Post new topic Reply to topic  [ 49 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Mar 09, 2013 1:59 pm
I'd thought about that, but I'll probably bin the q-rings and go back to compact when I switch. Don't think the aesthetic of the q-rings match campy.
Send me a PM about the cranks. Was on the fence about Athena/Chorus.
PostPosted: Fri Mar 15, 2013 3:46 am
Ok.....wanna drop some weight for free to cheap.
1. I have a veloflyte bearing cover on the way and I will slam the stem and cut the steerer.....should drop some grams there.
2. I haven't looked at the seatpost yet, but I assume there is some room to lop a bit off for some more free savings.
3. My hoods are a bit tatty, so I was going to try out the tube-as-hoods trick for some more free weight there.
4. Thinking about moving on some Planet X brakes. Definitely some weight savings over the Ultegra kit.
Any other ideas?? I am using Specialized S-Works bar tape.....any savings to be had there?
PostPosted: Fri Mar 15, 2013 6:29 am
Try out the innertube as hoods thing. I'll be posting about my findings a bit tomorrow (need daylight to take a few more photographs)
The Planet-X brakes are pretty great.
At this point your drivetrain as a whole is the weight penalty - and that ain't cheap, unfortunately.
But, in due time, when your pennies are saved, you'll get what you want.
As Axle Rose once sang "just a little patience...."
Exp001
PostPosted: Fri Mar 15, 2013 1:08 pm
That's exactly why I'm doing this.....want to get as light as possible now while I await the group upgrade (Campy or SRAM red). The weight is probably centered around the levers (400+grams?) and the cranks (550grams for the arms). I am sure the Q-rings aren't light either.
Frankly, I am amazed I got to 6.8 with the relatively heavy Ultegra kit.
PostPosted: Fri Mar 15, 2013 4:17 pm
My 53/39 rings came in at 153 grams for the pair.
PostPosted: Fri Mar 15, 2013 5:11 pm
That's not too shabby, thanks plpete! :cheers:
PostPosted: Sat Mar 30, 2013 10:35 pm
Picked up a RECON cassette to drop a little weight (thanks to member wiRIDEfast!!)......still looking for some brakes, and a full carbon saddle.
Untitled by btompkins0112, on Flickr
PostPosted: Sat Apr 06, 2013 2:04 am
Check out what the mailman dropped off today!
This brings me down quite a bit.....I think I have gotten as low as I can go before I upgrade the group
PostPosted: Thu Apr 18, 2013 4:40 pm
New saddle.......
PostPosted: Thu Apr 18, 2013 4:41 pm
Double post....sorry :oops:
PostPosted: Thu Apr 18, 2013 8:25 pm
Whoa, that is an awesome looking bike. I bet it goes as fast as it looks.
S P L I T: 2010 Meivici: 14.4 lbs | 2003 Odile: 19 lbs | Hunter Cycles Cyclocross: 17 lbs | 2013 Dundee Cycles Jewell 29er: 17 lbs
PostPosted: Tue May 07, 2013 8:33 pm
Noticed I hadn't posted some update pics from this weekend....
PostPosted: Tue May 07, 2013 8:38 pm
what a lovely shaped frame, lovely balance to the build mate. Have you thought about the dark grey ultegra crank for aesthetics longer term?
PostPosted: Tue May 07, 2013 8:45 pm
Thanks!
Yes, I am all over the road on group upgrades.....I had been interested in a Campy 11 upgrade to either Chorus or Record; however with the new Ultegra 11 I may go for that depending on price. Winter 2013 is pegged for the group upgrade, so what's available will make the decision for me.
:cheers:
PostPosted: Wed May 08, 2013 5:41 pm
truly great build... That frame is beautiful, very nice fuji. I like how it's evolving. I think changin the silver pars would be nice. Also, if you want, you could sand the fsa parts to matte black and make it full stealth, but like this it's already nice. I like the H sons rims, but why did you removed the carbon ones? Also i would leave the antares saddle and remove the carbon thingie.
Happy Trails !!!
MTB / Giant Xtc '05 / 8.7Kg
ROAD / La Perla Negra - FM015 / 7.0Kg
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: Exabot [Bot], gbranden, Google [Bot], steff and 15 guests
There are no new unread posts for this topic. Fuji Altamira geo
AGW
18
942
Sun Apr 14, 2013 10:31 pm
roadytracky View the latest post
There are no new unread posts for this topic. Fuji Altamira SL
flips
12
1746
Thu Mar 07, 2013 5:42 am
prendrefeu View the latest post
There are no new unread posts for this topic. 2011 Fuji Altamira 1.0
ThePullMan
Tue Feb 12, 2013 8:04 am
ThePullMan View the latest post
There are no new unread posts for this topic. 2013 Fuji Altamira 2.3 - what's your take?
ThePullMan
29
4542
Fri Dec 28, 2012 2:53 am
113245 View the latest post
There are no new unread posts for this topic. Fuji Altamira SL vs Scott Foil 10/15
Fri Jan 04, 2013 8:15 pm
It is currently Sat May 18, 2013 1:15 pm
