Post new topic Reply to topic  [ 69 posts ]
Go to page Previous  1, 2, 3, 4, 5
PostPosted: Wed Feb 27, 2013 9:09 am
Any suggestions or feedback? We'll be lowering the stem but will likely leave a bit of extra steerer so my son has room to grow. Also, I'm not happy with the I-links and the Planet-X brakes. Individually they are great. But the i-links don't fit into the cable stops on the brakes which is an issue. New saddle, some red-ano bolts, and wire grommets are on the way. We're probably going to switch to a longer crank... same design but moving from 145mm to 150mm. Otherwise, I can't see anywhere I can make changes without throwing a lot of money at the project.
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
PostPosted: Wed Feb 27, 2013 2:28 pm
Nice overall project. The bike looks huge compared to the kid.
Cool crankset ! How much do these cost ? Any link to a manufacturer, or distributor ?
So, finally, bike weight ?.......anywhere near the projected "under 6kg" ?
Louis :)
http://www.ccsalma.com
PostPosted: Wed Feb 27, 2013 10:19 pm
The front end is tall. We need to pull out the giant spacer under the stem. But when you see him on the bike, actually riding, it is a good fit. The top tube is only 49cm.
The crankset runs US$150.00. It is actually a BMX crankset. But I found it works really well with a double chainring. You can find it at http://speedlineparts.com/products/cranks/sx-mini-cranks/. The design is actually licensed from Answer BMX which has the same crank at http://www.answerbmx.com/AnswerMiniCranks.html.
My scale is dead... I think damaged in the move. I'll have to buy/borrow a new one to get the weight. But it feels close to the mark compared to my bike.
TED ESSENFELD
Bike Pics
Litespeed Ghisallo
PostPosted: Wed Feb 27, 2013 10:23 pm
looks happy to be riding it, nicely done!
PostPosted: Thu Feb 28, 2013 4:04 am
xnavalav8r wrote:
It is actually a BMX crankset. But I found it works really well with a double chainring..
Thanks for the links Ted.
So it's intended for use with a single ring ?
How (any particular placing, or modification) did you install the two chainrings on the crank ?
Very clever. I'll copy you, that's for shure :beerchug:
How tall's Ryder again ? Just for crank arm lenghts comparison with my twin daughters...
Louis :)
PostPosted: Thu Feb 28, 2013 8:50 am
Ryjder is about 140cm tall (roughly 55in). I chose his crank length by measuring his inseam and comparing the proportions to my own. A professional fitter recommended I use a 170mm crank based on my 78.74cm (31in) inseam length. The 145mm crank worked great last year, but he has grown a bit so I have a new, slightly longer crank coming. Unfortunately, I have only been able to find cranks in 5mm increments. As a result, he is moving to a 150mm... but I would prefer he was on a 147.5.
As for modifications. I made a very minor modification to the spider. Using the Extralite 42/30 chainrings on the 104bcd spider is almost perfect. However, the arms extended a bit further beyond the chainring bolt holes than is normal on a road or mtb crank. As a result, the chain tended to make contact with the arms and "lift" 4 times per rotation. I used a Dremel to grind away a bit of the excess material and shaped the ends of the arms to act as lift ramps when shifting. I'll try and post a detail picture later today. To be honest, I am really impressed with the result. It's not very noticable visually, but it really did improve the shifting. Considering I did it by hand, I can't be more pleased with the result. It was about 10 minutes of effort for a huge performance improvement.
TED ESSENFELD
Bike Pics
Litespeed Ghisallo
PostPosted: Thu Feb 28, 2013 10:16 am
That is seriously cool!
Congrats on the build
Your son obviously loves his new bike, you cant wipe the smile off his face!
And nothing makes me prouder than riding down the road with my son (12y/o)
PostPosted: Fri Mar 01, 2013 8:55 am
Yeah, we have a lot of fun together on bikes...
TED ESSENFELD
Bike Pics
Litespeed Ghisallo
PostPosted: Mon Apr 01, 2013 1:51 pm
Out for a ride along the North Sea Coast... "hurry up dad!"
TED ESSENFELD
Bike Pics
Litespeed Ghisallo
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5
Users browsing this forum: damitamit, DamoRider, Gary, ghisallo2003, konky, NoiseBoy and 34 guests
There are no new unread posts for this topic. Kinesis RaceLight, budget aluminum on steriods
DMF
9
1663
Mon Mar 04, 2013 9:01 am
DMF View the latest post
There are no new unread posts for this topic. Project AsiaCarbon with ISP (FM015-ISP) Pics pg. 2
CaptainP
32
4363
Sun Jun 16, 2013 11:52 am
nevermindthebikeshop View the latest post
There are no new unread posts for this topic. AlpineStars Cro-Mega LX T26 - Jr Project - Complete w/pics
in MTB
xnavalav8r
19
1803
Sun Jan 13, 2013 12:46 pm
xnavalav8r View the latest post
There are no new unread posts for this topic. Attachment(s) BMC SLR01 Project --> [Update & link to NEW Pics on PP 2]
vlastrada
22
3144
Wed May 08, 2013 3:53 pm
bally81 View the latest post
There are no new unread posts for this topic. Helmets for 2 and 4 year old kids
digitalnorbs
Wed Sep 05, 2012 6:59 pm
digitalnorbs View the latest post
It is currently Wed Jun 19, 2013 10:33 pm
