Post new topic Reply to topic  [ 32 posts ]
Go to page 1, 2, 3  Next
PostPosted: Sun May 27, 2012 1:40 am
Completed 1 June 2012 - 1 of 25 pieces world-wide in this scheme.
Looks intimidating huh?
Project started as:
To me, the Storck Organic (2012 Light version pictured here) best signifies the genius behind arguably the most innovative bike builder in the world - Markus Storck (doesn't he have a striking resemblance to Albert Einstein?). This frame has multiple design awards including the Red Dot and IF Award design prize as well as being nominated for the German National Design Prize.
According to Markus, only 25 pieces of this frame in the 2012 livery colours have been made. When I saw the factory photo, I was sold immediately. I understand that other owners include Governor Schwazenneger and Rubens Barrichello - apt for the "mean and fast" attributes that the Organic seems to convey, even as a bare frame.
Less talk, more photos. So here goes.....
Current Bikes: Storck F0.6 6kg , Storck Aero2 7.04kg
Storck Organic Light 11.1kg , Storck F0.7IS Di2 4.8kg
PostPosted: Sun May 27, 2012 1:58 am
Instead of a traditional build list, I am posting an exploded build photo!
One or two parts are still missing - see if you can spot them.
PostPosted: Sun May 27, 2012 2:42 am
This bike is going to be absolutely magnificent. Only word to describe it.
PostPosted: Sun May 27, 2012 4:34 am
Chainrings + bolts.
Valvecores.
Can't quite tell, but headset?
Lube for fapping.
PostPosted: Sun May 27, 2012 4:49 am
:shock: I am subscribed! Glad to see one built up proper.
Felt DA(RIP), Look 595, Merlin CR Works, Calfee Tetra Pro, Moots Vamoots
PostPosted: Sun May 27, 2012 5:14 am
Personally I would go with a different wheelset/skewers. Breakes do not match as well.
Glad you went with syntace on the other hand...
Looking forward to seeing it biult up.
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Sun May 27, 2012 6:01 am
Thanks for your suggestion. I was looking at Magura MT8 brakes, Ai2 Rotors (if they work with MT8), German:A fork, an older pair of ZTR Race-Tune Prince/Princess with Furious Fred tires which I own for a weenie build but decided to go with the factory parts from Storck as shown in the exploded picture above. The Cobalt 3 wheels have signature speed blue "spoke holders"and I suspect that is why Storck chose them. It looked really good on Storck's Adrenalin and Rebellion builds.
BTW, as a background, I am predominantly a road and TT guy. So I decided that this XC build will be skewed towards factory matching rather than absolute performance and weight. Yeah a bit unadventurous on the MTB side for me (an oxymoron in itself).
PostPosted: Sun May 27, 2012 7:55 am
Which are those pedals? They look like standard flatbed pedals. No cliplesss?
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Sun May 27, 2012 8:11 am
If I pay you can I come round and spend some alone time with your frame?? That thing is BEAUTIFUL! Can't wait to see it built up :thumbup:
PostPosted: Sun May 27, 2012 12:02 pm
:shock: This is going to be awesome! Cannot wait to see it built up.
PostPosted: Sun May 27, 2012 1:46 pm
The Build List
Similar to the Fascenario F0.6 that I am building in parallel, I intend to build the Storck Organic Light using almost all Factory options. I believe I can shave off a kilo or more by using lighter parts but I think this list is acceptable for a good initial build.
