Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: Re: 2012 Cervelo R5 VWD
PostPosted: Mon Oct 22, 2012 5:32 pm
i'm 5'9 with shorter legs and a longer torso.
my S2 and S5s were both 51cm, fitted by a shop that always put me on the smaller size but most other shops recommended i be on a 54cm. i always felt a little cramped and compressed on the 51s even with a longer stem.
after a lot of back and forth, i finally decided to go with the 54cm as i simply felt more comfortable while still being in a fairly aggressive position and i love how the bike feels and more importantly how i feel on the bike.
hope this helps :)
PostPosted: Mon Oct 22, 2012 5:54 pm
gosh exactly the same height/body dimensions as me, thanks Stepehen, enjoy your R5 mate!
PostPosted: Tue Oct 23, 2012 12:47 pm
Nice R5! I've got the same height as you and decide the same size also, hope it fits me :D
PostPosted: Tue Oct 23, 2012 3:22 pm
thanks !
i was kinda in between 51 and 54, but found the 54 to be much more comfortable, and never found a comfortable position on my 51cm S5 Team.
PostPosted: Thu Oct 25, 2012 2:15 pm
a couple updates
- steerer tube has been cut down
- picked up a Fizik Kurve Chameleon, but might exchange for the Bull after a few test rides
will post some new pictures soon
PostPosted: Fri Oct 26, 2012 3:47 am
*update*
- Fizik Kurve Chameleon Saddle
- Cut steerer tube
PostPosted: Sun Nov 04, 2012 4:41 am
hope this helps :)
Can you tell me what your saddle height is as pictured?
PostPosted: Sun Nov 04, 2012 1:40 pm
Thanks stephenjwhan, mine is done and very fit me with 130mm stem. My dimension is 555mm saddle-bar, 680mm saddle-bb :wink:
There's one thing I don't like about this frame is a handlebar stack, even I cut half of a headset cap off, it still higher than I get used more than 2cm :cry:
PostPosted: Sun Nov 04, 2012 9:35 pm
A true work of art.
My dream :) :thumbup:
PostPosted: Mon Nov 05, 2012 3:18 am
Get a -17 degree stem, that should help a bit
PostPosted: Mon Nov 05, 2012 6:37 pm
@Reamens - thanks !
@JummsBikeStudio - yes a -17 degree stem would definitely help or you can get an even shorter headset cap.
my shop already put on a shorter cap for me and then you can or you can do what ryder hesjedal does and remove the upper headset cover all together :)
PostPosted: Fri Nov 30, 2012 10:00 am
What a great bike! :)
PostPosted: Fri Dec 07, 2012 6:49 pm
nice photo
PostPosted: Thu Jan 10, 2013 9:29 am
hi stephen,
I'm building my R5 Vwd now..
and I see u were able to fit SRAM exogram bb30 crank.
I thought the SRAM exogram bb30 was too short to fit BBright frame?
can you give me some input? If i get the bb30 SRAM exogram crank set, how do i make it fit? are there any special adapters needed?
thanks!!
PostPosted: Thu Jan 10, 2013 3:20 pm
@dlin88 - you are correct ! the bb30 cranks do not fit in the bbright BB. my cranks are GXP and fit into the bb using the enduro bb adapter. it works perfectly fine. i know some people will complain that the adapter will reduce stiffness of the bbright bb, but for me, and this completely personal, i haven't noticed a huge difference. i also believe there is a rotor adapter but not sure if its just for rotor cranks. i've heard good things about that adapter system tho.
@lovestheclimb - in comparison to my previous S5 Team and S2, this bike much much more comfortable. i like the geometry on the 54cm, coming from the 51cm which i found to be a bit too compact and aggressive. on this geo, i can still be in a good position while being comfortable. with that being said, i might opt for a 100mm stem when the season starts, feel slightly stretched out, but that's on my trainer so maybe it'll feel normal again on the road.
thanks for all the compliments !
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: stuwright and 25 guests
There are no new unread posts for this topic. 2012 Campagnolo Chorus 11 Group - updated with picture
system787
Thu Feb 28, 2013 8:27 am
system787 View the latest post
There are no new unread posts for this topic. My 2012 Cervelo S2
therouler
Mon Sep 10, 2012 6:47 pm
petepeterson View the latest post
There are no new unread posts for this topic. CERVELO R5vwd 2012
Naturel
Fri Apr 19, 2013 7:26 pm
Naturel View the latest post
There are no new unread posts for this topic. 2012 Cervelo S5 with Ultegra Di2
wangsanegara
15
3156
Tue Nov 20, 2012 2:42 am
wangsanegara View the latest post
There are no new unread posts for this topic. 2012 Cervelo R3 Team
MikeR3
Tue Aug 21, 2012 3:57 pm
NGMN View the latest post
It is currently Wed May 22, 2013 2:58 pm
