Post new topic Reply to topic  [ 20 posts ]
Go to page Previous  1, 2
PostPosted: Sat Jul 21, 2012 1:39 pm
I'm looking forward to the stiffer springs. There actually quite simple to play with. I've already modded one set of Enve pads - but got a little carried away on the grinder - hence why I need the new set.
The ride quality of the bike is awesome, it's usually mainly for rural riding around Central Ontario - Muskoka.
PostPosted: Tue Jul 24, 2012 2:58 pm
Nice.
Di2 will tear those chainrings apart.
-Deacon Doctor Colorado Slim
PostPosted: Sun Jul 29, 2012 9:32 am
Beautiful. Hope you enjoy the ride, morrisond. Maybe you would consider taping over the battery mount hole on the down tube or put a screw there to prevent water from going in?
Cippo - nice work with the hidden battery. The F0.6 deserves simplicity.
Current Bikes: Storck F0.6 6kg , Storck Aero2 7.04kg
Storck Organic Light 11.1kg , Storck F0.7IS Di2 4.8kg
PostPosted: Sun Jul 29, 2012 5:47 pm
Yes you need to close that hole. I used a rubber grommit.
Another thing to note is if you have ridden your F0.6 in the rain you will need to take the seat tube out and let any water that may have gathered in the frame evaporate. Worth doing after cleaning also. Should be done even in normal circumstances but with a post mounted battery it's essencial.
PostPosted: Wed Aug 15, 2012 9:55 pm
Konky - thanks for the above.
Coloclimber you were right I switched to Praxis Dura Ace Style rings - much nicer shifting.
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google Adsense [Bot], theletterk and 21 guests
There are no new unread posts for this topic. Storck Fascenario 0.7 with new SRAM Red and Enve 3.4's
CippoForLife
Sat Jan 05, 2013 5:23 am
CippoForLife View the latest post
There are no new unread posts for this topic. Alchemy KVA MS2 Stainless with Di2 + hidden battery @ 14 lbs
CippoForLife
Tue Jan 08, 2013 1:52 pm
There are no new unread posts for this topic. Look 695 vs. Storck Fascenario 0.7
luckypuncheur
20
2385
Thu Nov 01, 2012 10:37 am
luckypuncheur View the latest post
There are no new unread posts for this topic. 2013 Storck Fascenario 0.6
konky
14
3146
Sat Jul 28, 2012 6:46 pm
konky View the latest post
There are no new unread posts for this topic. Enve 110mm stem & Enve 27.2mm layback post - both BNIB
BikeTart
Fri Apr 05, 2013 9:16 am
BikeTart View the latest post
It is currently Wed Jun 19, 2013 7:10 am