1. Storck Organic Light Frame module 2012 (17" with fox shock, THM BB30 cups, E-mount type XT FD and drop in headset bearings) - 2.695kg
2. Storck Seat Post SP249 in white (uncut) - 266.4g
3. Storck Stem ST139 in white 110mm - 166.2g
4. Storck Saddle Prologo Nago EVO Nack Carbon in white - 170.8g
5. Storck Duraflite Handlebar 31.8mm by Syntace (uncut) - 144.2g
6. Storck Grips classic - 98.4g
7. Storck Powerarm SL cranks by THM 175mm - 408.8g
8. Storck Headset Integrated Drop-in by Acros - 79.2g
9. Fox Fork 32 Float Fit RLC 100mm travel remote lock out QR15 white (uncut) - 1580g
10. Fox 15QR thru axle Front Skewer - 76.6g
11. Crank Brothers Rear Skewer with split lever system - 61.8g
12. Crank Brothers Cobalt 3 Front Wheel Thru Axle ::Twinpair Spokes System (Black rim/ Silver spokes/Blue spines/ Blue nipples) - 720.4g
13. Crank Brothers Cobalt 3 Rear Wheel ::Twinpair Spokes System (Black rim/ Silver spokes/Blue spines/ Blue nipples) - 871.8g
14. Schwable Rocket Ron Evo Tires 26x2.25 (1 pair) - 983.8g
15. Inner tubes and valve (1 pair) - 386.4g
16. XTR Brake Rotors ICE Tech Front and Rear 6 bolts mounting - 248.6g
17. XTR Brake Rotor bolts - 32.3g
18. XTR Brake Lever with hydraulic hose and brake calipers (Front) - 275.8g
19. XTR Brake Lever with hydraulic hose and brake calipers (Rear) - 285g
20. XTR Shifters (1 pair) - 236g
21. XTR Rear Derailleur - 175.8g
22. XTR Chain (uncut) - 270g
23. XTR Cassette with lockring - 257.4g
24. THM BB30 cup and bearing - 78g (included in frame weight)
25. XT Front Derailleur (E-Type) - included in frame weight
26. Fox Rear Shock - included in frame weight
27. Head cap and Starnut by Acros - 25.6g
28. Shimano Brake Cables (uncut) - 150g
29. Pedals - Xpedo Face Off 18 Platform Pedals - 383.4g
30. Chain rings and bolts - TBC (likely Extralite Rings and bolts, 119g)
Total Paper Build Weight: 11.3 kg
Let's see where it will end up.
PostPosted: Sun May 27, 2012 2:20 pm
Frame module including Fox rear shock, FD, Headset bearings, BB30 cup and bearings - 2.695kg
PostPosted: Sun May 27, 2012 2:51 pm
Some of the more interesting components:
Fox Fork F32 Fit RLC 100mm travel QR15 thru axle version with Remote Lockout (special non-kashima version - Storck insists that the "gold" kashima will not match the bike). No place for a warm color in an essentially cool scheme- 1580g.
Storck Powerarm SL carbon crank 175mm (more exclusive cousin of Clavicula, both produced by THM) - 408.8g
Crank Brothers Cobalt 3 ::Twinspokes wheel set - 720.4g (F) + 871.8g (R) = 1592.2g (pair)
One of Storck's corporate colors is "Speed Blue". You often see spots of blue details in Storck's bikes and equipment. This pair of wheels puts the necessary dash of corporate speed blue into the overall white-black theme.
PostPosted: Sun May 27, 2012 3:02 pm
Other Storck co-branded pieces -
Saddle by Prologo Nago EVO Nack - 170.8g
Seat Post SP249 by Syntace - 266.4g (uncut)
Stem ST139 by Syntace (110mm) - 166.2g
Storck full carbon Duraflite handlebar (uncut) - 144.2g
Storck Grips Classic - 98.4g
PostPosted: Sun May 27, 2012 8:28 pm
This thing is looking like a sports car prior to assembly....cant wait to see it finished
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: CBJ, Meatball, Rippin and 29 guests
There are no new unread posts for this topic. Broken Storck Organic Light frame wanted
in Wanted
Simon BP
Mon Apr 29, 2013 3:21 pm
Simon BP View the latest post
There are no new unread posts for this topic. STORCK FENOMALIST 2012 with Sram/FFWD
Dougan
Tue May 21, 2013 5:50 pm
davec View the latest post
There are no new unread posts for this topic. MAVIC CCU 2012 + LIGHT PARTS
elfuinha
Tue Apr 09, 2013 11:18 pm
elfuinha View the latest post
elfuinha
Mon Feb 18, 2013 4:24 pm
There are no new unread posts for this topic. MAVIC CCU 2012 + LIGHT PARTS + Fizik Antares 00 ... etc
elfuinha
Fri Mar 29, 2013 6:46 pm
It is currently Thu May 23, 2013 8:20 pm
