Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
 Post subject: A white Scott Foil U-Di2
PostPosted: Sun Apr 08, 2012 12:02 pm
There not much good Foil pics here yet, so I thought I share some. It's a bone stock Scott Foil 40, with Shimano105 and Shimano wheels.
I removed the wheel decals for a more non-flashy look.
Plans are:
Ritchey wet white handlebar & stem to match the seat post
Black saddle to match black tape
Ultegra Di2 gruppo or DA mechanical
Other wheels.
Also, got a Shi105 gruppo to sell :)
This was my last road bike, sold it in 2004 if I remember correctly and haven't had a road bike since.
Scott Foil Di2 2012
Scott Scale 35 2010
 Post subject: Re: A white Scott Foil
PostPosted: Sun Apr 08, 2012 4:03 pm
Here's some weights
Time ICLIC2 Carbon Titanium Pedals
Scott Foil seatpost clamp by Ritchey (uncut)
Scott Foil seatpost with saddle clamp by Ritchey (uncut)
Scott Foil Seatpost clamp
Selle Italia X1 saddle
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Sun Apr 08, 2012 4:20 pm
These scott foils look very similair to the giant tcr frame.
PostPosted: Mon Apr 09, 2012 9:54 am
What is the weight of the frame?
The 40 is made of HMF NET fibre and the more expensive is made by HMX NET fibre but how much is the difference.
Lars K. P.
PostPosted: Mon Apr 09, 2012 4:09 pm
Hey Lars, a previous person weighed a HMF R2(2010 designation I think) 54cm frame at 921 grams, here:
viewtopic.php?f=3&t=85579&start=210
Though, the white or yellow paint on the 40/30 is probably worth a few grams.
Even so, nice choice on your first bike back.
PostPosted: Fri Apr 13, 2012 10:54 am
Had my first ride yesterday and it felt good. Can't compare to anything, because I haven't ridden anything else for years. Only thing I can say that steering is "typical Scott style" - quick and responsive. Shimano105 was a disappointment. Shifting throw is too long for me and front trimming is limited.
Ordered a Ritchey wet white handlebar, but can't find a matching C260 wet white stem for decent price.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Mon Apr 16, 2012 3:07 am
If you have an issue with Shimano 105 and the long throw I highly recommend SRAM. I switched my 2009 Spec Allez Elite Comp from Shimano 105 to a mix of SRAM Apex and Rival this winter and couldn't be happier. The throw is much much less and the parts were a bit lighter if I recall correctly. Also, I basically broke even selling my 105 since if you shop around a bit SRAM stuff can be had for some crazy good prices
Looks like I made a new 90 Proof friend
PostPosted: Sun Apr 22, 2012 11:59 am
Well, I wanted to try Di2, so a Ultegra Di2 gruppo should be here next week - at least I hope. I have sold the 105 and must give it to the new owner next Saturday.
Crank will be DA7900. Received it yestarday after back from training. Of course, had to mount it right away.
I really like how it matches the white frame. Here's a quick pic. The bike is dirty, I know.
Front upshifts are noticeably better with DA rings.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Sun Apr 29, 2012 10:13 am
My Di2 conversion is almost complete. Everything went easy, even drilling out the rear internal routing cable stop. It just took some patience to drill it.
Have to sort out some tiny bits, but no time at the moment. Currently taking a break and spending time with my newborn child.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Sun Apr 29, 2012 6:40 pm
Wow, first Foil I have seen in something other than black/matte.
Visually the white spacer throws it off for me, might look better black?
PostPosted: Tue May 01, 2012 5:50 pm
Im havent decided wheter to go with black stem and spacers or with white stem and spacers.
Heres ther first pic of Di2 installed:
Will clean the bike as soon as possible and take some better pics.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Mon May 14, 2012 11:33 am
Hi bro,
Nice bike you have there. I have a Foil 40 myself and am keen to setup the bike with Ultegra Di2 as well. Currently running on Ultegra mechanical but am very interested to see how you managed the issue of the cabling.
