New Project: Lynskey CX Disc
Ramjm_2000
by Ramjm_2000
After about a 5 month wait my Cooper CX Disc has finally arrived. On my other 2 Lynkseys (L3 Custom and Helix) I went with the Handbrushed finish but this time around I though I'd go with the Satin. I figured if I didn't like it could always take a scotchbright to it in the future. The finish reminds me of my old IF and is a pleasant change. As for weight she is definitely burly at 1502 gms but not too bad considering the massive tubes, and disc tabs. I also think the new seatpost shims (seatposts now 27.2 vs 31.6) Lynksey is using has contributed to a higher weight than previous models. Build is going to be modest since this will be doing double duty as my work commuter and cross bike and consist of a Campy 10 sp Record/and newer Veloce (mid-cage RD and Ergos). Wheelset will be NOS Stans 29r 355 laced to CK ISO Disc hubs spaced via Ergott's shim method. Fork will be a Wound Up Team Disc.
limba
by limba
Ti is too heavy and too expensive for me but I'm sure this bike will be awesome.
SWijland
by SWijland
Great build! Not feeling the fork though. Seems a bit low end for this bike. A Whisky carbon fork would be much better IMHO.
Ramjm_2000
by Ramjm_2000
Funny you say that because I considered it and had I gone Whiskey it would have been at least $100 cheaper and about 30gms heavier. Unless you go tapered the Whiskeys come with alloy steerers. Given the choice with close weights, I'll go hand made in the US whenever I can (Whiskey is just Woodman relabeled). Ride quality wise, both are familiar to me (my Ti Spicer had a Woodman) and I most definitely prefer the Wound Up.
Stolichnaya
by Stolichnaya
Wound Up low end?
Whiskey high end?
:roll:
jooo
by jooo
Ramjm_2000 wrote:Wheelset will be NOS Stans 29r 355 laced to CK ISO Disc hubs spaced via Ergott's shim method.
What?
Any particular reason for 355s?
Ramjm_2000
by Ramjm_2000
What?
Recommendation from local wheel builder. A bit taller side wall (vs. crest), more robust, and easier to get road tires on and off. Minimum tire size is 25c so my 32c commute and cross tires fit just fine.
jooo
by jooo
What about the shim deal?
Juanmoretime
Administrator
by Juanmoretime
:thumbup: Looks like someone will have some good dirty fun this fall. Good choice on the frame! :wink:
RESIDENT GRUMPY OLD MAN.
Ramjm_2000
by Ramjm_2000
Thanks :thumbup: . I've got some sweet single track I want to test her out with before the season starts.
