Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sat Sep 22, 2012 5:03 pm
I just aquired a blue ac1sl frameset. I'm going to strip my addict sl and build this up. They're both size mediums, but the geometry on the addict was "doable" while the geometry on the blue (w/ a shorter TT) should be closer to ideal for me (the price was rather ideal as well). After I built up a time trial bike I've been wanting to go to an aero frame as well.
The addict built up to about 11.5 lbs w/ edge 1.45 tubulars and a little under 12.5lbs w/ the clinchers I use.
The blue frameset (frame, fork (uncut), headset, seatpost and those plastic thingies that keep the fork and dropouts stable in shipping) weighed 1851g, I figure I'll drop about 20-40g more switching out the steel bottle cage bolts & cable guide bolt for aluminum bolts and the seatpost clamp bolts for ti, as well as some small parts that are not needed for this frame.
The addict frameset (headset and seatpost/seatpost clamp included) as is weighs about 459g more, that's not taking into account me not cutting the new fork yet, I'd expect that to take the blue frameset to just under a pound heavier.
The rest of the build will be the same, except the parts that are on the new frameset (seatpost clamp, etc):
Front der- campy chorus tuned to 58g, all bolts and washers included
Crankset- zipp vumaquad (now I'll have to use the bb30 kit)
Saddle- ax lightness endurance - 77g
Rear Derailleur- Sram Red 136g (w/ some tuning)
Brakes- KCNC CB1 w/ swissstop yellow pads - 181g
Cable Adjusters on frame- ritchey 6g (for the pair)
Cable Housing and Liner - I-links and Mini I-links - 54g
FD & RD Cables - mini-I-link 22g (uncut)
Brake Cables- Power Cordz - 8g (F & R)
Shifters, Stem, Bars, Tape- Sram Red w/ btp clamps, Extralite OC 90mm, Ritchey superlogic II carbon, spugna tape- 591g
Fork expander- Extralite Ultrastar - 9g, Extralite Top Cap and screw - 5g
Rear Wheel- Edge 1.45, 24h, extralite hub, sram og-1090 11-26 cassette, m2 racer bolt-on skewer, magnet for speed sensor, Continental Competition 700x22 w/ valve extender (total weight 1001g)
Front Wheel- Edge 1.45 20h, extralite hub, m2 racer bolt-on skewer, conti comp 700x19 w/ valve extender (total weight 723g)
Chain- kmc x10sl, 226g
Now I just need a day to switch everything out and ride the new frameset to see if I'm going to keep both frames or sell the addict.
Speedplay is the devil.
PostPosted: Thu Sep 27, 2012 3:22 pm
just finished building, just under 14lbs with clinchers and 25mm tires on there. I have some work to do, there are areas I can shave some weight.
pics later, I'm gonna take it out for ride!
PostPosted: Thu Sep 27, 2012 5:22 pm
I really like these frames and considered getting one for myself, but the fit wouldn't work. Anyways, looking forward to seeing some pictures, it sounds promising.
My Bikes
My Photoblog
PostPosted: Fri Sep 28, 2012 8:49 pm
Here it is. I did 40 miles yesterday and I was impressed with it. Totally different feel than the addict. Harsher ride (not a biggie for me), definitely felt faster, need to do some more riding and comparisons to sort out reality from psychological BS, but the fit is a million times better.
I also need to pull my edge tubulars out and take it for a ride with those on there.
Users browsing this forum: CBJ, kavitator, MSN [Bot] and 19 guests
There are no new unread posts for this topic. New frame...light the blue touch paper
Monkeyboy3333
13
1185
Wed Feb 27, 2013 5:08 pm
sawyer View the latest post
There are no new unread posts for this topic. Salice 006 blue/blue for sale brand new
ferrarista
Fri Jun 14, 2013 4:13 pm
ferrarista View the latest post
There are no new unread posts for this topic. Replacing Red for heavier Ultegra Di2, worth weight penalty?
Tamu8104
Thu Nov 22, 2012 1:52 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Attachment(s) Blue AC1 SL LE
Sneakbox22
Mon Jan 14, 2013 8:14 pm
durh221982 View the latest post
There are no new unread posts for this topic. Blue Loctite Question
ipenguinking
Mon Jul 02, 2012 7:30 pm
Cheers! View the latest post
It is currently Tue Jun 18, 2013 10:20 pm
