Post new topic Reply to topic  [ 35 posts ]
Go to page Previous  1, 2, 3
PostPosted: Thu Nov 15, 2012 11:10 am
The forces applied will be roughly the same from the outside in vs. from the inside out. I am pretty sure you will be safe, but contact Cinelli if you want to be sure.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Nov 15, 2012 1:27 pm
One is in compression and one is in tension. It would depend on the design of the tube. I would stick to tension based fixing as it is what the frame has been designed for if you run it with no supporting element.
The other option, if possible (and contradictory to my previous statement), is to get something like a KCNC seatpost, use an external clamp, cut the post short and clamp at the top. There would be a seatpost designed to be strong under compressive clamping force taking the load, so you reduce the risk of crushing the frame. It could work out >100g lighter than the current setup depending on how much tube you cut.
BMC SLC01
Visiting South West Australia? Visit Crank n' Cycles!
PostPosted: Fri Nov 16, 2012 3:03 pm
Rob English can build you anything you want:
- A custom cap, with setback if needed
- A Thomson seatpost modified to work like your current seat post. It weighs rather less than yours, but no setback. BMANX on here has one on his English, weight 96g.
3rd picture here.
http://fairwheelbikes.com/forum/viewtopic.php?f=2&t=7291
PostPosted: Fri Nov 16, 2012 3:37 pm
i've taken the very un-ww view that it's not worth chasing my tail to reduce the weight in this area. the bike is never going to be a 5.5kgs whippet, but instead, a very comfortable, stiff bike, ideally suited to longer rides. besides, i wouldn't want to compromise the aesthetic appeal which the bike currently enjoys.
viewtopic.php?f=10&t=109022
viewtopic.php?f=10&t=109000
viewtopic.php?f=10&t=105626
PostPosted: Fri Nov 16, 2012 6:44 pm
ultimately I went with the cut seatpost and collar combo clamped at the top of the mast route. See here: viewtopic.php?f=10&t=108931
The word "Brifter" should be banned.
Casati Vola SLi- viewtopic.php?f=10&t=108931" onclick="window.open(this.href);return false;
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Bing [Bot], mbaulfinger and 13 guests
There are no new unread posts for this topic. 2012 Cinelli Ram 2 Italo'79 colours - 130mm / 420mm c-c
fivethirtyonepm
Sun Apr 14, 2013 8:51 pm
fivethirtyonepm View the latest post
There are no new unread posts for this topic. Attachment(s) FS: Brand new in box 2012 Cinelli Pro Best of frameset XL!
veloman
Fri Mar 01, 2013 2:55 am
veloman View the latest post
There are no new unread posts for this topic. FS: Brand new Cinelli Pro Best of frameset - 2012 57cm tt.
veloman
Wed Mar 13, 2013 8:42 pm
There are no new unread posts for this topic. FS: Brand new Cinelli 2012 Pro Best Of frameset - size XL
veloman
Thu Mar 07, 2013 6:23 pm
There are no new unread posts for this topic. FS: Brand 2012 Cinelli Pro Best of frameset XL 57cm tt $1295
veloman
Thu Mar 21, 2013 4:21 am
It is currently Sat May 25, 2013 1:03 am
