Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Sun May 27, 2012 8:40 pm
stunning, looking forward to the full build pics :D
My bikes:-
- 2011 Boardman MTB Pro HT-10.22kg
- 2011 Lapierre DH 920-17kg
Carbon - Lightens your bike and your wallet
OCBD - Obsessive Compulsive Biking Disorder
PostPosted: Mon May 28, 2012 6:33 am
Couldn't resist this since the analogy to sports car assembly was mentioned....
The new Storck full sus vs my old faithful hardtail Colnago
Not too bad weight-wise for the Colnago too, considering this build was three years ago (8.6kg)
Closer shot -
Current Bikes: Storck F0.6 6kg , Storck Aero2 7.04kg
Storck Organic Light 11.1kg , Storck F0.7IS Di2 4.8kg
PostPosted: Mon May 28, 2012 9:16 am
denzity wrote:
If I pay you can I come round and spend some alone time with your frame?? That thing is BEAUTIFUL! Can't wait to see it built up :thumbup:
lol
PostPosted: Mon May 28, 2012 10:40 am
Online
Discoverspeed, I'm lost for words, I think I'm going to take up off road. Magnificent!!
PostPosted: Mon May 28, 2012 11:03 am
Thanks for the comments
@ denzity - if you fly to Singapore, it's on me. :thumbup:
@ konky - yes, you must take up off-road. It is both more technical on the build and ride
PostPosted: Mon May 28, 2012 11:23 am
Today's build update-
Handcrafted in Germany, built in Singapore
Cobalt 3 wheels launching on Rocket Rons
Pretty light. Front 1.54kg Rear 1.99kg (with rotors and skewers)
Slipping the wheel on... the blue spokes and blue rim edge complement Storck's corporate speed blue highlights throughout the bike
PostPosted: Mon May 28, 2012 4:20 pm
Great to see another Organic Light on this site....we share the same fondness for Storck :)
I have had a little over a year on the Organic Light and have some comments/advise for you.
The frame geometry is a little weird, with very steep angles (both seat and headtube angle), I usually like a very fast handling bike, but I believe the Storck with a 100mm fork is just to fast/nervous. I use a 120mm Fox, but if I should do it again I would go for a Lefty 140mm, which is a little longer than the Fox 120mm, but shorter than the Fox 140mm.
The rear suspension is a very efficient design, that are effected by chain torque, so when you hammer out of the saddle it stiffens-up, without the need for a lock out. While soft pedaling, or when riding downhill, the suspesion is 100% active. But also here I have found that I need to set up the rear shock different than other bikes. I usually like my suspension on the firm/efficient side, but when it comes to the Storck I run less pressure in the rear shock, so more sag, which gives a lower bottom bracket height, and better handling in corners. I usually bottom-out a couple of times per ride, but the suspension never feels inefficient. This is the best bike I have tried when it comes to climbing technical climbs, and I have cleared sections I have never made on any other bike (Rebellion 1.0, Scott Scale, Trek Topfuel, Trek Fuel EX, Adrenalin Carbon ++++). It has great traction when climbing with a constanst power on the pedals, but when you really put pressure on the pedals right before an obstacle, the suspension gets stiff, and shoots forward, and when you stop pedaling and shift your weight forward to get over the obstacle the suspesion soaks up the terrain.
It's also a very versatile bike, I have set it up with a solid build for normal trailriding, but when I use my 1004g Ax-Lightness wheelset, the bike is very fast against the clock.
The only downside I have found is that the chainstays don't allow for low q-factor cranksets.
www.sykkelplaneten.no
PostPosted: Sat Jun 02, 2012 1:51 pm
Completed today.
Final weight 11.1 Kg almost on the dot with the paper build estimate.
I actually like the wheels quite a lot
PostPosted: Sat Jun 02, 2012 2:20 pm
Online
I want I want
PS The wheels definately match the frame and look great.
PostPosted: Fri Jun 08, 2012 12:43 pm
I think this brings new meaning to the word 'acceptable'. Clearly you are a master of understatement. Thanks for sharing. I look forward to the next build.
PostPosted: Wed Jun 13, 2012 3:55 pm
mrfish - that should be an Organic 2. v :wink:
PostPosted: Wed Jun 13, 2012 11:43 pm
How does it ride? Looks like a very upright position. Also, is there much room for mud clearance on the rear triangle, the 'seat tube' part, on the non-driveside??
Another very nice build added to the collection of very nice builds :thumbup:
FELT AR0 Now sold.
Crit Weapon. CAAD10 105 W/Hollowgram chainset, Ksyrium SLR/FFWD F6R Ltd's
Velo Club Bristol
PostPosted: Thu Jun 14, 2012 6:30 am
Looks nice but kinda old school.. Geometry-wise it's like suspension frames from the early 2000's :noidea:
Slammed. Campy. Tubulars.
PostPosted: Fri Jun 15, 2012 2:04 am
@eurpeg - you are exactly right. This is a masterpiece collector's item for me as it marks probably the last incarnation of the Organic Light which was designed in 1995 and prototyped as the Organic in 1998. I understand that the Organic is the first completely carbon full sus frame in the world and it is still one of the lightest to date. It is no longer "on Katalog" but "on Application" basis directly from Storck. The significance of the Organic is not being the most modern piece of equipment out there now but "the one that started it all".
This bike is now a permanent collection piece at the Neue Sammlung (The International Design Museum Munich) der Pinakothek der Moderne in München which is the oldest museum in the the design world. The museum houses more than 80,000 objects in the areas of Industrial Design, Applied Arts and Graphic Design, making it the world's largest and most important collection of 20th and 21st Century design. More importantly for Markus Storck, the Organic now takes pride of place along German design classics like the Porsche and Volkswagen. A tremendous recognition for any bike designer and manufacturer.
No doubt that back in Germany, Markus Storck is already penning down the initial design of the Organic 2. Another superlative for sure.
PostPosted: Fri Jun 15, 2012 2:11 am
@TerribleCadence - sorry that the photo is not that clear but the carbon piece you see between the tire and rear shock is actually a full carbon "fender" designed to shield mud away from the rear shock. From the photo's side elevation shot, the tire clearance is not clearly shown but it is comfortably there. I will try to post another shot when I am back home from traveling.
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: civdic, Google Adsense [Bot] and 19 guests
There are no new unread posts for this topic. Broken Storck Organic Light frame wanted
in Wanted
Simon BP
Mon Apr 29, 2013 3:21 pm
Simon BP View the latest post
There are no new unread posts for this topic. STORCK FENOMALIST 2012 with Sram/FFWD
Dougan
Tue May 21, 2013 5:50 pm
davec View the latest post
There are no new unread posts for this topic. MAVIC CCU 2012 + LIGHT PARTS
elfuinha
Tue Apr 09, 2013 11:18 pm
elfuinha View the latest post
elfuinha
Mon Feb 18, 2013 4:24 pm
There are no new unread posts for this topic. MAVIC CCU 2012 + LIGHT PARTS + Fizik Antares 00 ... etc
elfuinha
Fri Mar 29, 2013 6:46 pm
It is currently Fri May 24, 2013 2:51 pm
