It is currently Sat Jan 20, 2018 8:00 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4
PostPosted: Mon Dec 30, 2013 9:54 am
After picking up two cans of paint remover, I got busy removing the paint of the Salsa frame. I said 'super aggressive' on the can, which sounded like music to my ears, because a paint remover I purchased a while back didn't do anything to the paint I was trying to strip down back then. They weren't kidding with the 'super aggressive', because the stuff started working almost instantly after spraying it on the frame. It did the same on my skin unfortunately, even though I only got two tiny flakes of removed paint on my skin :? . For stripping the fork I will be using some Carbolift that was left over from a previous project. It doesn't work nearly as good as the paint stripper I used on the frame, but it beats sanding every day.
Next up is the painstaking task of polishing the frame. Seeing as the finish on the bare metal is quite rough, this will involve quite a bit of sanding before I can do the actual polishing.
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon Dec 30, 2013 10:14 am
By the way, before paint stripping I was able to do a more accurate weigh in of the frameset. With paint, the bare frame weighed in at 1320 grams. Removing the paint resulted in some 50 grams of weight loss. The fork is really porky at 670 grams.
PostPosted: Fri Jan 03, 2014 1:47 pm
I finished polishing the frame today :D . It isn't 100% perfect, but for the time being it will do just fine. Next up, the fork.
PostPosted: Fri Jan 17, 2014 2:00 pm
I have finished removing the paint of the front fork and polishing it and while I was at it I also did the same for a Deda Zero 100 seatpost. All that remains now is putting some parts on it. So far so good :D
PostPosted: Sat Jan 18, 2014 8:06 pm
top work!
look forward to seeing the final build
PostPosted: Thu Jan 23, 2014 6:19 pm
Is it wrong that I am physically aroused by this Salsa?
I am itching to do this to an older alu frame myself and don't trust my skills.
I'll PM you about this at some point, SWijland.
I'm watching this one...
There are no new unread posts for this topic. Winter Project
Ellipsis415
Sun Nov 19, 2017 11:02 am
bikewithnoname View the latest post
There are no new unread posts for this topic. Using your good bike through the winter?
mike001100
25
2567
Sun Oct 01, 2017 10:41 pm
fromtrektocolnago View the latest post
There are no new unread posts for this topic. Hub choice for winter bike
in Everything wheels
Bigger Gear
13
1437
Sat May 06, 2017 12:15 am
Asteroid View the latest post
There are no new unread posts for this topic. Focus Paralane winter bike
nemeseri
Wed Dec 06, 2017 2:49 am
Stickman View the latest post
There are no new unread posts for this topic. BMC RoadMachine02 as my new rain & winter bike
TonyM
16
2744
Sun Dec 17, 2017 7:52 am
dre_lo82 View the latest post
Users browsing this forum: Google [Bot] and 14 guests
cron