Could you post more pix of the building process and how you drilled the holes to accommodate the group set? Much thanks and good work!
PostPosted: Tue May 15, 2012 4:49 pm
Just in case anyone is interested.
I have a HMX Premium Foil and it has HMF seatpost (no setback).
I wonder if the setback seatposts the pros use is HMX?
Did you request a setback seatpost or did it come standard with your bike?
2012 Scott Foil Premium
PostPosted: Wed May 16, 2012 5:05 pm
kindredd wrote:
Hi bro,
I didn't make any pics but it's not complicated, patience is the key.
0. You need at least a 5,5mm drill bit to drill out the rear cable stop. Using a 5mm drill bit only wasn't enough. The Di2 wire is ~5,1mm.
You have to drill a decent amount, but be patient and do not use a lot of force. Just apply gentle pressure when drilling.
At one point you may feel the drill moves forward quit a bit, but it might not be done yet. You can try to put the wire through, but do not use any force.
Once the drilling is done, the wire slides through easily.
1. Unmount all the mechanical parts you don't need. The bottom bracket plug cover will drop off once the shifting cables are removed.
2. You can leave the crack on, but removing it makes the install more easy (more room to work).
3. Attache the shifters and front wiring.
4. Take a used brake/shifting cable, put it through the opening behind the head tube (left or right depend which side you want to run the Di2 wire) so it exits from the bottom bracket plug. Now take the Di2 wire for the down tube and attach it with some tape to the end of the Di2 wire. Now pull the Di2 wire through the down tube.
5. Attach the down tube Di2 wire to the front wiring harness, attach the junction box (i used internal) to the wire.
6. Assuming the rear cable stop is drilled out, slide the wire through and catch it at the bottom bracket. Attach it to the junction box.
7. Attach the two wires for FD and battery mount. I ran them through the bottom bracket plug, between the rear chainstays and to the correspondending unit. In the middle way, I zip tied them behind the chain catcher. Not the nicest thing but you actually do not notice it.
To plug the bottom bracket hole use your own expertice, I drilled to stock cable routing plug so that I could run the wires through it and then used silicone to fix it in place.
I also filled the RD wire entry hole with silicone, so that water wouldn't get it form there.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Thu Sep 13, 2012 8:40 pm
I've done some more weight measuring.
Stem cap is 7g:
Stem cap bolt is 3g:
New 120mm alloy stem Ritchey WCS 260 wet white is 119g:
42cm Ritchey WCS Logic II Road 31.8 handlebar 254g:
Ultegra Di2 shifter is 158g:
Ultegra Di2 RD is 272g:
Ultegra Di2 long battery holder 43g:
Ultegra Di2 battery is 70g:
Dura-Ace crank is 467+187=645g
Hollowtech II bolt is 2g:
My current estimate weight is about 7,5kg, but I think it's actually 100-200g lighter.
I can easily lose 350g with saddle and lighter brakes and at least another 500g with wheels without spending a fortune.
Scott Foil Di2 2012
Scott Scale 35 2010
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], Malik and 29 guests
There are no new unread posts for this topic. My Scott Foil 40
Pimpdaddy
14
3001
Sat Dec 22, 2012 4:16 pm
Reamens View the latest post
There are no new unread posts for this topic. My Scott Foil 20
simurs4
Sat Jun 16, 2012 9:50 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Revised Scott Foil?
Novamax
Mon Feb 25, 2013 7:33 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Attachment(s) 2013 Scott foil 10
Sabracadabra
9
2070
Tue Nov 20, 2012 9:34 pm
53by11 View the latest post
There are no new unread posts for this topic. Scott Foil 30 size M
kampiakseli
Fri Oct 19, 2012 3:24 pm
kampiakseli View the latest post
It is currently Sat May 18, 2013 11:33 am
