It is currently Wed Aug 23, 2017 10:50 pm
Post new topic  Reply to topic  [ 147 posts ]  Go to page Previous 15 6 7 8 9 10 Next
PostPosted: Mon Jun 03, 2013 8:21 pm
I'm 184 cm with 92 cm inseam and also long arms for my height, 190 cm between fingertips. So I'm comfortable with big drop and long stem... I also have a 59 traditional CT2 with 1cm shorter stem, and the differences in handling are very small. Maybe I feel the front wheel is a little bit closer with the C59, but they both feel very good and the contact points are just the same.
nobrakes71: For someone who's 179 cm, I think 54s is on the large side, still possible to get a good fit with a shorter stem, but maybe 52s or 57 traditional would be a better choice?
tumblr
PostPosted: Wed Jun 05, 2013 9:44 am
nobrakes71 wrote:
eurperg: just out of curiosity: what's your height and inseam measure?
I'm planning to order a C59, and was recommended a 54s by the dealer. I'm 179cm height and 88cm inseam, but I'm thinking if the 54s is going to be a bit too big, and the 52s would be better.
Apologies for briefly stealing your post - but any thoughts on the above would be appreciated.
I am 180ish and have an 88 inseam in cycling shorts. I ride Colnagos in 56 and 57cm. Recently got the 56 and I slightly prefer it to the 57. Anything from 56-58 is in the fit zone for you, but you need to know your preferred saddle height and how much drop you can handle. The top of your saddle should be between 17 and 19 cm or so above your top tube unless your proportions are very skewed. I've had a 58 and it is more suited to a 70s old school type of fit where you'd have downtube shifters and non-aero levers and spend less time on the hoods; it feels much larger than the 57.
PostPosted: Wed Jun 05, 2013 12:42 pm
I am 1.80 with a bit shorter legs, so 84cm inseam.
for that reason my fit range is more between the 54-58.
I have tried Colnago sizes 54,55,56 custom ( with lower top tube),56, 57 and 58
I prefer the regular 56 on a 120mm stem, it provides the most balanced ride.
I can ride the 54-55 with a longer stem but I feel I am too forward, or the 57-58 with shorter stem but I feel the bike is too big and the top tube a bit too high.
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
PostPosted: Wed Jun 05, 2013 4:54 pm
thanks for the tips on sizing.
I think I'll be able to arrange a test ride on a 54s, and will let you know how I get on. If it's too big, it will be obviously be a 52s for me. I'm now also thinking whether I should consider a traditional frame and get a 57, which is right in between sizes and might provide a better fit.
Apologies again for stealing the thread!
PostPosted: Thu Jun 06, 2013 2:54 am
That bike looks well no matter which wheels, these ambrosios also shine, still hyperons are my favorites. Comes to show that modern bikes don't need hi profile wheels to shine, when built right! ;-)
PostPosted: Thu Jun 06, 2013 7:31 am
In fact, I just sold the Reynolds wheelset because I didn't use it that much... Hyperons + Roubaix is a winning combination both on asphalt and gravel.
Too many nice gravel roads to avoid with high profile wheels here. This is where the fun begins:
tumblr
PostPosted: Thu Jun 06, 2013 8:29 am
Are you riding your C59 there? :0
Why not a CX?
PostPosted: Thu Jun 06, 2013 8:52 am
Makes no sense to ride a CX bike for hours on asphalt just because of some gravel sections, and also because CX bikes and tires are overkill for most gravel roads...
The C59 frame is probably beefier than my Kuota CX frame, at least it doesn't feel soft when I squeeze it with my fingers. :roll: And small dings in cranks and bb, who cares...
tumblr
PostPosted: Thu Jun 06, 2013 9:54 am
I is no problem riding it on rocky roads. I am sure. Just put some protection under the diagonal tube. ;)
PostPosted: Tue Nov 12, 2013 3:25 pm
:up: Fresh pic after some end of season cleaning:
tumblr
PostPosted: Tue Nov 12, 2013 3:51 pm
:thumbup:
Are you ever in Sweden?
PostPosted: Tue Nov 12, 2013 5:51 pm
I really like the monochromatic theme on this bike, and how only the gum sided tubies and the Iride Colnago badge break it.
very well done, the early Hyperons without red accents are the best looking to my taste.
The only things I would "improve" on this bike would be a less bulky saddle and a horizontal top tube....
PostPosted: Tue Nov 12, 2013 5:55 pm
It looks very nice!
PostPosted: Tue Nov 12, 2013 6:07 pm
Hey @Eurperg, really nice setup and always good to get it all clean again. I know you like to ride in some pretty nasty weather and less than perfect roads and I know you've had at at least one set of Arenbergs. I love the Arenbergs but have only used them on paved roads with little debris. I don't care about rain or water but now that fall/winter is here there's a lot more crud, sand and leaves etc on the road. So, before I have to change tires again, I was wondering if you've used the Arrenbergs with your C59 on some of the unpaved roads you ride on . There's not a lot of clearance between the front tire and fork crown so just wondering if you found it an issue at all. I have no issues with rain etc. The older 24mm Veloflex Roubaixs were actually a perfect size for the C59 I thought. What do you think?
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Tue Nov 12, 2013 6:35 pm
perfection
There are no new unread posts for this topic. Colnago Super vs Colnago Master X-light
Kupepe
Sun Jan 08, 2017 6:57 pm
Kupepe View the latest post
Kupepe
Tue Jan 10, 2017 8:19 am
Zakalwe View the latest post
There are no new unread posts for this topic. Just another black Evo build: 6.1kg (Update: Build finished)
mcinco
11
2064
Thu Aug 03, 2017 3:29 pm
mcinco View the latest post
There are no new unread posts for this topic. Attachment(s) New Colnago
E90
Tue Aug 15, 2017 6:16 pm
E90 View the latest post
There are no new unread posts for this topic. what's going on with Colnago
fromtrektocolnago
Fri Mar 10, 2017 4:04 am
Selmer View the latest post
Users browsing this forum: Baidu [Spider] and 13 guests
