Post new topic Reply to topic  [ 24 posts ]
Go to page Previous  1, 2
 Post subject: Re: S-Works Venge Di2
PostPosted: Tue Dec 11, 2012 4:42 pm
HOCHPROFIL wrote:
not the best frame choice for a basketballer......nice built, but in this size : :frightened:
@Hochprofil: which big frame do you think looks good?
power2max
PostPosted: Tue Dec 11, 2012 5:10 pm
BIG bike! Looks good. Enjoy it.
PostPosted: Tue Dec 11, 2012 5:56 pm
All i can say is WOW ! :shock: :thumbup: A very very BEAUTIFUL BIKE ! ENJOY IT. :beerchug:
PostPosted: Tue Dec 11, 2012 6:47 pm
AttacknowAttackoften wrote:
Holy headtube, Batman! :unbelievable:
Where's the battery?
It's inside the massive headtube!... only joking, it's in the seatpost.
Here are some photos of the build and my hack job with the battery.
PostPosted: Tue Dec 11, 2012 7:01 pm
LOL Not sure I see what you did there.
Why strip the battery, then wrap it in tape? What's that do?
I only train on days that end with "y".
Eli
PostPosted: Wed Dec 12, 2012 12:48 pm
Serious question?...
1. Physical dimension - casing adds about 5mm around the edge and would never fit within the post
2. Connectivity - see attached
File comment: another example
PostPosted: Wed Dec 12, 2012 1:39 pm
Cool...I haven't been around long enough to see those. Maybe do that on my Caad10 (take it from under the bb), but then I'll have to get inside the bike and change the wiring, right? How do you pull the wiring up through the seat-tube? Also, how small is the battery? Small enough to fit in 27.2 or no way? The second picture makes it look like...maybe! My battery looks like no way (Ultegra).
Eli
PostPosted: Wed Dec 12, 2012 2:27 pm
Yeah, it's heaps cleaner and makes sense to go internal. The battery charge lasts for a very long time. I actually got the Ultegra electronics kit as it had superior cabling at the time, but the battery is the same for DA.
Battery size shouldn't be an issue as you can separate the two cells (about AA in size), solder together and create a tube shaped unit for standard posts.
If you have a standard Di2 fit out, all you need to do is route the battery cable up inside through the seat tube. I used a piece of steel wire with a bent hook to grab the cable from inside the BB area. If your stock cable isn't long enough, you can order different lengths from a Shimano dealer. Just measure your seat tube and allow a bit of slack for connecting / disconnecting with the post removed. You will see that I actually took the socket from the stock battery holder and the socket from the base of the battery housing and they are connected together within the seat tube. This is important as the Ultegra unit has small circuitboards inside these parts which are required for the whole system to function so they must be retained. Secondly, they allow for easy charging as you can place the socket part from the original battery case into the Shimano charge unit to charge - without having to remove the battery from inside the seatpost.
You will need to be careful not to short the battery or even worse connect with wrong polarity as you can blow not only the battery - but the whole DI2 circuit (circuitry in the derailleurs I believe). Not for the feint hearted! I can try and post a guide if I get time.
Otherwise, wait a couple of month for Shimano to release the Di2 internal battery (tubular shaped designed for seat post installation) - part no SM-BTR2. Exactly the same as above but will probably sting you about $150 USD though.
File comment: example
PostPosted: Wed Dec 12, 2012 3:04 pm
Fascinating. When/if you find time to post a guide, please shoot me a PM and let me know? I'd love to try this (read: have my buddy Mike try this, who is heaps more handy than I am).
Cheers
Eli
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Users browsing this forum: giant man, woz9683 and 28 guests
This topic is locked, you cannot edit posts or make further replies. Attachment(s) S-WORKS Venge or S-WORKS Tarmac SL4
elliott123
Wed Feb 13, 2013 4:38 pm
elliott123 View the latest post
There are no new unread posts for this topic. Specialized S-works Venge Di2 2013
nagge
23
3614
Tue May 21, 2013 7:09 am
nagge View the latest post
There are no new unread posts for this topic. Specialized S-Works Venge Di2 Battery Mount
Lionlin
12
1863
Wed Apr 17, 2013 3:57 pm
Lionlin View the latest post
There are no new unread posts for this topic. S-Works Venge; Now with 2013 Upgrades (new pics on the way)
Chadbus25
25
7763
Tue Feb 05, 2013 9:00 pm
Chadbus25 View the latest post
There are no new unread posts for this topic. S-WORKS Venge + SRAM Red 2012 and Speed Concept 9.9 Di2
StoneRoses
Sat Jun 09, 2012 1:48 am
pmr View the latest post
It is currently Tue May 21, 2013 2:58 pm
