Post new topic Reply to topic  [ 34 posts ]
Go to page 1, 2, 3  Next
PostPosted: Sat May 26, 2012 4:22 am
I am taking this 2007 Cannondale SystemSix 54
and so far have gotten to here
This method of using the razor blade is taking a lot of time. Very slow and very labor intensive. However, I am happy with how clean it is leaving the frame compared to sanding it. At this point, it is going much slower. Paint seems to come off much easier, quicker and in bigger chunks over the aluminum half. However, the front carbon fiber is very very slow and very difficult. If things don't improve, I might have to resolve using something like Carbolift. I'm in no rush, but the portion over the carbon front is not very easy to chip away at.
Stock frame weight was 1172g. Currently it sits at 1146g and I expect it to get below 1100g. Rough guess, somewhere around 1060-1070g when all the paint and decals are stripped. Will then repaint the frame myself. Have a few ideas, but haven't solidified that yet.
Pics of rest of build kit to follow, predominately anchored by a Hollowgram SL crank. Will update this thread as the project progresses and as I seek advice.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Sat May 26, 2012 8:13 am
:thumbup:
PostPosted: Mon May 28, 2012 4:13 am
Weight now down to 1124g. Still have chain stays, downtube, toptube and headtube left. Not sure I will lose another 50g like I was first estimating. It will be close.
Now for some goodies:
The SRAM Red Black chainrings are a little porky, but the color and the stiffness will go perfectly with the build of this frame.
So far with the build:
Frame: 2007 Cannondale SystemSix 54 HiMod= 1089g (currently still more to go)
Fork: Cannondale SystemSix HiMod= 328g (currently, will stip as well)
Headset: Cannondale SystemSix= 70g
Crank: Cannondale Hollowgram SISL w/ SRAM Red Black chainrings= 493g
Bottom Bracket: Cannondale BB30= 137g
Stem: 3T ARX Team 130mm= 135g
Handlebar: Edge/Enve= 197g
Handlebar tape: Deda= 42g (uncut)
Seatpost: Easton EC90 SL= 199g (uncut)
Seatpost clamp: Cannondale= 23g
Saddle: Selle Italia SLR= 142g
Bottle cage: A1= 20g
Brakes: SRAM Red= 272g
Shifters: SRAM Rival= 331g
FD: SRAM Force= 88g
RD: SRAM Force= 171g
Chain: KMC X10SL gold= 224g
Cassette: SRAM Red= 154g
Wheels: Edge/Enve 1.65 DT240 w/o decals= 1229g
Tires: Vittoria Corsa EVO CX x2= 539g
Skwers: KCNC Ti= 45g
Valve extenders: Tufo 40mm x2= 4g
Glue/misc: 20g
Housing/cables: Yokozuna Reaction= ~150g
Pedals: Keywin CRM Ti= 196g
Total: 6298g
Rough estimate at this point, bike should be around 6.3-6.35kg built once the frame is painted. Not bad based on most of the parts above were spare parts/parts I got on the cheap. This build is not meant to be a super crazy WW build. This was meant to be a budget race bike and will make for a lovely crit bike.
PostPosted: Mon May 28, 2012 6:14 am
Looks like a nice summer project. Can you reveal your ideas for the paint scheme?
Looking forward to follow this project :)
Cannondale SuperSix 105 Team Replica: viewtopic.php?f=10&t=85941
PostPosted: Mon May 28, 2012 6:29 am
It will most likely end up black with a few Cannondale decals that are "ghosted" out if I can make that work. Black will match my other frames and seems the easiest as a DIY home project.
Thanks for your interest.
PostPosted: Mon May 28, 2012 6:52 pm
Weight now down to 1103g. Probably have another ~20g left on the frame to take off is my estimate.
PostPosted: Mon May 28, 2012 7:23 pm
Great looking project. Should turn out to be a great build. :beerchug:
PostPosted: Mon May 28, 2012 7:39 pm
Ah razor scraping. Been there before. Good luck with the project. Looks good so far.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Mon May 28, 2012 7:52 pm
Yeah you would know. Did you wet sand your Trek down or did you use a razor blade for parts of it?
PostPosted: Mon May 28, 2012 9:31 pm
how is the alu-carbon joint made? looks different than clear-coated SystemSIX.
will you then clear-coat the frame or just leave it rough? :)
PostPosted: Mon May 28, 2012 10:06 pm
I only did very light wet sanding with 800 grit after 98% of the paint was gone. I finished it up with a scotch bright pad, and light wet sanding with it.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Tue May 29, 2012 12:21 am
I'll take a shot of the alu-carbon junction later tonight.
For the paint scheme I am thinking of this Parlee. I know not very original. A nude with clear coat would be cool. But I think I might get tired of it.
Any reason for the Scotch bright pad at the end?
PostPosted: Tue May 29, 2012 2:49 am
It gets in all the spots that are hard to get with the blade, and paper. Then the last couple passes just prep it for the clear to stick to.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Tue May 29, 2012 4:16 am
Weight of the frame is now at 1095g. The rear triangle is about 95% done, still a few tiny patches that need work.
The front carbon triangle is one piece of work. That clear coat and decal layer is very very stubborn. I think I will need to move to sand paper now.
@ kenz76
Here are some pics of the aluminum-carbon joint.
@ ProfessorChaos
I picked up some 400 and 1000 grit wet sandpaper tonight. Those were the highest grit count wet sandpaper they had in stock. I am curious what you used? Do you think I will be ok with that?
After going through all the paint, I am blown away by how beautiful the frame still is. The aluminum welds are quite stunning. :beerchug:
PostPosted: Tue May 29, 2012 10:26 am
Depending on the actual finish after the paint comes off and you have scotchbrited it etc., why not put a clearcoat and keep as is with the TI effect or maybe half and half; the front maybe in black. There are some stunning System 6's that look like that.
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: cyclistcong, Google [Bot], Heritrix [Crawler], jörgl, Mockenrue and 30 guests
There are no new unread posts for this topic. cannondale systemsix bearing cover
digiadaamore
7
391
Wed May 15, 2013 9:23 pm
Getter View the latest post
There are no new unread posts for this topic. Cannondale Systemsix Paint scheme ?
masters324
16
1632
Thu Jun 07, 2012 6:08 am
53x12 View the latest post
There are no new unread posts for this topic. Cannondale Slice Di2 Project
turas
Thu May 31, 2012 8:44 pm
turas View the latest post
There are no new unread posts for this topic. Attachment(s) Cannondale flash team 26" project
BuddhaInc
Mon Jul 09, 2012 9:43 pm
BuddhaInc View the latest post
There are no new unread posts for this topic. SystemSix Brake Clearance Issues
gpeterson63
12
829
Mon Dec 03, 2012 11:57 pm
bikerjulio View the latest post
It is currently Mon May 20, 2013 10:14 am
