Post new topic Reply to topic  [ 73 posts ]
Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Jul 05, 2012 11:32 am
Noticed that some of the latest posts here make reference to installation issues.
I thought that it would be a good idea to share two other installation issues to help others properly set up their Storcks.
1. BB cups - the below is direct advice from Storck
"Please only assemble the BB shells with ca. 8nm and not the 40nm that is in
the manual. The 40nm is for aluminium frames; carbon frames cannot be
subjected to these stresses during assembly. Please do not forget to use
Loctite to securely hold the BB shells in the frame."
2. Acros Ceramic Headset - I have come across some discussion in other posts about where to put the orange seal so this illustration shows how the headset should be installed properly
Current Bikes: Storck F0.6 6kg , Storck Aero2 7.04kg
Storck Organic Light 11.1kg , Storck F0.7IS Di2 4.8kg
PostPosted: Thu Jul 05, 2012 12:46 pm
Thanks for the info....we have been using that orange seal on the top of the HS for a long time with no issues....it works there as it creates a seal between the top cap and the bearing sureface. Are you positive it should be used on the bottom?
www.royalbicycles.com
PostPosted: Fri Jul 06, 2012 12:52 pm
Yes - the Acros installation photo is from Storck Technical Dept.
I installed the orange seal at the top before and it works fine but the lower head tube-fork crown transition area was disjointed and looks like a sure thing for collecting road grime. As there is more grime build up at the fork-lower head tube area, the seal should be there. I agree with you that there should be an additional seal between the top cap and bearings - I guess Acros believes the compression sleeve is sufficient to block out dirt.
PostPosted: Fri Jul 06, 2012 1:17 pm
Ok....will try it out but I agree with you that 2 seals would work better.
PostPosted: Mon Jul 09, 2012 2:57 am
Has anyone else with a 0.6 Noticed on the Front fork that Brakes are not equidistant for the rim?
The Rim is Centered but the non drive side Brake projects out from the side of the Fork 1-2 mm more than the drive side.
You can compensate by sanding that pad more, but it's really thin! (I Have ENVE3.4's) whereas the other pad can go in with almost no sanding.
Is there a way to adjust this?
PostPosted: Mon Jul 09, 2012 2:48 pm
I have the same issue with the same wheels....talked with THM about it and the only option is sanding the pads when using the ENVE Smart wheels or the ZIPP firecrest.
But you are correct, one side needs minimal sanding while the other has probably being sanded down half.
PostPosted: Mon Jan 14, 2013 1:00 pm
Beautiful bike. If I had the means I'd swap my stable of Scotts for Storcks.
PostPosted: Mon Jan 14, 2013 10:55 pm
Beautiful bike, very sexy!
At the end of the day, I would give up my bike and riding for the rest of my life for your backyard though :waving:
PostPosted: Tue Jan 15, 2013 2:11 am
Updates:
1. Lightweight Meilenstein Obermayer front (Special Edition for Storck with aero-hub & decal)
2. Lightweight Fernweg rear
Just swapped the rear wheel, forgot about the big ring - sorry. :D
PostPosted: Tue Jan 15, 2013 2:16 am
Got the baby signed by the maestro himself...
PostPosted: Tue Jan 15, 2013 2:27 am
Baking in the Sun
PostPosted: Tue Jan 15, 2013 5:22 pm
Some serious bike :beerchug:
Long Front valve.
Louis :)
http://www.ccsalma.com
PostPosted: Wed Jan 16, 2013 1:37 am
Thanks and good catch. Was about to snip the valve off.
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5
Users browsing this forum: Vuong05 and 18 guests
There are no new unread posts for this topic. Attachment(s) storck aero 2 is +storck 0.6
assikabir
Thu Aug 23, 2012 7:26 pm
benrosa View the latest post
There are no new unread posts for this topic. Storck Rebel Nine
msl1985
Wed Sep 26, 2012 11:20 am
1spd View the latest post
There are no new unread posts for this topic. Identify this Storck
mattharrop
Tue Jun 19, 2012 10:18 am
mattharrop View the latest post
There are no new unread posts for this topic. Storck Scenario 1.0
sjc166
13
2081
Wed Jun 13, 2012 6:38 pm
sjc166 View the latest post
There are no new unread posts for this topic. Storck Fenomalist
Neuman
Thu Jul 12, 2012 3:06 am
Neuman View the latest post
It is currently Wed May 22, 2013 5:14 am
