek Madone 5.9
bon
21
5080
Tue Feb 05, 2013 8:43 pm
Fuchspk View the latest post
There are no new unread posts for this topic. 2013 Trek Madone 7
Lawfarm
Mon Oct 15, 2012 2:47 pm
fio View the latest post
There are no new unread posts for this topic. Hello , question about Trek Madone 6.2 2013
CeCa
Sat Apr 13, 2013 7:45 am
CeCa View the latest post
It is currently Thu May 23, 2013 7:22 am
