Post new topic Reply to topic  [ 73 posts ]
Go to page 1, 2, 3, 4, 5  Next
PostPosted: Sun May 27, 2012 1:01 am
UPDATED Final Pic (more in later posts)
In German but you can probably make out what the title says
HOW IT ALL STARTED:
First off, let me state that this build is not meant to be an outright weenie build. I have already done a previous 4.8kg Di2 weenie build on my Storck Fascenario F0.7IS some years back and I could satisfy the weenie bug in me by updating some of those parts to maybe shave off 100 grammes or so, but that is a separate topic.
For this current Storck Fascenario 0.6, I intend to build a more comfortable and rock-solid rig that I will use for my longer-distance rides of about 150km or so. The criteria is that the components must work with the frame as a whole to wrap me in comfort, better handling and safety.
Having laid out the ride criteria, I also do not want to sacrifice the overall weight too much. My target is to have the final build come in at between 5.5 to 6kg with almost all "everyday" parts. Fellow weenie konky had previously pushed the weight envelope with his superb sub 5kg Di2 F0.6 build (http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=99320&hilit=best+bike+storck) so my current "everyday" F0.6 build could be interesting as a comparison and for reference to potential buyers of the F0.6 as a daily ride (or as a weenie ride).
Let the build begin....
Current Bikes: Storck F0.6 6kg , Storck Aero2 7.04kg
Storck Organic Light 11.1kg , Storck F0.7IS Di2 4.8kg
Last edited by Discoverspeed on Tue Jan 15, 2013 2:29 am, edited 6 times in total.
PostPosted: Sun May 27, 2012 2:03 am
On the stand Mr. Storck F0.6, your case begins...
PostPosted: Sun May 27, 2012 2:44 am
Do you happen to have just the frame weight on this? I'm curious as to how it compares against the 0.7 with 233g TRP brakes. Also, spot on build.
PostPosted: Sun May 27, 2012 3:52 am
The Build List
As mentioned, this is not an all out weight weenie build but rather a build for "everyday ride" and comfortable enough for my longer 150km rides.
Emphasis is on comfort, ride quality, handling and safety. Components are Storck factory recommendations (apart from the new wheels that Storck are offering which they promised are very special and will be launched at a later date). Groupset is a standard Shimano Di2 (apart from the pulleys which are color coded and crankset which has been changed to Storck's own Powerarms SL).
1. Storck Fascenario 0.6 scheme 2012. Frame size 51 (more like a 53) without fork, seat clamp and headset (with BB shell, BB bearings, front/ rear hangers, rear brakes and brake mounts) - 1.03kg. @konky weighed his F0.6 frame bare without BB shell, BB bearings and brake at 830g.
2. Storck Scapula F Fork by THM (uncut with integrated brake) - 378g
3. Storck Ceramic Headset by Acros (drop-in integrated) - 61g
4. Storck Top Cap and bolt - 11g
5. Storck Handlebar full carbon RBC 177 (42cm c2c, 31.8mm diameter) - 250g
6. Storck Stem F119 by Syntace, 6 degrees flop, Ti screws in speed blue (90mm) - 115g
7. Storck Saddle Prologo Nago EVO Nack carbon black - 170g
8. Storck Seat Post 185 Ultracomfort carbon 31.6mm (uncut) - 226g
9. Storck Seat Clamp by Token, alloy 34.9mm diameter (didn't want to fool around here) - 13g
10. Storck Powerarms SL crank by THM without chain rings or bolts- 388g
11. BB30 shell and bearings (included in frame)
12. Rotor Chain Rings 53/39T - 155g
13. Chain ring bolts in speed blue by Extralite "ExtraBolts"- 9g
14. KMC Chain gold - 240g
15. Look Keo Ti Carbon pedals (waiting for new Garmin/Vector power, wait and wait) - 190g
16. Madfiber wheels tubular, ceramic hubs - 1085g
17. Veloflex Extreme Tubulars - 460g pair
18. Recon cassette 11-25 with Mowa lock ring - 109g
19. Carbon Ti skewers - 35g
20. Brake pads cork by Madfiber - 26g (the only brake thingy that needs to be added!)
21. Di2 Groupset less crank, chain rings, brakes and BB (as estimated via konky's build list) - 836g
22. Storck Microfibre bartape and cap (estimated) - 45g
23. Shimano brake cables - darn it, didn't weigh - I estimate about 100g or so
24. Others - grease, glue.....
Total paper build 5.9kg (with uncut fork and seat post). Fair enough, within my target weight range with Storck's factory components.
So let's see....
PostPosted: Sun May 27, 2012 5:21 am
Frame module size 51 (sloping size equivalent more to a conventional size 53) including BB shell, BB bearings, front/ rear hangers, rear brake mechanism and holders - 1.03kg.
Frame is closer to low 800g without the BB and rear brake (this is the 2012 full matt black version without the older scheme's shiny paint protection stickers which add quite a few grams). Not to mention the big Storck badge that takes pride of place on the head tube - additional weight but who is to argue with tradition? Other ww frames have their badges painted on.
The F0.6 bare frame is only a shade heavier than the previous Storck weight weenie champion, the F0.7IS I believe. However, the comparison is not direct as the F0.6 is Di2 ready with additional internal cable channels. So on a like for like basis, the F0.6 frame weight is probably on par with the F0.7IS. The main difference however is in it's ride, with the F0.6 touted as plushier.
