Post new topic Reply to topic  [ 13 posts ]
 Post subject: Felt DA1
PostPosted: Mon Jun 11, 2012 9:30 pm
Pic of her on training wheels. Normally run a 90mm front with a disc rear.
Size 58cm
Rotor 3D Cranks with SRM
O Symetric 56 tooth ring
USE Bars
Looking at new wheels ideally some Enve 8.9 or Lightweight Disc (still undecided)
Also waiting on a new USE R1 bar
Front has been dropped by 1cm since this was taken.
ISM saddle has been removed and replaced with Fizik Ares.
Tester for PMR@cing / www.Biketart.com
 Post subject: Re: Felt DA1
PostPosted: Mon Jun 11, 2012 9:47 pm
We NEED more pictures of her. And a FULL buils spec. More detailed pics of the handlebars possible? :thumbup:
PostPosted: Mon Jun 11, 2012 9:54 pm
this thing is the business.
More pics and details!!! :popcorn:
PostPosted: Mon Jun 11, 2012 10:21 pm
Finally a bike in a normal size :kidding:
I'm 1.92 mtr so this is too small but.......
Great bike!
PostPosted: Tue Jun 12, 2012 6:17 am
Size 58cm
USE Bars
Wow, quite nice. Perhaps a 100mm x 60mm rise fixed position stem would suit your fit, too?
-SD
www.feltracing.com
PostPosted: Tue Jun 12, 2012 6:43 am
Hi SD
I use the 100mm stem at the moment. Is the thing to raise it the small adapter? I want the whole front end to be cleaner hence the bar change..It would mean no need to run adaptors on the frame.
I'll get some more pics tomorrow with race wheels on..
PostPosted: Tue Jun 12, 2012 7:07 pm
Wow, this is awesome!
I see you have the tt version (thicker & stiffer) of the Osymetric rings. Are spacers needed with these or were you able to just slap them on? I ask because I have the normal version (pretty thin) and I'm thinking spacers are needed between the rings to avoid chain rub, which I have in spades at the moment.
PostPosted: Tue Jun 12, 2012 8:26 pm
The front mech was set up by a friend with no spacers. There is however one on the mech mount to move the mech back for more clearance. 5mmthick. We also had to file the mech mount slightly to get more clearance.
The front mech is preloaded slightly for better/quicker shifting.
Shifting is perfect with zero rubbing.
I have the same set up on my road bike and again no rubbing. You just have to be careful on set up.
What size rings are you running?
PostPosted: Tue Jun 12, 2012 9:23 pm
As nice as it is and im sure it is very very fast but It does look a bit like something from wacky races .Im sure I saw Professor Pat Pending riding it.
PostPosted: Wed Jun 13, 2012 2:41 am
I have a set of 54/42s. They're 2mm thick. 1mm less than my Rotor Q rings and surely the reason for the chain rub between rings when in the small ring.
PostPosted: Sat Jun 16, 2012 9:00 am
Your not getting away with this mate, we need pictures and buildlists!!
PostPosted: Tue Jun 19, 2012 4:02 pm
Sorry - I will take some more pics tonight.
And a full build list.
Waiting on a new USE R1 bar to arrive to.
PostPosted: Tue Jun 19, 2012 4:21 pm
Sweet! If you could take some pics of the single parts and maybe the inside of the pods, that would be awesome.
I have the Tula and don't get how the new one works.
Thanks in advance.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
Users browsing this forum: Google Adsense [Bot], iswmhamc891, roadieboy and 31 guests
There are no new unread posts for this topic. Felt DA
Jman
Mon May 20, 2013 9:30 am
MarkGiardini View the latest post
There are no new unread posts for this topic. Felt F75 under 7kg
RMcC
Thu Jul 12, 2012 1:10 pm
Dimitri View the latest post
There are no new unread posts for this topic. Felt F3
johnnyha
Sat Mar 02, 2013 11:38 pm
johnnyha View the latest post
There are no new unread posts for this topic. Felt FC
system787
Sat May 25, 2013 4:34 am
system787 View the latest post
There are no new unread posts for this topic. Experiences 2013 Felt F1?
kojtl1000
9
1024
Fri May 17, 2013 3:21 pm
roadytracky View the latest post
cron
It is currently Sat May 25, 2013 5:46 pm
