It is currently Mon Aug 21, 2017 9:46 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Sat Sep 07, 2013 5:19 pm
nobrakes71 wrote:
nice!
Thank you.
Painting is almost finished:
Uploaded with ImageShack.us
PostPosted: Fri Sep 20, 2013 8:43 am
Finished. Hope you like it.
Maybe it needs now some black clinchers...
PostPosted: Fri Sep 20, 2013 2:01 pm
Thats awesome!
I have a 2013 Red Tarmac Expert and would LOVE to repaint it like that, although possibly in a matte blue or green.
Can you write out your process? Specifically, how did you sand (what grits, etc). and how did u paint?
Thanks and great work.
PostPosted: Fri Sep 20, 2013 9:37 pm
Thank you very much.
I started sanding an small area to find out the thickness of the red and white painting. The white one was a thin layer but the red one and clear coat were very thick layers so I went to my local hardware shop and asked for a non carbon agressive paint stripper; once the red painting was gone I started sanding the whole frame -400 grit-.
Then came no less than 20 hours sanding with 800 grit sanding paper first and 1200 water sanding paper later. Finished it with this 3M sandblaster:
I cleaned the frame with acetone and applied three layers of black matte UV resistant spray painting. Used this one which is intended for graffitti purposes:
http://www.sprayart.es/product_info.php?products_id=556" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
It leaves an uniform surface but a bit raspy. Best of all is that there´s no dripping.
Then I applied a black glossy layer in the logo areas and put the vinyl stickers - high quality vinyl; got the vectorized logos at http://www.brandsoftheworld.com" onclick="window.open(this.href);return false; -" onclick="window.open(this.href);return false; and applied another black matte layer. Took off the stickers with a razor blade trying not to scratch the painting and I was done.
I didn´t applied a clear coat layer but it can be done if you wish to.
There are no new unread posts for this topic. Wheel rebuild
in Everything wheels
GT8
13
738
Thu Dec 29, 2016 5:17 am
sugarkane View the latest post
There are no new unread posts for this topic. Trek Emonda ALR - Rebuild
Christono
11
2961
Thu Jul 06, 2017 3:31 pm
jeffy View the latest post
There are no new unread posts for this topic. Rebuild XX1 der. to match XTR shifter
in MTB
Esben
Thu Mar 02, 2017 9:25 pm
HaakonJohansen View the latest post
There are no new unread posts for this topic. Older carbon tub rims - rebuild for 11 speed -worth it?
patchsurfer
12
587
Thu Jun 15, 2017 1:35 pm
mattr View the latest post
There are no new unread posts for this topic. Parlee Z3 - Rebuild... Full build pics at bottom of page 1.
Lig
18
2508
Wed Jan 18, 2017 6:34 pm
Lig View the latest post
Users browsing this forum: dastott, Norregard and 18 guests