PostPosted: Sun May 27, 2012 5:40 am
Another gorgeous build to add to the collection. Looking forward to this one also. :beerchug:
Felt DA(RIP), Look 595, Merlin CR Works, Calfee Tetra Pro, Moots Vamoots
PostPosted: Sun May 27, 2012 5:47 am
Selected weight shots. Thought I would show only the Storck matching components as the other stuff have been posted before in other threads.
Handle bars weigh quite a lot and has a very aggressive drop of 40. Understand Storck has another bar coming out later this year which is more weenie
Sorry for the shaky shot here - the best wrench dens are a bit dark
PostPosted: Sun May 27, 2012 6:17 am
Now, should I or shouldn't I.... haven't got the guts to use them since buying them years back.
Maybe no, as this is a daily ride and I have punctured 6 times this year.
PostPosted: Sun May 27, 2012 10:28 pm
Discoverspeed I just find this build so exiting. You're right in saying the the thing with this bike isn't weight. If you want a light bike get a Cannondale Evo and save a bit of money. The 0.6 is about ride. It's unbelievable.
Two tiny comments about your build if you don't mind. For that build I'd go for a Dura Ace 7900 cassette instead of the recon. And the Tune U20 skewers are no heavier than the ones you feature and are in my view are the best skewers out there regardless of weight.
Good luck with the build.
PostPosted: Mon May 28, 2012 11:35 am
Thanks konky. Yes this frame is designed for pure riding indulgence and must be built that way to squeeze the most out of it. I will switch back to the original DA cassette after I grind the Recon out. I bought the Recon initially as spare for the 0.7IS but might as well use it now.
PostPosted: Mon May 28, 2012 12:24 pm
Hi guys, the initial build is complete.
Note: Saddle angle not adjusted properly in this shot
My "plushed up" Fascenario 0.6's final weight is 6kg - just on the dot of my upper target and pretty close to my paper build estimate.
In fact the build weight was spot on my paper build estimate based on the workshop photo below of 5.85kg (without bar tape and cage) before I started fattening it up with remote shifters etc).
This is built the way I like to ride it - indulging in remote satellite rear shifters, adding an additional computer mount, more sturdy bottle cage, more comfortable seat post and saddle etc. By my calculations and demonstrated by konky's aforementioned build, if I had used all the uber light stuff, this build will be closer to the 5kg mark. As konky mentioned, there are cheaper frames to achieve this and the Fascenario 0.6 is better appreciated as a super ride and not the lightest ride.
PostPosted: Mon May 28, 2012 12:41 pm
Spot on build. Congratulations. I absolutely love it. You're going to be in rider's heaven.
PostPosted: Mon May 28, 2012 12:52 pm
Had a chance to take the F0.6 out for an acquaintance and fine tuning ride this morning.
All I want to say at this point is WOW, a superbly controlled, comfortable and balanced ride. I haven't felt such a rush in the feeling of "can this be true?" for any new ride (and I had plenty) for a long long time.
The last time I felt such a good connection between rider and bike was when I first rode the Prince and that was more than a decade ago. Since then, on roadies alone I had three more Princes, a Dogma, a F0.7, F0.7IS and S5 - all good in some way but also weak points for each. It is very rare for both the bike and rider to communicate and sync with one another - sometimes the bike overpowers and controls you, sometimes you need to put in a lot of effort into the bike before it responds. Rarely does a bike understand you as one. I think experienced riders know exactly what I am saying. The Fascenario 0.6 is an extension of you. It is part of you.
I cannot fault the F0.6 in any way so far - I can fling the bike, pump the bike, brake hard, sprint etc. Definitely 10 out of 10 right now from me. Putting aside euphoric scores that normally accompany new rides, note that my other new ride scores have barely hit 8 on first rides (and it gets downhill from there) so there is already a significant difference in ride quality right off the starting block.
I will post a long term ride report at a subsequent date.
PostPosted: Mon May 28, 2012 1:02 pm
More first ride shots
PostPosted: Mon May 28, 2012 1:16 pm
Details
Storck's corporate "speed blue" dashes of color everywhere. Subtle and classy.
Post new topic Reply to topic  [ 73 posts ]  Go to page 1, 2, 3, 4, 5  Next
Users browsing this forum: deltree, gbranden, giant man, Google Adsense [Bot] and 31 guests
There are no new unread posts for this topic. Attachment(s) storck aero 2 is +storck 0.6
assikabir
Thu Aug 23, 2012 7:26 pm
benrosa View the latest post
There are no new unread posts for this topic. Storck Rebel Nine
msl1985
Wed Sep 26, 2012 11:20 am
1spd View the latest post
There are no new unread posts for this topic. Identify this Storck
mattharrop
Tue Jun 19, 2012 10:18 am
mattharrop View the latest post
There are no new unread posts for this topic. Storck Scenario 1.0
sjc166
13
2082
Wed Jun 13, 2012 6:38 pm
sjc166 View the latest post
There are no new unread posts for this topic. Storck Fenomalist
Neuman
Thu Jul 12, 2012 3:06 am
Neuman View the latest post
It is currently Thu May 23, 2013 6:15 pm
