Post new topic Reply to topic  [ 22 posts ]
Go to page 1, 2  Next
PostPosted: Tue Jan 22, 2013 1:48 pm
So this is my Current project bike,
I have had the frame for a number of years and love the ride,stiffness and weight of it for the money.Im a student so trying to have a large frame with all of the above is pretty good.
Its a 61cm frame and weighs 990g which is not bad Since I started I've removed the Gear cable bosses with dremel,then Ive drilled into the frame then de-burred them with a fine end on the dremel.
It now weights some 963g Im having the Frame sanded and Sprayed as It needs to be blank,but im Planning on a matt black/ white colour combination.
Im trying to work out how to make the battery set up internal and lighter.. any ideas welcom bearing in mind Im non an electronics wizz.
The rest of the Build will be replacing the stock bolts on the Mechs and Jockey wheels.
Ill be running TRP 960 brakes or Dura Ace 9000,Sram Red crankset which is sanded and Will have Praxis Chainrings on or Dura ace 9000.
The Wheels will be my 4crosswheels 50mm wide rim tubs which come in at 1389g OR No tubes alpha 340 team's
Ill be running Veloflex tyres for summer use or pro4 grips for riding Spring time or Dura ace 9000.
Ive got It down (this frame) to 6.65kg with tubs and tuned sram red,but I wanted the shifting of DI2 for racing on.
Build list will be as follows;
Frame: BeOne Pearl
Fork: BeOne
Headset;Cane Creek AIR
Tires: Veloflex
Tubes: Continental Latex
Brakes:Planet X cnc/Dura ace/Trp 960
Cassette and lock ring: Dura-ace 7900 11-25
Stem: WCS 2013 120mm
Handle bar:Superlogic Carbon
Crank set: Sram Red with Praxis or Dura Ace 9000
Pedals: Dura ace carbon
Seat:Arione Cx carbon
Seat post: KCNC
Brake levers: Ultegra DI2 ( anyway to tune these?)
Rear Derailleur: Ultegra DI2
Front Derailleur:Ultegra DI2
Chain: Yaban SFL
Cables and housings: Gore Ride on
Botle cage: 2 xPlanet x carbon Sanded
Handlebar Tape:Lizard skins Thin
Any ideas how to cut weight for similar prices on items I need to buy? Or how to make U Di2 lighter?
Bruce
Last edited by 4crosswheels on Mon Mar 18, 2013 10:50 pm, edited 2 times in total.
PostPosted: Tue Jan 22, 2013 3:51 pm
Carbon tubes are not that good with compression forces so putting that frame in a clamp is maybe not the best thing.
PostPosted: Tue Jan 22, 2013 6:37 pm
The frame is only held lightly for display,Its only meant to hold..
PostPosted: Wed Jan 23, 2013 2:53 pm
Why not get the cables internal complete instead of that ugly junction under the bottom braket? For the battery the new seatpostbattery from Shimano is an easy solution.
/jonas l
PostPosted: Wed Jan 23, 2013 10:05 pm
I will be running them internal when the seatpost battery is available, I have good authority that it will be in the uk end of march,
In the meantime the colour scheme ive chosen for it is
it will have internal of the forks and rear stays a metal flake black... Ill update you as it happens.
Bruce
PostPosted: Thu Jan 31, 2013 7:05 pm
Update.
Frame in the painters....
One word BOLD.
what do you think?
PostPosted: Thu Jan 31, 2013 8:58 pm
Hi,
Beautiful color!
Now we need only to maintain so beautiful!
Waiting ended up full!
Thanks!
PostPosted: Thu Jan 31, 2013 10:22 pm
Wow! Love bikes with colour, well done
/jonas l
PostPosted: Fri Feb 01, 2013 12:13 pm
Picture From outside in the sun... It really sparkles and the black has a blue metal flake pigment that catches the light too...
PostPosted: Sun Feb 03, 2013 8:57 am
Looking good! Where/who did the paint for you?
PostPosted: Mon Feb 04, 2013 6:00 pm
Have you done anything to reinforce it in the places where you have drilled the holes for the Di2 wires? I'm thinking about the risk of stress-fractures in these particular areas due to the material working under load in the long term?
PostPosted: Mon Feb 04, 2013 6:14 pm
lovely green and nice with the black "inside-fields"
PostPosted: Tue Feb 05, 2013 12:22 am
Well the frame was done at my friends paint shack, regarding the drilling I researched the best method to drill into carbon,looked at best areas to do so...It looks clean drilling went well I drilled with a coolant.
All looks good to me.
PostPosted: Tue Feb 05, 2013 11:46 pm
How is the best method to drill in carbon fibre? Getting curious and want to be better
/jonas l
PostPosted: Wed Feb 06, 2013 9:53 pm
Best method I tryed on some carbon sheet was use a dremel to get down to the raw carbon,then a ti bit at high speed for short time,very clean cut. Hope that helps.
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Users browsing this forum: coppercook62, Google Adsense [Bot] and 25 guests
There are no new unread posts for this topic. My new 'old' Colnago spring project :-) Finished Images Pg4
[ Go to page: 1, 2, 3, 4 ]
Lig
58
4414
Thu Jan 31, 2013 3:20 am
willy View the latest post
There are no new unread posts for this topic. Attachment(s) Winter bike project: ALAN Alu Cross (finished P. 2)
SWijland
23
5124
Thu Dec 27, 2012 12:24 pm
SWijland View the latest post
There are no new unread posts for this topic. My Beone Raw Pro 2011
NexusKaiser
Sat Mar 16, 2013 11:10 am
MLown View the latest post
There are no new unread posts for this topic. My Internal DIY Di2 setup
Johhny Bravo
15
2474
Sat Jan 12, 2013 8:32 pm
Johhny Bravo View the latest post
There are no new unread posts for this topic. R5 VWD Ltd. Internal Di2 9070
rmerka
19
3423
Wed Apr 24, 2013 11:32 pm
rmerka View the latest post
It is currently Fri May 24, 2013 6:30 am
