Post new topic Reply to topic  [ 43 posts ]
Go to page Previous  1, 2, 3
PostPosted: Wed Sep 12, 2012 6:32 pm
BeeBee30 wrote:
You need one of these to go with your bar tape :lol: :shock:
I'd like a test ride or two before purchasing if possible... :grin:
Thanks for the info and pics, elviento! BB386 seems like a great idea to beef up the BB shell and all the tubes leading to it for greater stiffness regardless of the crankset used.
What about plans for commercialization of your Ti and carbon designs? I'm sure you'd have some buyers here...
sent by tapatalk because my computer is a paperweight
PostPosted: Thu Sep 13, 2012 5:50 am
I will be at Interbike and see what happens.
Will have a sub $800 frame to quench some ti thirst.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Thu Sep 13, 2012 8:04 am
Formerly known as CAADHEAD
Yeah it seems your right about BB30 cranks not fitting a BB386 frame, I was confused, it seems you can get adapters for it to work the other way, a BB386 crank in a BB30 frame. Its all about the width, BB30 is 68mm wide wheras BB386 86mm wide. I suppose it may be possible to fit a pseudo BB30 crank like a Vuma Quad or Rotor 3D+ as they have longer axles? I wouldn't want to stick an FSA crank on that beauty either :roll: So is any other manufacterer going to produce any BB386 chain sets then?
Ti or dye!
PostPosted: Thu Sep 13, 2012 11:52 am
Oversize HT on a bare finish I actually don't mind.
Well done mate.
PostPosted: Thu Sep 27, 2012 4:24 pm
Lightning cranks are pseudo bb386 compatible too. 86mm spindle from spider to NDS crank arm and 30mm diameter spindle, but you need to get the bearings flush to the frame edge for it to fit, as they tend to have a 1-2mm lip each side to ensure the bearings stay put. If you mill/ grind the lip off and insert a plastic internal spacer to keep the bearings in place and it should work. (in theory at least!)
PostPosted: Thu Sep 27, 2012 7:02 pm
I like it, bar tape and all :-)
Sent from my Nexus 7 using Tapatalk 2
Ride faster not harder!
PostPosted: Fri Sep 28, 2012 3:15 am
Very nice bike! I want one ti seatpost for me where I can found one like yours? :D
PostPosted: Fri Sep 28, 2012 3:22 am
Bellissima.
:thumbup:
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Fri Sep 28, 2012 6:32 am
Location: somewere floating between here and the other side
Looks very nice indeed, what diameter down tube did u use, it looks substantial ! Could I ask for a picture ? If so could we have a photo(closes up) of the right side dropout ? I'm curios to find out how it looks (; I must have a thing for dropouts, but don't tell the misses! (;
PostPosted: Fri Sep 28, 2012 7:46 am
Thanks for your comments, gentlemen.
Here are a couple of more details, along with a dropout shot...
Down tube is 45mm, a 35g weight penalty over size 40mm tube but works well with a BB386 shell and lots of confidence on a descent.
twitter: Falco_bike
PostPosted: Fri Sep 28, 2012 11:36 am
Are suggesting something like this would be avelible for less than 800$ ?
PostPosted: Fri Sep 28, 2012 12:30 pm
elviento, I have found this frame on Ebay, along with the other (planned?) offerings.
What are the chances for the "hobby" line to get tyre clearance up to, say, 35mm, and a disc option?
Bikes: Raceur, Beateur
PostPosted: Sat Sep 29, 2012 8:51 am
Well, I am working on a Cyclocross model which will have different geometry. Definitely will be disc-ready. No V brake bosses. I am getting some tips from one of the Rabo boys so that's pretty cool. I'd like to get a 1.5 tapered head tube but it costs way too much to have anything tapered on ti, so I need to figure that out.
Michel2, the $800 frame will be straight gauge everything with road geometry.
twitter: Falco_bike
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: gbranden, LeePaton, nicrump and 19 guests
There are no new unread posts for this topic. san francisco roadie shop
canbakay
9
820
Sat Dec 15, 2012 6:17 pm
thecounty View the latest post
There are no new unread posts for this topic. Mountain bike fitting, for a roadie?
in MTB
ScottGoBlue
7
693
Tue Dec 25, 2012 4:45 pm
Geoff View the latest post
There are no new unread posts for this topic. Opinions - CX bike as a winter roadie?
alexh
23
468
Mon Apr 22, 2013 3:27 pm
alexh View the latest post
It is currently Sat May 18, 2013 1:03 pm
