Post new topic Reply to topic  [ 14 posts ]
 Post subject: Storck Fenomalist
PostPosted: Sat Nov 03, 2012 9:07 am
Built this up last week, very happy with the ride so far. Frame took up a large part of the relatively small budget so couldn't go all out with the components, but still very pleased with the overall weight (for a size 59). I already had the wheels, everything else is new...
Not pictured with the final saddle as I need a replacement clamp kit to fit the rails, and some lightweight skewers are on their way as well; once I realised I was looking at a lower than anticipated weight I decided to use the minor contingency budget to get as close to 6.8kg as possible.
All weights verified by my kitchen scale (except for the skewers as they're in transit)...
Frame: Storck Fenomalist 59cm - 1089
Fork: Storck Stiletto 300 - 358 (cut to length)
Seatpost collar: Storck - 0 (incl in frame weight)
RD hanger: Storck - 0 (incl in frame weight)
Headset: Acros - 96 (includes expander, topcap + bolt)
Cage bolts: Storck - 0 (incl in frame weight)
Shifters: SRAM Red Black - 326
FD: SRAM Rival + Token chain catcher - 91
RD: SRAM Force - 173
Chain: KMC X10SL - 239 (cut to length)
Cranks: SRAM Red Black 175mm 53x39 GXP - 679
Bottom bracket: SRAM Red Blackbox GXP - 109
Brakes: Planet X Ultra Light CNC - 204 (includes pads + holders)
Cables: Gore Ride-On - 143 (inners, outers, ferrules, stops, cut to length)
Saddle: Selle Italia Flite 316 - 202
Seatpost: Ritchey WCS 1-bolt alu - 221
Handlebars: Ritchey WCS Classic 420mm - 248
Stem: Ritchey WCS C-260 120mm - 111
Spacers: BBB 5mm - 2 (on top of stem...)
Bartape: Deda - 44
Bottle cages: Elite Custom - 85
Pedals: Shimano PD-7900 - 251
Wheels: Corima Aero+ - 1415 (includes glue and magnet)
Skewers: Token TK221 - 45
Cassette: Shimano Ultegra 11-23 - 206
Tubulars: Vittoria Corsa CX 23mm - 488
Total : 6825gr
Storck Fenomalist 6.8kg
 Post subject: Re: Storck Fenomalist
PostPosted: Sat Nov 03, 2012 4:18 pm
I was just about to ask you how much it weighs, never mind..
The red valves and chaincatcher are a nice touch.
PostPosted: Sat Nov 03, 2012 7:10 pm
Very well chosen list of componants. A superb looking bike all round. It looks crazy stiff.
PostPosted: Sat Nov 03, 2012 10:29 pm
Not only that, the new skewers will be red too 8)
PostPosted: Sun Nov 04, 2012 2:00 am
Nice looking rig (and excellent weight!)
PostPosted: Mon Nov 05, 2012 12:12 am
Thanks and yeah I was quite impressed with how light the frame was considering the size. 1089 including all the hardware must mean it's very close to 1kg for the bare frame. The white paint must add a fair bit as well (isn't it supposed to be the heaviest as you need more layers?)
PostPosted: Wed Nov 14, 2012 11:36 pm
May I ask you what your seat height is?
I'm currently deciding between a 57 and a 59 Fenomalist....
“I want to clear my conscience. I don’t want to be part of the problem any more.”
PostPosted: Fri Nov 30, 2012 9:30 am
Ilike your Storck. :)
PostPosted: Mon Dec 03, 2012 9:12 am
Sorry for the late reply!
Seat height, measured along the seattube, is 79.5cm.
The reason I went for the 59 compared to the 57 was the increased stack height.
PostPosted: Mon Dec 03, 2012 12:10 pm
Couple more pictures. Quite happy with the Planet X brakes, they perform OK and are very well priced.
PostPosted: Thu Dec 20, 2012 6:48 am
Pictures of component weights for future reference:
Frame:
Storck Fenomalist, 59cm, including seatpost collar, rd hanger and bottle cage bolts: 1089gr.
The dog paying close attention as well:
Fork:
Storck Stiletto 300, original weight: 372gr.
Ended up being 358gr after cutting to length
Headset:
Acros, 65gr.
Weight includes two fork crowns, fork required smallest one, saved 5gr.
Topcap and expander:
Acros, 36gr.
PostPosted: Thu Dec 20, 2012 7:01 am
Shifters:
SRAM Red Black, including uncut inner cables, 326gr.
Shifters only, without cables, 299gr.
FD:
SRAM Rival, stock standard, 89gr.
With Token chain catcher, and a replacement aluminium fixing bolt, 91gr.
RD:
SRAM Force, 173gr.
Chain:
KMC X10SL, 252gr uncut.
Ended up as 239gr after cutting some links.
Cranks:
SRAM RED Black, 175mm, 53x39, GXP, 679gr.
BB:
SRAM RED Blackbox GXP (ceramic), including spacers, 113gr.
Spacers not required on road bike, saves 4gr.
Brakes:
Planet X Ultra Light CNC, including pads and holders, 204gr.
Yellow King pads (for carbon wheels) increase the weight by 9gr.
Cables:
Gore Ride-On, stock SRAM stuff, uncut, excluding shift inner, 228gr.
After cutting everything to length, total inner (incl shifter) + outer cable weight totals 170gr.
PostPosted: Thu Dec 20, 2012 7:08 am
Saddle:
Selle Italia Flite 316, 202 gr.
Seatpost:
Ritchey WCS 1-bolt alu, 221gr.
Had to replace bolt kit (saddle has oval rails), this increased the weight by 1 gram, but cutting the seatpost down saved 18. Total current weight: 204gr.
Bars:
Ritchey WCS Classic 420mm, 248gr.
Stem:
Ritchey WCS C-260 120mm, 111gr.
Bartape:
Deda, uncut, 44gr.
Spacer:
BBB, 5mm no picture unfortunately, 2gr.
Bottle cages:
Elite Custom, x2, 85gr.
Pedals:
Shimano PD-7900, 251gr.
PostPosted: Fri Dec 21, 2012 2:26 pm
Great looking build - excellent detail, love seeing component weight like that. Enjoy!
Fear is healthy, panic can be deadly
Users browsing this forum: fa63, Google [Bot], JamieG, nickf, vfb and 27 guests
There are no new unread posts for this topic. Storck Fenomalist
Neuman
Thu Jul 12, 2012 3:06 am
Neuman View the latest post
There are no new unread posts for this topic. Storck Fenomalist Di2 or Look 695 SR?
FatAndSlow
Mon Mar 04, 2013 11:16 pm
luckypuncheur View the latest post
There are no new unread posts for this topic. Attachment(s) Storck Fenomalist Frameset
Dougan
Tue Jun 11, 2013 5:19 pm
Dougan View the latest post
Dougan
Fri May 10, 2013 11:15 am
There are no new unread posts for this topic. Storck Fenomalist size 57 6.3 kg. new pictures page 2
[ Go to page: 1, 2, 3, 4 ]
Elrey
45
4941
Sat Jan 26, 2013 9:01 am
Juggler View the latest post
It is currently Wed Jun 19, 2013 11:11 am
